 Robby Dirty Old Man
 Posted: 12:13 - 10 Aug 2014 Post subject: Anrdoid GPS tracker apps |
I'm currently using an old Android phone as a GPS tracker on the bike. The problem is that it isn't very reliable, stops updating its position for no good reason. It's an old phone and a cheap bike, so there's no point getting a proper tracker.
My current setup uses the Spysat app, and uploads the position every two minutes to www.spysat.eu
As far as I can tell, the main problem is that the thing is using GPS to get a fix the whole time. The phone lives in the tail unit next to a tower block most of the time, so it doesn't get a very good look at the sky. There is no option in this app to get a vague location off cell towers.
Is anyone else doing a similar thing, and have you found a better app? I want to be able to go to a web page and see where my bike is, to the best accuracy possible. |
 Snop Doog Brolly Dolly
 Posted: 16:14 - 10 Aug 2014 Post subject: Re: Anrdoid GPS tracker apps |
| Robby wrote: | I'm currently using an old Android phone as a GPS tracker on the bike. The problem is that it isn't very reliable, stops updating its position for no good reason. It's an old phone and a cheap bike, so there's no point getting a proper tracker.
Is anyone else doing a similar thing, and have you found a better app? I want to be able to go to a web page and see where my bike is, to the best accuracy possible. | I used to use 'My Tracks' on my SGS3, it's by Google. When I used it, I had no problems. I stopped because I didn't need it. But yeah, it tracks your path, speed distance and elevation. Also, it's free
Edit: You can upload, and then view your tracks on Google Drive.
Edit 2: You can set the accuracy you want. E.g, 1 metre, 3, metres, 7 metres and so on. It wasn't those exact numbers but you get where it's going.
 Ste Not Work Safe
 Gobsheen L Plate Warrior
 Furrybiker Trackday Trickster
