Dads '67 Triumph TR6R Trophy, ongoing project.
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: 21:42 - 29 Oct 2014    Post subject: Reply with quote
See the first picture, it has been like it for a while! I'm going to check the timing in the next few days.
What are the tolerances for Brake drums?
https://www.youtube.com/watch?v=kL8kcOtY4sE&list=UUknRPFX5-bRMoHdUU8gYXaQ
My Method of measuring is a bit Heath Robinson. I'm getting a judder under heavy braking.
331X2
PostPosted: 00:54 - 30 Oct 2014    Post subject: Reply with quote
Do the measurements repeat on the inside of the braking surface (closer to wheel centre)? How much would spoke tension affect runout?
PostPosted: 11:47 - 30 Oct 2014    Post subject: Reply with quote
Sorry I don't really understand the question that is the inside of the braking surface :-S
331X2
PostPosted: 12:04 - 30 Oct 2014    Post subject: Reply with quote
Yeah, I wrote that like a bit of a spastic, sorry.
As the wheel is set up in the video, can the DTI be moved downwards to take a reading closer to the bottom (as it is in the video)? Imagine you are measuring the runout at the top of a cylinder standing vertically, now measure the bottom, ie the other edge.
I think I might draw a picture...
PostPosted: 12:41 - 30 Oct 2014    Post subject: Reply with quote
Although it was difficult to see it is actually measuring it fairly centrally. I'll have a go at measuring the top and bottom.
331X2
PostPosted: 12:45 - 30 Oct 2014    Post subject: Reply with quote
OK, imagine (again) that the aerosol lid represents the drum, you are currently measuring the runout of the drum here;
https://i689.photobucket.com/albums/vv258/L339EFX/IMG_20141030_111945.jpg
Now what happens if you take a reading here?;
https://i689.photobucket.com/albums/vv258/L339EFX/IMG_20141030_111956.jpg
Is there less runout or the same?
Edit: Seems my illustrations weren't necessary Laughing
PostPosted: 17:23 - 30 Oct 2014    Post subject: Reply with quote
Showing about 3 thou oval on that dial, but the angle it's working at means it's probably more like 2 thou.
PostPosted: 17:38 - 30 Oct 2014    Post subject: Reply with quote
I did wonder if I needed to pythagoras it but I couldn't get my head around it.
Pete. has offered to skim the drum for me, apparently it won't fit in his machine(s)however he has a plan so cunning you could put a tail on it and call it a fox, pictures and possibly a video to follow sunday (I know how much BCF love machining videos). Thumbs Up
Triton Thrasher
PostPosted: 00:27 - 31 Oct 2014    Post subject: Reply with quote
Best to put the whole wheel in a lathe to skim the drum.
Otherwise the spokes pull the drum out of true again when you lace the wheel.
Rrrrrrrrrrrrrrrrrr
PostPosted: 00:33 - 31 Oct 2014    Post subject: Reply with quote
That's the plan. Can't swing 26" in any machine I have got but where there's a will etc....
Triton Thrasher
PostPosted: 21:08 - 31 Oct 2014    Post subject: Reply with quote
You don't have to leave the tyre on.
Rrrrrrrrrrrrrrrrrr
PostPosted: 23:32 - 31 Oct 2014    Post subject: Reply with quote
No but it makes no odds since the bare wheel doesn't swing in my lathe either.
mysterious_rider
PostPosted: 15:32 - 02 Nov 2014    Post subject: Reply with quote
to skim the drum just use an air die grinder. Will do it in seconds.
Very cool bike, enjoyed this thread.
KAWASAKIIIII
PostPosted: 11:44 - 03 Nov 2014    Post subject: Reply with quote
Drum skimming not required Rolling Eyes I put the front wheel back together after measuring, because we were due to sort the timing out, however the strobe gun I borrowed was playing up and wouldn't flash when it was reved Rolling Eyes
Anyway long story short adjusted the timing a little bit before the bike packed up and it is more powerful low down now. Need to get it done properly with a better gun.
On the test ride I noticed all the juddering had gone Embarassed somehow something I had done when putting it together was causing it. Can't work out what though so will have to look later. It has a fair bit of oiling coming out of the rocker cover how so new gaskets will be needed!
