SpeedFight 2 - GearBox oil
scoop85
PostPosted: 18:43 - 06 Aug 2014    Post subject: SpeedFight 2 - GearBox oil Reply with quote
Can someone PLEASE show me with pictures,... Where do i let old oil run out,... And where do i let new oil go in,... Or if you know for any video tutorial,... But at least pictures,... PLEASE PLEASE HELP...
SQL
PostPosted: 18:52 - 06 Aug 2014    Post subject: Reply with quote
Its belt drive?
scoop85
PostPosted: 19:03 - 06 Aug 2014    Post subject: Reply with quote
I dont know... I am new at this... Peugeot Speedfight 2, 2005, 50 ccm,... If it helps??
SQL
PostPosted: 19:07 - 06 Aug 2014    Post subject: Reply with quote
https://www.scribd.com/doc/123365278/Peugeot-Speedfight-50cc-Maintenance-Manual
andys675
PostPosted: 19:13 - 06 Aug 2014    Post subject: Reply with quote
speedfight 1 had drain screw at bottom of gear case, you fill it up through the level check screw, a thumb pump type oil can is good for this
speedfight 2, drain plug no longer tapped, they decided it doesn't need changing, just top up through filling screw, when it runs out there's enough in
scoop85
PostPosted: 06:42 - 07 Aug 2014    Post subject: Reply with quote
I dont understand so good english... Confirm if i am right... I can see there only ONE screw... Its probably filing screw... I mist open it... And check if i need to refill,... Otherwise, i dont need to change it.... Never... ? Even if Speedfight was standing still, not moving for 5 years??? Since 2009,... ?
andys675
PostPosted: 17:03 - 07 Aug 2014    Post subject: Reply with quote
the only way of emptying it is to remove the clutch and then remove the cover over the drive gears, which you will need a gasket for then, obviously when you remove the cover what is in there will just leak out, there is less than 100ml iirc
take the filler screw out, tip the bike back on the centre stand so the back tyre is on the ground, if oil comes out it has enough in, if not squirt some scooter gear oil up the hole until it comes back out of the hole, the hole is the fill level
Robby
Dirty Old Man
PostPosted: 17:08 - 07 Aug 2014    Post subject: Reply with quote
The oil in there isn't doing much. If changing the oil requires a lot of stripping down, you have far more chance of something going wrong during the strip down than of the gearbox failing because the oil is old.
Top it up, ride it.
gavcarter
PostPosted: 18:50 - 07 Aug 2014    Post subject: Reply with quote
if your that bothered syringe it out by the dipstick hole
scoop85
PostPosted: 19:05 - 07 Aug 2014    Post subject: Reply with quote
Is this the screw where I refill oil when needed??? Sorry for being so stupid,..? Smile
gavcarter
PostPosted: 20:37 - 07 Aug 2014    Post subject: Reply with quote
never worked on a speedfight but it could be. Usually with side mounted fillers like that just pour it in until it dribbles out that hole then its done.
scoop85
PostPosted: 13:55 - 12 Aug 2014    Post subject: Reply with quote
U helped me alot about gearbox oil,... Let`s see, if U can help me again,... What is called this little plastic thing under the bigger importent thing,.. I need english translation, so i can check and order it on eBay,... Or if anyone knows good link, where i can order it,... Drain screw was inserted in too much, and its broken,... So i need new one,... For more info, to know what am i looking for, check the picture,... PLEASE HELP ME Very Happy
gavcarter
PostPosted: 14:13 - 12 Aug 2014    Post subject: Reply with quote
If you mean the big part circled, and not something that goes inside its called a float bowl.
scoop85
PostPosted: 14:41 - 12 Aug 2014    Post subject: Reply with quote
Yes, you are right,.. Float bowl or fuel chamber,... But,.. WOW,... Its so expensive for such a little plastic thing with no other parts,... Cca. 40-50 eur ?!?!?!? Or i dont know where to search,...
gavcarter
PostPosted: 14:48 - 12 Aug 2014    Post subject: Reply with quote
Get a complete new one? Check this is right for your bike first though
https://www.ebay.co.uk/itm/NEW-CARB-CARBURETTOR-E-CHOKE-PEUGEOT-SPEEDFIGHT-2-50-LC-/161368548236?pt=UK_Motorcycle_Parts_13&hash=item259250a38c
scoop85
PostPosted: 15:04 - 12 Aug 2014    Post subject: Reply with quote
I dont think i would know how to change the whole carburettor,... But i know how to change only this float bowl,... I see other cups for just a few dollars or euros,... How come this one is so expensive ?!?!? Very Happy I will check for broken Speedfights in my area, and maybe i will get this float bowl here somewhere,...
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 16 - Page Size: 92.69 Kb
