low tech navigation aid wanted
thx1138
PostPosted: 19:22 - 07 Nov 2014    Post subject: low tech navigation aid wanted Reply with quote
Can anyone suggest a low tech solution instead of taking a Sat Nav or GPX gizmo?
I want some sort of waterproof paper, and permanent marker combo.
Planning a byways ride tomorrow, weather looks grim. My notes will probably get soggy as will my map, if it's not blown about. I know I could get a water proof OS map, but I have loads of maps and can't afford to change them all.
Would like a way to write notes on route on a sheet of plastic or something, that won't smudge or wash off, and is cheap and hardwaring. Don't need to clean it off, if I can throw it away, though recycling preferable.
Eddie Hitler
PostPosted: 19:26 - 07 Nov 2014    Post subject: Reply with quote
https://i.imgur.com/3EgoI2Ul.jpg
https://i.imgur.com/sRZ8GEbl.jpg
https://i.imgur.com/iTdpriG.jpg
https://i.imgur.com/mhjPcUSl.jpg
thx1138
PostPosted: 19:28 - 07 Nov 2014    Post subject: Reply with quote
yeah, always ends up wet and smudged in the end, though it's the best I can do for now is that
fords, UCRs on rivers, dropped in muddy puddles, crash it and it rips and the paper dissolves.
I've tried writing on the plastic folders themselves though, but don't stay on.
Northern Monkey
PostPosted: 19:40 - 07 Nov 2014    Post subject: Reply with quote
write in pencil, doesn't run when its wet
SQL
PostPosted: 19:57 - 07 Nov 2014    Post subject: Reply with quote
99p store: whiteboard, tape, permanent marker and alcohol hand gel.
£3.97
pepperami
PostPosted: 20:10 - 07 Nov 2014    Post subject: Re: low tech navigation aid wanted Reply with quote
thx1138 wrote:
Can anyone suggest a low tech solution instead of taking a Sat Nav or GPX gizmo? yadda yadda yak yak yak stuff about going out on the bike tomorrow.
Use a compass Thumbs Up
Or stay indoors and save you and your bike from getting wet and dirty Smile
Once again the great and wise Pepperami comes up with a helpful solution!
Wonko The Sane
PostPosted: 20:14 - 07 Nov 2014    Post subject: Reply with quote
if you're putting your bike through that then you could just get a chinagraph pencil and write on the tank,
bit of solvent (something like white spirt) should bring it right off again
thx1138
PostPosted: 20:25 - 07 Nov 2014    Post subject: Reply with quote
yeah could write on the tank I suppose Very Happy
I already have a compass Thumbs Up
,(and a pump, and tools, and waterproofs, and a camel pack, and food, and maps, and a first aid kit, and a puncture repair kit, and duct tape, and copper wire, and electric tape, super glue, WD40 a whistle and an emergency blanket, spare gloves, and a torch and a swiss army knife) Laughing all stuffed into this...
https://www.motolegends.com/accessories/bags/ogio-flight-vest-black.html Thumbs Up
white board sounds like an idea, might well try that, I'm hoping I've memorised tomorrows route, what could possibly go wrong? Mr. Green
PostPosted: 21:18 - 07 Nov 2014    Post subject: Re: low tech navigation aid wanted Reply with quote
Laminaters are cheap - I'd sometimes print off a relevant map/instructions and laminate it.
But then so are waterproof pouches for your phone, which solves a good few problems.
Neither may be practical for tomorrow - so permanent marker on a plastic sheet sounds reasonable Smile.
thx1138
PostPosted: 21:38 - 07 Nov 2014    Post subject: Reply with quote
yeah as for my phone, that goes inside two zip lock freezer bags, and is tucked away
it really just hadn't even occurred to me to buy a laminator, that might just be the answer, top of the Christmas present list Thumbs Up
PostPosted: 21:44 - 07 Nov 2014    Post subject: Reply with quote
With a proper bag you can have it on your yolks or similar and still use it.
mentalboy
PostPosted: 21:46 - 07 Nov 2014    Post subject: Reply with quote
I find it easier to write the instructions down and commit them to memory (but I do stash the hardcopy in the topbox just in case!)
Make mine a Corona.
Fladdem
PostPosted: 21:59 - 07 Nov 2014    Post subject: Reply with quote
I normally use the clear plastic wallet gaffa taped to the bar pad and gaffa'd up. But, like you, if some wind can get in, it just blows the back end out and the paper gets ruined so I was looking for a better of bodging something on.
Although I like having to pull over and inspect maps and try to work out where I am.
ScaredyCat
PostPosted: 00:46 - 08 Nov 2014    Post subject: Reply with quote
Just follow whatever is in front of you...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 01:18 - 08 Nov 2014    Post subject: Reply with quote
Chinagraph washes off. I've tried it.
Bit of cardboard in a sandwich bag works ok.
Barnoe
PostPosted: 01:26 - 08 Nov 2014    Post subject: Reply with quote
Buy a tank bag with clear window on top, put your smartphone in it with a free satnav app on Smile
Thank me later Very Happy
You know you are old when you're told to slow down by your doctor and not the police.
kramdra
PostPosted: 02:30 - 08 Nov 2014    Post subject: Reply with quote
Use a compass or use nearby places/signposts as a reference. Know a rough estimate of the distance and direction.
Or follow someone that looks like they know where they are going. Laughing
PostPosted: 22:00 - 08 Nov 2014    Post subject: Reply with quote
https://cache1.asset-cache.net/gc/114218700-woman-giving-directions-to-man-in-car-gettyimages.jpg?v=1&c=IWSAsset&k=2&d=epq4ozCYYy%2BJ0Hxr51tBGWO%2FURmwye2Ov4s%2B8nny88A%3D
Might only work if you're a 7' male model asking directions from a 6' female model, mind.
i.p.phrealy
PostPosted: 22:10 - 08 Nov 2014    Post subject: Reply with quote
camping shops sell waterproof map holders.
many will be open in the morning.
The last post was made 11 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 104.13 Kb
