How would you stubby this can?
PostPosted: 08:18 - 27 Sep 2014    Post subject: How would you stubby this can? Reply with quote
Bought on a whim, a standard, dented end can with a welded on cap.
https://i57.tinypic.com/2cna8ts.jpg
Suggestions are welcome for re-attaching or replacing that end cap after stubbying it, or to be more precise, re-joining the cut exhaust at any point.
Hacksaw, angle grinder, riveter, silicone gloop, metal tape and patience is available and I don't give a stuff about how it looks, as long as it's more or less gas tight. The original will be going back on for MOTs and sale.
I don't plan to re-weld it to within fish finger of a sprocket as this is a DIY garage project for funsies. I mean, a stick welder is available but I can't weld thin sheet with it - I'm no BodyGuard. Whistle
Fisty
PostPosted: 08:46 - 27 Sep 2014    Post subject: Reply with quote
As It is not a straight through can there will be much internal gubbins that will need re welding too.
I wouldnt bother, but I am lazy.
Fatter and faster than Fret
PostPosted: 08:49 - 27 Sep 2014    Post subject: Reply with quote
I also wouldn't bother. I don't really like stubby cans.
PostPosted: 08:56 - 27 Sep 2014    Post subject: Reply with quote
But if you were to bother...
To forestall the "Y U..." Zeitgeist, the whole thing including the bendy link pipe cost less than a separate new link pipe, so worst case I can just chop the can off, fit a slip on and still come out ahead of the game.
PostPosted: 09:00 - 27 Sep 2014    Post subject: Reply with quote
To forestall the "Y U..." Zeitgeist, the whole thing including link pipe cost less than a separate new link pipe, so worst case I can just chop the can off, fit a slip on and still come out ahead of the game.
Hack it in half, then take it to a friendly machinist to be re welded.
Personally I'd probably chop around the weld near the end cap, then cut however much you want out of the middle section, then get someone to re-weld the end cap back on.
nowhere.elysium
The Pork Lord
PostPosted: 09:01 - 27 Sep 2014    Post subject: Reply with quote
Cut it at the other end of the can?
kramdra
PostPosted: 10:06 - 27 Sep 2014    Post subject: Reply with quote
Get a strip of stainless sheet to make a sleeve and rivet it together.
Stainless can also be braised, you need borax flux, any form of scrap brass rod and a torch. The link pipe and headers may get too hot but it would be fine on can.
Or find someone local with a welder. I have just bought stainless wire and argon, so plan to try similar myself soon.
Fisty
PostPosted: 10:09 - 27 Sep 2014    Post subject: Reply with quote
_Iain_ wrote:
Oh and before the screams of potato, moron etc, micron produced cans that were held together with a simmilar principle;
https://www.micronexhaust.com/store/images/01canistersend.jpg
Potato.
The micron cans had end caps held on with cap heads, not stud bar going all the way through.
PostPosted: 10:36 - 27 Sep 2014    Post subject: Reply with quote
I know the correct answer is "weld it together", but this is an experiment in bodging rather than in doing it right.
On that note...
_Iain_ wrote:
https://i.imgur.com/zSNUA9a.jpg
That is potato, but I love it. Thumbs Up
A strip of stainless riveted across the gap (possibly inside and out) and sealed with silicone was my standby position. Thoughts on thickness?
I'm not set up for brazing, but I'm beginning to wonder if I should be. Looks like a laugh.
Fisty
PostPosted: 10:48 - 27 Sep 2014    Post subject: Reply with quote
As the innards will look not too dissimilar to this
https://www.bikersoracle.com/jaws/myPictures/exhaust11.jpg
Without stripping the whole thing down you will need some mighty long drill bits to get through the internal baffles etc.
Potato.
Fisty
PostPosted: 13:43 - 27 Sep 2014    Post subject: Reply with quote
_Iain_ wrote:
Potato.
So dremel the bottom cap off too, as said bolts setup will be perfectly good at holding the bottom cap on.
All that gumph thats in there is easily removable with a hammer and a metal bar. How do you think the KTM cans were gutted? They had inside a simmilar setup to that.
Potato Wink
Edited for pics;
https://www.teamincomplete.com/projects/duke/Resources/img6301.jpeg
Dremel the cap off? That will take some time and A LOT of dremel cutting discs.
Mr Borg Esq's can is welded at both ends, no doubt the internals are welded to the outer skin too at the ends.
I have no Idea how the KTM cans were gutted my crystal ball is a little cloudy lately.
The picture you have shown is a riveted, rebuildable can. Mr borg esq can is not.
The only way to really do it is cut the caps off, gut it, cut it to length, fit a straight through tube and new wadding, and re weld it.
