Author |
sainttm |
sainttm Two Stroke Sniffer
Back to top |
mchaggis |
mchaggis World Chat Champion
Posted: 12:55 - 18 Jan 2005 Post subject: |
Yes. Blip the throttle when you change down, and the engine speed will match the rear wheel speed more quickly in the lower gear. Less clutch wear and less stress on the gearbox. T'is a good thing. Sounds good too.
Also, if you knock down a gear and it skips more than one, if you're blipping the throttle it might save you from locking the rear. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
Back to top |
Craggles |
Craggles Traffic Copper
Back to top |
Rory |
Rory Traffic Copper
Back to top |
AcIdBuRnZ |
AcIdBuRnZ World Chat Champion
Back to top |
Claud 14.7 to 1 |
Claud 14.7 to 1 World Chat Champion
Posted: 04:39 - 20 Jan 2005 Post subject: |
Craggles I suspect you instructor told you not to do it because it is difficult for a learner to pick up, and not necessary for test standard. It is probably hard for a new rider to use front brake and blip the throttle at the same time. It just adds confusion. It's really not needed.
I wouldn't recommend doing it until you have passed and have your own bike to practice on. And remember to practice with the bike going straight and level until you are confident/good enough.
It's not as if you are reving it high for the test. You keep the rpm low, so you don't really need to blip. Wheel won't lock up if you are using low rpms, just easing the clutch will be enough at low rpm.
Rory, you so need to do it on 400s eh? Keep them buzzing... |
Back to top |
Craggles |
Back to top |
Mantzy |
Mantzy Spanner Monkey
Back to top |
Claud 14.7 to 1 |
Posted: 13:25 - 20 Jan 2005 Post subject: |
IMO it's only really needed if you are riding like you would on a race track - keeping the rpm higher for maximum power delivery, and then for coming down from high rpm using the emphasised engine braking higher up.
Saying that, sure you can use it when not pushing it, but there isn't as much point. Does sound good though, and smoothens things out.
Hence why IMO you don't need it for test standard. Hehe
Practice it when you have passed and can really experiment with your bike and your riding. Then find out whether you will need it or use it. |
Back to top |
Rory |
Rory Traffic Copper
Back to top |
..... Quote Me Happy
Back to top |
The last post was made 19 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
