A question about infinity for mathsy/sciencey people.
c_dug
PostPosted: 22:31 - 12 Jan 2015    Post subject: A question about infinity for mathsy/sciencey people. Reply with quote
During my commute home tonight while filtering through endless miles of traffic down the A13 a thought got stuck in my mind.
If there are a hypothetical infinite amount of universes then it follows that I am in an infinite amount of them (because infinity?). Surely it also follows that there are an infinite amount that I am not in.
Is one infinity bigger than the other? Is that even possible? It seems to me that there must be more universes without me in them at all than there are with me in, but if both are infinity how does that even work?
_Will_
PostPosted: 22:51 - 12 Jan 2015    Post subject: Reply with quote
I'm sure you mean realities? Which are hypothesised as being infinite. As there is one Universe, the totality of space and time.
Suffering Bike Withdrawal.
c_dug
PostPosted: 23:07 - 12 Jan 2015    Post subject: Reply with quote
Whatever the wording, the sentiment is the same no?
mentalboy
PostPosted: 23:13 - 12 Jan 2015    Post subject: Reply with quote
Infinity is infinity is infinity.
If you limit your parameters then yes you may well appear to be proportionally in fewer realities than you are not but the probability is that if you've had a blow job in reality then you've had an infinite amount of blowjobs if you factor in other realities (so who cares about the ones you're not in Laughing )
Make mine a Corona.
noobRider
PostPosted: 05:34 - 13 Jan 2015    Post subject: Reply with quote
I'm not a maths person but while infinity is infinity, some infinities can be larger than others, e.g.
As German mathematician Georg Cantor demonstrated in the late 19th century, there exists a variety of infinities—and some are simply larger than others.
Take, for instance, the so-called natural numbers: 1, 2, 3 and so on. These numbers are unbounded, and so the collection, or set, of all the natural numbers is infinite in size. But just how infinite is it? Cantor used an elegant argument to show that the naturals, although infinitely numerous, are actually less numerous than another common family of numbers, the "reals." (This set comprises all numbers that can be represented as a decimal, even if that decimal representation is infinite in length. Hence, 27 is a real number, as is π, or 3.14159….)
In fact, Cantor showed, there are more real numbers packed in between zero and one than there are numbers in the entire range of naturals.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
trevor saxe-coburg-gotha
PostPosted: 06:29 - 13 Jan 2015    Post subject: Reply with quote
Yeah - fuck words. We'll just use psi-power to access your sentiments.
yen_powell
PostPosted: 06:46 - 13 Jan 2015    Post subject: Re: A question about infinity for mathsy/sciencey people. Reply with quote
You just pay attention and watch where you're going!
XT1200Z and a DR350 in bits
weasley
PostPosted: 07:32 - 13 Jan 2015    Post subject: Reply with quote
Infinity is a mind-fuck. Here's one for you:
How many radii are there in a circle? Answer: an infinite number.
OK, so how many radii are there in a sphere? The same number?
daemonoid
PostPosted: 07:34 - 13 Jan 2015    Post subject: Reply with quote
Cardinal it's of infinity is what you're looking for, noob appears to have a section of it.
Basically, infinities can be of different sizes - countable infinities or uncountable infinities. The two infinities you describe are the same size and are considered countable - you could use an integer to represent every single one of them.
Your infinities and integers are the same size... And, this is where it may sound odd, but they are the same size as an infinity of rational numbers (anything that can be represented as a fraction).
This pic may illustrate why...
https://divisbyzero.files.wordpress.com/2013/04/screen-shot-2013-04-16-at-9-23-14-pm.png
The red line shows a clear path through the list of rational numbers, at each step you can label the rational (give it a position... 1st, 2nd, 3rd...299th...). Because you have infinite integers you can always label any new number added to that table, thus they are countable.
Real numbers (which include irrationals like pi) are not, however, countable. You cannot even begin to draw the table - there will always be infinite values between 0 and the first value you choose.
<edit> watch this instead - https://youtu.be/fRhdpyaOhEo
current: ducati monster 750
PostPosted: 08:13 - 13 Jan 2015    Post subject: Reply with quote
An infinite number of you are getting blowjobs right now.
However, in a sample of 1000 of your cocks, only one of them is getting sucked right now.