PostPosted: 01:14 - 19 Jan 2015    Post subject: Reply with quote
Slight update, dad loves the bike and has put a good few miles under his belt on it even in the shitty weather. Then the day before Xmas eve, the rear brake lever detached itself as he was coming up to a junction and there was a touching cloth moment.
https://www.bikechatforums.com/download.php?id=94321
The lever should have a square to locate a cam arm and as I mentioned earlier in thread the square was a bit ropey and loose and this I think helped cause it to sheer.
Anyway we couldn't find one on anywhere to buy online, so the only other choice was to get it repaired. I asked BCF's epically excellent engineering extraordinaire Pete if he would look at it for me. He very kindly offered to sort it. Sorry I didn't get too many photos but the work was blinding. Pete's plan was to turn down an old high tensile bolt from a demolition robot (plus cool points for that), cut a thread, mill in a square, drill out some of the snapped part then weld in the new one.
Turning down the bolt.
https://img.photobucket.com/albums/v295/chris-red/6D68C336-91C5-4503-B612-E3E79A5FB6B6_zpspqtwhcli.jpg
Centering the old pivot in the milling machine.
https://img.photobucket.com/albums/v295/chris-red/4AE816BB-A6F4-488F-AC0A-19DEC0D0F7B7_zpsdy750679.jpg
The finished article...
https://img.photobucket.com/albums/v295/chris-red/8CE66496-FCB8-4E77-B30A-5196092C4686_zpsk9uy2str.jpg
https://img.photobucket.com/albums/v295/chris-red/7031E38B-705E-49D4-A727-DB3F8DED492C_zps9jklzlia.jpg
It's now 12.9 tensile steel and will probably out last the rest of the bike, it is a lovely tight fit in the arm and should noticeably improve braking I reckon. I wish I had gotten more photos of the piece Pete made up it was really nice Laughing
It took up a large part of Pete's Sunday and I got tea, coffee, biscuits and bacon sarnies! I'm extremely grateful! Binge also stopped by to show off his new lathe it was like a mini BCF meet!
PostPosted: 11:12 - 19 Jan 2015    Post subject: Reply with quote
Was my pleasure Smile
That setup in the mill might look a right lash-up but with no straight of flat part anywhere on the whole pedal assembly it was what was needed to get the job done.
What was also highlighted was the difference between modern and 1960's materials. The new pivot I made which I milled a square in had to be bashed right through the crooked square hole in the actuator arm, and it cut it square for a nice tight fit. Didn't even roll the edge slightly of the 12.9 bolt material.
PostPosted: 17:17 - 21 Jan 2015    Post subject: Reply with quote
Does anyone know where we can acquire a matching Tacho to this speedo.
There are plenty about but none in this style, with the black finish.
https://img.photobucket.com/albums/v295/chris-red/Bike%20back%20together/IMG_0141_zpse58ca4b1.jpg
I believe it is off a later bike, possibly even a 750.
Wave2k
G's Stalker
PostPosted: 18:15 - 21 Jan 2015    Post subject: Reply with quote
Late to the party as always, but what a magnificent thing you did.
Total legend.
Ducati 1299 Panigale
2009 Corvette C6 z51
PostPosted: 13:18 - 23 Jan 2015    Post subject: Reply with quote
Dad fitted the lever last night after a few coats of hammerite, it is a brilliant fit. 0 movement in any direction other than up and down. I honestly believe it is better now than when it left the factory. Thumbs Up Thumbs Up Thumbs Up Huge thanks again to pete again for his efforts
I'll post some more photos once it sees daylight. Dad fitted some new bars that are US spec, they are higher and further back but not outrageously so. They are ideal for dad's dodgy back and my size, besides it is a Canadian import so is more original Wink There is still a list of things to do but I'm led to believe it isn't a classic bike if you don't have a list of things to do!
In a vague order of priority
New Front brake Cable - never been right the inner is too long
New Choke Cable - it's a bit tight with new bars
Electrical system - Charging is 'iffy' convert to a modern reg/rec
New Tyres - old ones aren't bad but are old and cracks are starting to appear in the sidewalls.
