Cleaning Carb's, how long?
Az
PostPosted: 13:51 - 20 Aug 2014    Post subject: Cleaning Carb's, how long? Reply with quote
I'm having a mechanic that my brother knows clean out my carbs and he's saying 3hours to take them off the bike (Bandit 600), take them apart, clean them and refit them at £25/hour.
Does that sound about right? I've never had carb's cleaned out before so unsure if he's trying to charge me more or if 3hours is about right.
Also is £25/hour reasonable considering i'm taking it to his house and he's doing it in his garden Neutral
Another question I had is, is it actually worth getting my carb's cleaned out...
I've owned the bike for a year and its idle isn't as smooth as it was a few months ago and the bike in general isn't as smooth but it's not being problamatic and runs good on the whole. I just felt like it may benefit from a carb clean as they probably haven't been cleaned out in years.
c_dug
PostPosted: 14:05 - 20 Aug 2014    Post subject: Reply with quote
Sounds more like a balancing issue than a cleaning issue.
Bezzer
PostPosted: 14:28 - 20 Aug 2014    Post subject: Reply with quote
If it's used fairly regularly and running O.K. generally then don't bother paying £75 to have them cleaned. Proper cleaning would mean using an ultrasonic bath to make sure all internal passages and drillings are clear has he got one in his back garden? Regular use keeps them clean.
Just freshen it up with a service, valve clearances, carb balance and new plugs and it should be as good as "new"
Copycat73
PostPosted: 14:35 - 20 Aug 2014    Post subject: Reply with quote
I would try this first
https://www.amazon.co.uk/Choke-Carb-Cleaner-care-300ml/dp/B0032XHNTI
spray some down the fuel line after you drained wots already in the carbs: by runnin it till it stops: and leave it over night.
caveat emptor
Aff
PostPosted: 14:39 - 20 Aug 2014    Post subject: Reply with quote
Do it yourself?
Even if it somehow takes you 7 hours you would still be paying yourself £10 an hour, which isn't bad for a learning experience.
Electric Bike Project
Robby
Dirty Old Man
PostPosted: 14:47 - 20 Aug 2014    Post subject: Reply with quote
Petrol cleans carbs. Using the bike regularly keeps them clean.
smegballs
PostPosted: 15:09 - 20 Aug 2014    Post subject: Reply with quote
I'd say it's usually a lack of use that gums up carbs, altho I have had float valve issues before after dropping a bike. My guess is that the shock scabs of rust from the inside of the tank that then gets stuck on the float valve seats.
My sisters zzr has a tendency to fill the carbs with water, over the space of about a year or so, so every spring it needs the float bowls draining but that is about it.
Az
PostPosted: 15:49 - 20 Aug 2014    Post subject: Reply with quote
Ahh, I didn't realise running your bike regularly/petrol cleaned the carb's.. that's very self effecient! Smile
And what C_dug mentioned about the carb's being out of balance may be right. After some thread crawling, I think I may need a carb balance rather than a clean.
PostPosted: 16:49 - 20 Aug 2014    Post subject: Reply with quote
By the time you've got at them to remove them then got the airbox rubbers back on again after, three hours seems reasonable.
£25/hour is very cheap for a motorcycle mechanic.
chickenstrip
PostPosted: 16:59 - 20 Aug 2014    Post subject: Reply with quote
Even for a northern one Wink Laughing
Casper
PostPosted: 17:39 - 20 Aug 2014    Post subject: Reply with quote
I did mine just today. Just under an hour without the balance. Main and needle jets came out for a blast through but £25 is a good price.
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 68.55 Kb