You could if feeling very potato, cut the caps off 25mm inwards then taper the skin on the cap so the cap slips back in under the skin of the main body. Lots of silicone sealant then rivet the cap into place.
https://s1.cdn.autoevolution.com/images/news/how-to-check-for-exhaust-leaks-with-potatoes-on-1992-2002-toyota-camry-video-74353_1.png
Potato
P.
PostPosted: 14:52 - 27 Sep 2014    Post subject: Reply with quote
Wouldn't stubby, would just cut the end exit bit off and make the hole exceptionally wide at the end of the can. Laughing
PostPosted: 15:12 - 27 Sep 2014    Post subject: Reply with quote
First off, for loudness, you could just run with down pipes. *loud*
Then - going seriously bodgetastic, I'd be tempted to cut a section out of the middle, then got slots (alternating position on each half) around and see if you can slide one half inside the other.
Or just get a cheap one you can rivet instead.
Robby
Dirty Old Man
PostPosted: 15:32 - 27 Sep 2014    Post subject: Reply with quote
You may well find a suitable epoxy, I doubt it's going above 250 celcius. It's likely that there's some sort of end cap inside the can so you could bolt through the one you remove and the inner end cap.
For a really quick, easy and ugly bodge you just wrap some metal around the cut with a smear of silicone and pop rivet it.
PostPosted: 15:37 - 27 Sep 2014    Post subject: Reply with quote
I was just thinking, actually... or have the metal inside for less ugly.
gavcarter
PostPosted: 16:11 - 27 Sep 2014    Post subject: Reply with quote
Looking at fistys pic, I would cut the end off with a hacksaw or very carefully with a grinder ( whichever you can get the straightest cut with...)
Then I would start to cut the sleeve of the can down bit by bit until you hit the metal plates visible in the pic
Pick a plate ( or a can length ) and finish the sleeve flush with this plate.
You can use high temp silicone etc between the plate and the outer sleeve to gas tight it - just finger it smooth with the end plate before it sets.
Put the end cap in place temporarily and mark the inner exhaust diameter on the end plate with a marker, and proceed to drill a lot of holes around its circumference. If you cant be bothered to dremel or file to a decent finish then make it 10mm bigger so it cant be seen through the end cap.
To replace end cap I would drill 3-4 holes in the end of it and bolt it to the plate inside the exhaust as the micron ones do.
If the cuts are nice and square and the weld is still in place you probably wont be able to tell its been done as the inside is gas-tights you wont get the tell-tale carbon streaks where its leaking.
If you want to GUT it totally the easiest way is to cut it at the base nice and square BEHIND the weld.
Pull the outer sleeve off, pull the packing out of the way and then chop off the pipe that is welded to the base of the can.
This should leave you with an empty can, and the base...
If you carefully inspect the base you should be able to carefully grind away enough weld ( and a small part of the outer skin that was left ) and have the outer sleeve push back on ( after cutting to desired length ).
A good smear of exhaust paste will ease the skin back on and also help to gas-seal it. Then go round with a drill and a riveter to keep it in place. I find it easiest to do 1 rivet - then one 180 degrees to that, then 2 at 90 so that you can pull the sleeve onto the base and keep it square, if you set off putting a river every inch or two one after the other its easier to mis-align the can
PostPosted: 17:55 - 27 Sep 2014    Post subject: Reply with quote
Interesting stuff, thanks all.
It'll come down to what's actually inside the can which I won't know until I start hacking.
£38 delivered, by the way, and it costs £55 just for a new link pipe, so I'm not too fussed if I keep cutting until there's nothing left. Wink
Clanger
Stirrer
PostPosted: 19:04 - 27 Sep 2014    Post subject: Reply with quote
Personally I'd give it to my mate Big Steve, and get him to sort it. Then when he's finished, I'd give it to my mate Grizz and get him to polish the fury out of it. Then I'd give it to my mate JD and get him to put it back on the bike...all this would cost me a bottle Southern Comfort - 'cos my mates love me... Wub
Sload
PostPosted: 19:32 - 27 Sep 2014    Post subject: Reply with quote
Cut it, gut it and have it re welded by someone that can for best results. Ill say Ians idea would work fine too, plenty of things retained with tie bars but as with anything the more effort you put in then generally the better the results Thumbs Up
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
PostPosted: 19:55 - 27 Sep 2014    Post subject: Reply with quote
I don't want to gut it completely as I'm not sure if the GS runs closed loop (using the O2 sensor) all the time, or if it goes to an open loop fixed mapping at high rpm / throttle, which is likely to run lean with a straight through pipe.
I'm only considering doing it at all since I'm mostly using it for a commute where it's barely off idle most of the time, and it's dangerously stealthy. It'd be the Hun in the sun, if we had sun up here.
The last post was made 10 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 1.12 - MySQL Queries: 16 - Page Size: 149.84 Kb