Look at cam cover gasket, slight oil leak - It's a British bike
Repaint - The paint is shitty, it looks alright but really isn't a good job, it has cracks and in places on the oil tank has reacted with the metal, the front mudguard is also a crap reproduction one that will be replaced.
steveh
PostPosted: 13:55 - 23 Jan 2015    Post subject: Reply with quote
You can get the tacho's pretty easily for a unit construction, your bike uses a Smiths 4:1 ratio clock (driven clockwise)
You can buy a match pair of pattern ones for about £100, there good quality (ive got them on my TR6R) and then just alter the milage to suit yours.
Original ones aren't impossible to get, but be prepared to hunt around abit.
You can use a 2:1 tacho, and don't use the right angle drive gear, but these were only made for about a year or so, i think it was a 66 model T120 that used this, but id have to check.
PostPosted: 17:15 - 23 Jan 2015    Post subject: Reply with quote
Thanks,
I thank both he and I would rather get one to match I think, not necessarily for originality but gleaming new dials on a slightly scrapy bike would look out of place. It needs the patina!
PostPosted: 15:52 - 18 Feb 2015    Post subject: Reply with quote
Right the front brake, what a PITA this has been However the light at the end of the tunnel is finally in view.
The more a fiddled with it the more I could see something was wrong.
It started out me believing the brake cable was wrong as after I justed the shoes till they didn't drag I had to wind the cable out to full adjustment AND put a collar round the end of the cable for a bit more pull. It seemed like the cable was wrong.
I asked on another forum and they told me the shoes weren't adjusted correctly. Bollocks I thought I adjusted them perfectly myself, they were 1 click back from dragging. I asked them to elaborate and they showed me this...
https://i589.photobucket.com/albums/ss339/BikeVice/Conical-Front-Brake-1971-73_zps5a2ef83f.jpg
A 1972, properly adjusted front brake.
Spot the difference.
https://img.photobucket.com/albums/v295/chris-red/wweffew_zpsd185b5df.jpg
Dads brake.
The arms are pointing in far too much, the adjustment on the cable is taking up far to much of the distance between the shoes and drum.
So I didn't do the adjustment correctly, well thats what I though. So I readjusted the brake, however after winding them back off then winding them back in I still had the same problem.
Thoroughly confused I started looking more at the wheel itself. We have always noticed the wheel was slightly off to the LHS of the bike but we assumed it was either just how they were, or the forks/yokes etc. was slightly bent. As we didn't think it was causing an issue we ignored it. I started checking as best I could if anything was bent but it all seemed fine.
A closer look at the wheel gave us some more clues.
https://img.photobucket.com/albums/v295/chris-red/75665421-BDF3-42E3-B957-ADECD91400AE_zpsvc6tcgpr.jpg
https://img.photobucket.com/albums/v295/chris-red/59D7E79C-8CF2-46EA-A250-47890C92CC73_zpsqglgbeyd.jpg
The gap here is only at the top and only when the brake is tightened to the fork leg.
https://img.photobucket.com/albums/v295/chris-red/1DCD1AB1-3532-453E-80B0-8A91B7A99FF5_zpsnwgdl36b.jpg
All these photos where taken with the spindle already over to the drum brake side
https://img.photobucket.com/albums/v295/chris-red/EBC8DCF1-F617-44B5-95DD-43F2EA06BDBA_zpsdymypqhl.jpg
https://img.photobucket.com/albums/v295/chris-red/69FE3A72-7D84-4885-9D83-916F716D8140_zps7qrf4bgp.jpg
Having the Spindle in the middle caused the brake to be away from the fork leg, meaning tighten the brake pulled it off center. Pushing the spindle as far over the the right as possible made it better but clearly wasn't right.
This meant as far as I could see it the wheel needed to be 1/4 over to the right on the axle.
This was confirmed on the forum as someone pointed out there was a lot more thread showing on the axle than should be. A closer inspection revealed the nut that holds the brake plate on wasn't tightening against the plate but tightening against the end of the thread. The plate was actually slightly loose when tightened again, not knowing these bikes this is something I wouldn't have realised was an issue.
Then someone made this point...
