 Rogerborg nimbA
 Posted: 16:22 - 17 Sep 2014 Post subject: 2007 cb500 not stsrting |
Lights ok. No starter. Died abruptly. neutral light ok. Wont start in neutral. Fuses ok. No alarm no immobilser no multimeter. SidestNd switch attached. Ideas? ____________________ Biking is 1/20th as dangerous as horse riding.
 map Mr Calendar
 Posted: 16:28 - 17 Sep 2014 Post subject: |
Any clicking when hit starter?
If there is I would say look to the starter motor.
Try putting in gear and rocking forward. Or sort of try bump starting it in 2nd. Then hit the starter button. If fires into life clean/refurb the starter motor (I did a thread).
I also note mine does not like being wet. More difficult to start. I am suspecting a leak to earth but it will be a sod to find. What voltage on battery?
If not the above then when you find cause/solution please post  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
 Rogerborg nimbA
 Posted: 16:35 - 17 Sep 2014 Post subject: |
Loool killswitch. ____________________ Biking is 1/20th as dangerous as horse riding.
