Lubricate small end bearing?
AzzA1990
PostPosted: 09:17 - 20 Aug 2014    Post subject: Lubricate small end bearing? Reply with quote
I am rebuilding the top end of my single cylinder 2 stroke engine, I'm fitting a new small end bearing and according to the Haynes manual the small end bearing needs to be lubricated before it's fitted but it doesn't say what to lubricate it with? i was thinking either bath it in 2 stroke oil for 5 minutes or using a bit of this?
https://www.amazon.co.uk/Castrol-16537290-500g-Muli-Puprose-Grease/dp/B005SP0MXW/ref=sr_1_1?ie=UTF8&qid=1408522536&sr=8-1&keywords=castrol+multipurpose+grease
Any recommendations?
Thanks guys
Aff
PostPosted: 09:20 - 20 Aug 2014    Post subject: Reply with quote
Permatex Ultra Slick is my assembly lube of choice.
Electric Bike Project
weasley
PostPosted: 09:25 - 20 Aug 2014    Post subject: Reply with quote
I just liberally doused it in 2T oil.
AzzA1990
PostPosted: 09:26 - 20 Aug 2014    Post subject: Reply with quote
Just found it! looks like awesome stuff
I can just drizzle a bit of this over the new small end bearing?
CestrianX
PostPosted: 10:46 - 20 Aug 2014    Post subject: Reply with quote
Generally, whatever you put on it will be washed off by the fuel/oil mix that fuels the motor when it's running, and it's that same fuel/oil mix that will lubricate the top end bearing in the future so if you don't want to spend extra money on other lubricants just dip it in 2t oil and go for it. Just keep it all clean as the slightest bit of gritshit in the bearing will cause problems.
pepperami
PostPosted: 11:52 - 20 Aug 2014    Post subject: Reply with quote
All the 2-smoke rebuilds I`ve ever done are this ^
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 53.93 Kb