Triumph Manual
https://img.photobucket.com/albums/v295/chris-red/3_zpsc83e14f6.png
https://img.photobucket.com/albums/v295/chris-red/1_zps6fb44d80.png
BSA Manual
https://img.photobucket.com/albums/v295/chris-red/Capture_zpsa8933b77.png
https://img.photobucket.com/albums/v295/chris-red/2_zps190b8a6e.png
Yep Triumph fucked up the manual 50 something years ago. Whoever last built this hub we believe either didn't put the spacer, sorry "Distance Piece" in OR put it in the wrong side. Can't really blame them looking at the triumph manual
The width of this piece? 3/16" so the wheel doesn't need to move over 1/4" it needs to move over 3/16" Laughing
What was happening was I adjusted the shoes till they weren't dragging, but as the wheel was it pulling the brake off kilter this meant the shoes were hitting it at an angle making it drag a lot sooner than it engages. I was adjusting the shoes then adjusting the cable and treating it as 2 unrelated adjustments I was only checking rub when doing the shoes then adjusting the cable for a strong feel so it was rubbing all the time. Embarassed
I think think the Judder was because when I put the bike together that time I tightened the spindle before the brake.
Anyway we are just waiting for a tool to remove the axle to turn up so we can confirm this is the issue then it should resolve all the problems we had.
I'm so looking forward to getting this correct. It feels like Christmas. Laughing
PostPosted: 10:06 - 20 Feb 2015    Post subject: Reply with quote
B, E, A, U-tifull
https://img.photobucket.com/albums/v295/chris-red/8F3F4EB9-755B-4402-A759-C57B9FE511E8_zps3zkaawsk.jpg
https://img.photobucket.com/albums/v295/chris-red/974052A2-195A-457E-9F8F-D4C87842B2E9_zpslbheu3ip.jpg
https://img.photobucket.com/albums/v295/chris-red/75824C4F-103F-417C-A278-BF231554F8E6_zpsboy3vzk1.jpg
The spacer was on the wrong side. Put it together correctly and strangely it all went together fine Laughing
God knows how long it has been wrong. at least since he bought it.
PostPosted: 17:14 - 25 Feb 2015    Post subject: Reply with quote
Little bit more work has been done. Really do want to apologise about the picture situation, I start with the best of intentions of documenting everything but I take a few shots then forget when I get stuck into the job.
Noticed one of the forks seals had been gone so replaced them on Monday, however made a rookie mistake!
https://img.photobucket.com/albums/v295/chris-red/DSCF7820_zpsoocbse0g.jpg
I took the left (non leaking) leg out stripped the fork and rebuilt it other than a little bit of a struggle getting the old seal out it was a piece of cake. I then did the right leg, as you can see I only use precision tools on this bike. https://img.photobucket.com/albums/v295/chris-red/DSCF7821_zpsxcje0vtn.jpg
Fork in bits.
https://img.photobucket.com/albums/v295/chris-red/DSCF7823_zpsjij2ib6a.jpg
Having them both rebuilt I thought I'd clean the upper stantions before putting it back together, which at this point had remained covered by the gaitors. I remove the gaiter on the Left leg gave it a bit of a clean up, I noticed the chrome wasn't great and was lifting slightly ( think thats what it's called when it is still shiny but a different shiney) then bolted the leg back in. I then took the right leg out. I noticed there was a lot of orange muck I started cleaning and then realised it was fairly severe rust. Bummer.
https://img.photobucket.com/albums/v295/chris-red/5BEA0A12-4159-4C0D-90EB-A077AD89D577_zpsenm97sub.jpg
Thats why the fork seal had blown Rolling Eyes Rookie mistake not to check first. It was clear this rust had shredded the seal. I spoke with dad and we decided to put it back together as was. I cleaned the stantion fairly well using a scotch pad. This took the edges of the rust and didn't feel that bad. I took it for a test run and it didn't instantly blow the seal. Worst case scenario it blows and we've lost a £6.50 worth of seals and same again in oil. I'm under no illusions it will last, it's just another job for another day.