That's how textbooks should explain it.
PostPosted: 08:24 - 13 Jan 2015    Post subject: Reply with quote
Eventually it will be the one I am using to type this with?
Hopefully.
orac
PostPosted: 09:16 - 13 Jan 2015    Post subject: Reply with quote
Infinite isn't really a thing, it's simply a term used for something indescribably large to a point where a number can not illustrate whatever it is. Alot of things are described as infinite due to unknown properties. We already know the universe to our perception is not infinite
PostPosted: 09:40 - 13 Jan 2015    Post subject: Reply with quote
Yeah but do we? I mean, if the universe is continuously expanding surely we can't know whether the energy it uses in this expansion is finite or infinite? Also, what about the "space" it is expanding into - that might be infinite as well, mightn't it?
Please don't destroy my entire mind if/when replying to this as I am hopelessly stuck in a very crude newtonian thang and can't deal with other more hardcore stuff.
Taught2BCauti...
PostPosted: 09:46 - 13 Jan 2015    Post subject: Reply with quote
I read somewhere, that current thinking is that there are many 'universes' out there, because the galaxies at the furthest reaches of our own universe, are showing signs of being deflected, and it was illustrated as being similar to what happens when several soap bubbles come together.
https://phys.org/news/2010-12-scientists-evidence-universes.html
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
daemonoid
PostPosted: 10:40 - 13 Jan 2015    Post subject: Reply with quote
Infinite is a thing. It is a mathematical concept. If something is large, but has an end then it is not infinite... Your description implies that numbers have a finite usability... They do not.
If something cannot conceivably be counted or measured, it is not merely large it has no end.
Whether anything in reality is infinite is a different question.
PostPosted: 10:55 - 13 Jan 2015    Post subject: Reply with quote
You aren't understanding infinity, it is a concept not a number.
∞+1 = ∞
∞x2 = ∞
∞x∞ = ∞
pdg
PostPosted: 11:47 - 13 Jan 2015    Post subject: Reply with quote
If you can count it, I can add 1 to what you have counted. Ergo, it is not infinite...
Basically, if you can comprehend the end of something it is finite.
As for infinity+1, you cannot add something to something that has no end. You might be able to stick it in the middle somewhere though.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 12:59 - 13 Jan 2015    Post subject: Reply with quote
∞+1 = ∞
But ∞+1 > ∞ if you're into hyperreality.
PostPosted: 13:37 - 13 Jan 2015    Post subject: Reply with quote
There was a brilliant quote I read about infinity and understanding the scale of it. I can't remember who it was by and I am going to reproduce it far less elegantly.
Imagine a steel sphere the size of the earth, and then imagine that a fly lands on this sphere once every million years. The sphere will ware away into nothingness before you get anywhere close to infinity.
PostPosted: 14:09 - 13 Jan 2015    Post subject: Reply with quote
But wouldn't the fly just die after a few weeks? Or is this different flies?
daemonoid
PostPosted: 14:35 - 13 Jan 2015    Post subject: Reply with quote
May I suggest you quit your jibber jabber...
https://lmgtfy.com/?q=Countable+infinity
A countable infinity is one that can map directly onto the infinite set of integers. I'm sure you'll get it once you've read a bit more...
PostPosted: 14:55 - 13 Jan 2015    Post subject: Reply with quote
Different flies, it destroy the sphere because it evolves over those years into a metal stomping monster.
The Wobbly Orange
PostPosted: 15:03 - 13 Jan 2015    Post subject: Reply with quote
My girlfriend put the Hollyoaks omnibus on the TV, pretty sure that lasts for infinity.
People tell me I am lovely. How wrong they are!
Gazz
PostPosted: 15:11 - 13 Jan 2015    Post subject: Re: A question about infinity for mathsy/sciencey people. Reply with quote
Don't drink and ride.
Chinaboy
PostPosted: 15:19 - 13 Jan 2015    Post subject: Reply with quote
Are we saying it wears away because the flies stomp on it or is the steel going to corrode and rust away because the flies have sticky sweaty feet? Furthermore, where the fuck are these flies coming from? and who chooses the lucky bugger to get sent to the steel world? Confused Question
The last post was made 11 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 144.86 Kb
