Dropped plastic syringe in fuel tank
gbrand42
PostPosted: 16:32 - 13 Sep 2014    Post subject: Dropped plastic syringe in fuel tank Reply with quote
My brother took it on himself to take some fuel out of my newly-filled bike for the petrol strimmer, using a small plastic syringe and has managed to drop the main part of the syringe in the fuel tank. I cant even see it to fish it out.
Do you think it will be ok to just leave it in there or is it likely to turn to jelly in the petrol and make its way into the fuel system and fuck up the injectors?
Any advise is welcome, cheers
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Tamsin
PostPosted: 16:37 - 13 Sep 2014    Post subject: Reply with quote
Depends on the type of plastic really.....
if it was me, I'd have the tank off, drain and it and get the syringe out, but its really simple to do that on the CG
1198
PostPosted: 16:43 - 13 Sep 2014    Post subject: Reply with quote
Drain it (through the tap for ease and lack of mess) into a can. Remove tank, remove syringe. Replace tank, refuel, throw bucket of water at brother. Fixed.
Dan100tdi
PostPosted: 16:47 - 13 Sep 2014    Post subject: Reply with quote
yeh dont leave it mate as it could start to brake down
The Artist
PostPosted: 17:07 - 13 Sep 2014    Post subject: Reply with quote
It will have started to chemically react unless it is some special hydrocarbon resistant plastic which is unlikely. Get it out ASAP.
What bike is it and what sort of fuel system? I would be more worried if it was FI rather than carbs.
PostPosted: 17:33 - 13 Sep 2014    Post subject: Reply with quote
Bike is already screwed, sell it to Paddy. Whistle
Matt B
PostPosted: 17:37 - 13 Sep 2014    Post subject: Reply with quote
Deauville is it?
Not to bad a job. See here:
https://www.elsham.pwp.blueyonder.co.uk/deauville/remove-fuel-tank/
PostPosted: 18:06 - 13 Sep 2014    Post subject: Reply with quote
Matt B wrote:
Deauville is it?
That's showing how to do it on the 650, not the 700. Although, removing a fuel tank is usually a simple job and that would give you an idea of how to do it but not a definitive guide.
stevo as b4
PostPosted: 18:07 - 13 Sep 2014    Post subject: Reply with quote
Or Fill strimmer tank with said water and throw bucket of petrol at Brother? Thumbs Up
ws4936
PostPosted: 18:37 - 13 Sep 2014    Post subject: Reply with quote
https://i.ebayimg.com/00/s/NTAwWDUwMA==/z/l3IAAOxyGstR~DUd/$T2eC16d,!)UE9s3wDcdOBR+DUdW8og~~60_35.JPG
If everything seems under control, you're just not going fast enough.
gbrand42
PostPosted: 18:44 - 13 Sep 2014    Post subject: Reply with quote
Done, tank drained and removed, syringe removed and tank replaced. Bit of a ball-ache (have to remove the fairing side panels and the fairing cubby holes). Drained petrol has found its way mysteriously into the wifes car. Brother is out buying compensatory pizza and beers. Thumbs Up to you all for your advice.
Oh and there is no fuel tap on this bike as it has FI, so had to syphon it the old fashioned way and managed to get a mouthful of finest shell unleaded. Mmmmm refreshing.
Matt B
PostPosted: 09:55 - 15 Sep 2014    Post subject: Reply with quote
Good job Thumbs Up
Sometimes cock ups like that aren't a bad thing, you learn a bit more about your bike when you are forced to strip it apart.
The last post was made 12 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 74.34 Kb