A pair of Stantions is £55! Fuck knows how they are so cheap!
https://www.thunderbirdspares.com/fork-stanchions-pair-triumphbsa-conical-hub--71-72-327-p.asp
Anyway while I have been doing more mechanical stuff, dad painted the Mudguard. Not a great job just a short term thing before he paints the lot. The paint applied to the the mudguard (like the rest of it) was crap on top of that the Zenner Diode had cracked the paint at some point previously when the forks had little oil in them. For him it was a quick job with alloy wheel paint but still I think it looks pretty good.
https://img.photobucket.com/albums/v295/chris-red/B691DF40-3343-48C9-A36C-06DEB88883AD_zpstr3usrbx.jpg
His next cosmetic task is the Shocks. They aren't bad but a couple hours and a tin of hammerite will make them look much better.
Also next on the agenda is converting the electrics to a modern reg/rec type set up and getting the correct choke cable.
I'll put pics of the crappy stantions up later. Thumbs Up
Edit:- I meant to say, on the test run it was the first time I had used the bike with the wheel in the right place and Pete's repaired brake lever. The front brake was so much better, it was a revelation, it can only get better to has I imagine the pads have to bed in again. The rear brake is much improved with the fixed brake lever although not in power but definitely in feel the old brake felt so spungey because of all the movement in the mechanism.
PostPosted: 17:48 - 24 Aug 2015    Post subject: Reply with quote
Little more on this,
Pete. has been a great help with various bits we have been chasing an oil leak for a while and pete helped repair the cam cover as the studs were glued in and it wasn't flat. With this fixed it started leaking oil from the rocker oil feed, long story short I hadn't done the bolts up tight enough there is no torque information in the manual and petrified of stripping threads or cracking the casing I didn't want to go too crazy with it. Asking on the triumph forum lead to being told they are 20lbft which is much less that I was doing. It seems excessively tight, however now there is ANOTHER leak from the other side of the engine somewhere.
Dad has done a fair chunk of miles on this bike since it was recommissioned. I'm not sure exactly how many but a few thousand. I've always felt it hasn't been running right, but without ever riding another it's hard to tell. We have checked the timing numerous times and it was bang on. It seemed to pink often and was a right pain.
Anyway saturday I arranged to meet Pete and the bike is running shite, coming over the Dartford bridge it was struggling to do 40 without pinking. On the flat it would hit about 50 It was really worried it was on it's last legs. When I arrived at the Pub I looked and there was oil EVERYWHERE. I was thinking the leak from the oils had starved the rockers or it had ran out of oil and it was gonna be fooked. Luckily when I checked it had /only/ lost 1/4 of a pint. Pete let me in his workshop and we annealed the washers came back and fitted them. On the way home the bike seemed to leak less and run better, untill it warmed up a bit then was back to being shit again.
Pete. had mentioned the valves, so I checked them 1 was correct, the others were as tight as they could be. Rolling Eyes
Not sure why this would be the case they were set when the bike was recommissioned and the service intervals says every 6k miles for valves. I believe this is a symptom of a leaded being used with leaded fuel, however we do have a receipt for unleaded head work. Anything else that could cause it?
Anyway with the valves set it runs so much better (funny that), I went out with my missus on the back. Bearing in mind the previous day it barely got me up a fairly shallow hill without pinking this time it pulled strongly with the pair of us on it, from like 2k rpm. Very Happy
Still it seems everytime we fix an issue another appears...
Fix one leak and we get another and now I think the petrol tank is leaking from where it bolts into the frame. Rolling Eyes
It's only weeping be still enough to be a pain. Any bodges (alredite/chemical metal) worth doing or should be go straight for welding?
In other news I found a matching rev counter and have fitted that.
Also she won a prize!
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/11953093_10153536563558476_3490484273779273858_n.jpg?oh=c10e43a40ed45e6ef73ea5a333eb2a96&oe=563F6881
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/11899991_10153536563473476_8619772761162583905_n.jpg?oh=843a05d9e37e60587074bd5c6b5eb3e2&oe=5636316D
Laughing Ok there wasn't a great deal of competition but still, A PRIZE! I think all the old boys just got nostalgic when I pulled up and the first thing I started doing was trying to stop an oil leak.
Next jobs chase the new oil leak(s) and sort the electrics, so you can use the lights for more than a mile...
Will get some better pictures when the weather is nicer.
The last post was made 8 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Page 4 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.52 - MySQL Queries: 17 - Page Size: 156.01 Kb
