3 Bolt Silencer to Slip On
KD88
PostPosted: 18:26 - 28 Nov 2014    Post subject: 3 Bolt Silencer to Slip On Reply with quote
Is there much work involved in changing from a three bolt silencer to a slip on with link pipe?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:19 - 28 Nov 2014    Post subject: Re: 3 Bolt Silencer to Slip On Reply with quote
You will have to undo at least 3 bolts...
Triumph Sprint ST 1050
Minty
PostPosted: 22:21 - 28 Nov 2014    Post subject: Reply with quote
I did mine, cut with angle grinder and use a 52mm slip on with exhaust clamp.
My fingers smell of your mum.
KD88
PostPosted: 22:27 - 28 Nov 2014    Post subject: Re: 3 Bolt Silencer to Slip On Reply with quote
Really? Who'd have guessed?
Thanks Minty, presumably I use the link pipe to judge where to cut?
PostPosted: 10:00 - 29 Nov 2014    Post subject: Re: 3 Bolt Silencer to Slip On Reply with quote
If it's a Hyosung, you will have to drill out at least 3 bolts.
I mention this to illustrate that taking 10 seconds to specify make and model can be a good investment.
KD88
PostPosted: 12:43 - 29 Nov 2014    Post subject: Reply with quote
2000 Kawasaki ZX6R J1
Minty
PostPosted: 17:06 - 29 Nov 2014    Post subject: Reply with quote
I put the can I had bought into it's clamp and when it was in the position I liked, draw a line on the pipe with a sharpie (was able to push it the couple of inches to the side that was needed.
Then added around an inch extra past the sharpie line to slip into the exhaust. Was really no bother at all.
Reminds me, whatever happened to Craigs23? T'was him I bought the can off? Maybe he polished himself into a coma??
PostPosted: 09:38 - 30 Nov 2014    Post subject: Reply with quote
Overcome by T-Cut fumes in the garage.
The last post was made 11 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.29 - MySQL Queries: 16 - Page Size: 63.34 Kb
