Weird electrical issue
c_dug
PostPosted: 09:50 - 06 Oct 2014    Post subject: Weird electrical issue Reply with quote
Over the last week my bike has developed an odd electrical fault. It took a couple of times for me to nail down what was happening, I think it happened 3 or 4 times in total last week. It has been very cold and damp in the mornings so I'm not sure if that has contributed.
I park with my front wheel to a hedge, so the first thing I do is get on the bike, key in ignition on. With that the headlight, dashboard and Neutral light all come on. I then start to paddle the bike backwards by around a foot or two, the backwards bit may or may not be relevant but I thought I should mention it.
While paddling backwards everything electric dies for about half a second. No lights on anything. Clock resets (Time not Odometer). It then all comes back on. I think it makes a sound a lot like a starter solenoid clicking as the power comes back on, I've not identified where the click is coming from.
- The bike starts up fine and there are no issues at all on the way to work.
- The issue only seems to happen first thing in the morning.
- I don't think I am pressing the starter button or anything like that which might somehow trigger everything to die.
I have never replaced the battery and I have questioned it's health in the past, it is just about at the top of my replace list for when I have the spare £££, but to me the issue doesn't seem like something that would be caused by an unhealthy battery? It still shows 12V.
Copycat73
PostPosted: 10:15 - 06 Oct 2014    Post subject: Reply with quote
worn ignition lock or contacts .. try jiggling the key in the lock when it goes off and see wot happens. Thinking
caveat emptor
c_dug
PostPosted: 10:25 - 06 Oct 2014    Post subject: Reply with quote
I don't really have time to, by the time I've noticed it has gone off it flicks on again. I've had a fiddle with a few bits but I can't seem to force it to do it.
To be honest if it was something loose and moving I would expect it to happen while riding along.
map
Mr Calendar
PostPosted: 10:44 - 06 Oct 2014    Post subject: Reply with quote
Can you confirm the bike, not clear from your tags line, is it the XJ900?
One thing I can think of related to going backwards (and I'm not exactly sure if there's one fitted) is a tilt sensor being dodgy.
Other than that I'd go with looking at the contacts in the ignition/key area. Or maybe kill switch electrics being pulled/shorting with backwards movement (so ok when ridden forwards).
c_dug
PostPosted: 10:58 - 06 Oct 2014    Post subject: Reply with quote
Yep sorry, diversion 900.
iooi
PostPosted: 12:02 - 06 Oct 2014    Post subject: Reply with quote
Moisture getting into the switches maybe.
Get some WD 40 or such sprayed into the switch clusters.
Or park the bike the other way round Thumbs Up
WD Forte
PostPosted: 12:52 - 06 Oct 2014    Post subject: Reply with quote
Intermittent faults can be a sod to pin down
It sounds like a bad connection
(or possibly a wire breaking at the headstock?)
If you have time I'd suggest one morning just turn it on but
dont move the bike.
Tap around and nudge stuff with a screwdriver handle to see if you can replicate/localise the fault.
It could just be the weathers got in and you need to open check clean all
connectors and squirt some electrolube or ACF50 in
bikers smell of wee
Suntan Sid
PostPosted: 13:34 - 06 Oct 2014    Post subject: Reply with quote
I had a similar problem with my DRZ400E, turn the ignition, sometimes it worked, sometimes completely dead.
Turned out the main fuse holder and wiring were a bit dodgy.
The fuse was situated on the frame just between the seat and side panel. The position of your backside, on the seat, or how hard you brushed the side panel with your boot, last time you used the bike, determined the availability, or lack of, electrickery, when turning the key!
What, if any, wiring is under your seat?
PostPosted: 13:50 - 06 Oct 2014    Post subject: Reply with quote
Solenoid-type clicking noise shortly after turning on the ignition says fuel pump to me.
Does it have one? If it does, I'd look here first, even if it's just to confirm this is the source of the clicking.
map
Mr Calendar
PostPosted: 13:59 - 06 Oct 2014    Post subject: Reply with quote
If we're admitting to weird electrical faults of our own bikes the old GT550 had one. Could I find it, could I heck.
Then one day looked at what appeared a good solid earth wire from battery. Gave it a little pull and it just crumbled to dust. Totally gone. A fresh piece of shiny (insulated) copper wire and all as good as new (well as good as for a 20+ year old bike).
So, on topic, checked a good earth connection?
monkeybiker
PostPosted: 14:05 - 06 Oct 2014    Post subject: Reply with quote
Sounds like a bad conection so where, try cleaning the battery connection.
c_dug
PostPosted: 14:39 - 06 Oct 2014    Post subject: Reply with quote
Just mulling over on this.
For it to reset the clock every time I presume it must be one of the main power connections, pretty much every other component on the bike is switched with the exception of the clock. The only reason the clock would reset is if it lost power.
So it can only really be one of the main connections to the battery?
Or am I way off?
I'm not ignoring any of the above suggestions for the record, I'll have a look tomorrow when there is less rain.
monkeybiker
PostPosted: 15:12 - 06 Oct 2014    Post subject: Reply with quote
Yes I would have thought a bad battery connection like you say because of it resetting the clock. Could be also be problem at the fuse box but I would try the battery connections first.
Might be loose and just need tightening up or connection could need cleaning.
PostPosted: 15:18 - 06 Oct 2014    Post subject: Reply with quote
I had something similar, however it would happen when I press the starter, everything thing would die then come on again and be fine. Turned out to be the starter solenoid.
If you want to try sorting it with spending money take the seat, tank and airbox off and take apart and clean every connection you can see especially the battery and solenoid connections. Also try wiggling cables with the igntion on see if you can force it to do it.
I would replace the solenoid, if there is still no joy, but that is based purely on my replace experiences.
PostPosted: 15:50 - 06 Oct 2014    Post subject: Reply with quote
That, or there is an intermittant short draining a huge amount of power.
PostPosted: 15:58 - 06 Oct 2014    Post subject: Reply with quote
See where the main feed is routed, on my KTM and TDM the live is directly routed through the solenoid before it goes out to the rest of the bike. Thumbs Up
c_dug
PostPosted: 17:28 - 07 Oct 2014    Post subject: Reply with quote
I had a look today, the positive battery terminal was a tad loose, I could just about indo it with my fingers, wasn't much movement in the connection though. That was the only thing I could see wrong, cleaned up the terminals on the solenoid and battery anyway but to be honest I've seen way way worse still functioning fine.
I'll just have to keep an eye on it for the next couple of weeks and see if it repeats.
Ribenapigeon
PostPosted: 13:26 - 08 Oct 2014    Post subject: Reply with quote
From what you said in the original post I take it your switching on the ignition but not starting the bike til, you've paddled back, right?
if that's the case I think your battery has low power or a bad connection. Its just charging into the coils then running low on power and conking out for a moment. This might explain why the bike behaves the rest of The day. You could try charging the battery over night see if that cures the problem first before buying a new battery.
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 102.06 Kb
