| Dave70 |
 Dave70 World Chat Champion
 Posted: 13:08 - 15 Jan 2015 Post subject: Something's slipping. Any Ideas/Suggestions? |
Over the past couple of months, usually when travelling at 60+mph, I've felt as though something has slipped on the bike. It feels like it's something connected to the rear wheel.
Initially I thought that maybe the chain was slack but, it is absolutely fine. The sprockets look fine too and they were replaced less than 5,000 miles ago and were a decent quality branded set.
The "slip" only lasts a split second and it doesn't always happen, just now and then. It's probably something simple but, I'm not at all up to speed with the mechanical side of things, so any ideas would be helpful. I've heard of something called clutch slip but, I have no idea what the tell tale signs of that is, all I can say is that apart from this issue, everything else appears fine. Would the clutch slipping do this?
The bike is a R125 and has been well maintained and looked after since new and has done around 28,000 miles. ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| stinkwheel |
 Posted: 13:18 - 15 Jan 2015 Post subject: |
The only two things that CAN slip are the clutch or the back tyre. Everything else is rigidly attached together.
I doubt it's spinning up the rear wheel so you're left with clutch slip where the sandwich of metal and cork plates, held together with springs, that transmit the power from the engine to the gearbox aren't gripping together properly.
Can be because they are broken, worn, glazed or that the springs have lost some of their springiness. The only way to find out which is to dismantle the clutch. That's not a huge job but does involve draining the oil and removing one of the engine side-covers.
The friction clutch-plates and springs are a wearable componant and are relatively inexpensive to replace.
Check your clutch cable is correctly adjusted for free-play first though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dave70 |
 Posted: 13:31 - 15 Jan 2015 Post subject: |
Thanks for the replies.
I'll give snoos tip a try first and see what happens.
As for taking things apart, although it's not a big job as such, I only have the back alley way to work on my bike, so will probably let someone who knows what they're doing have a look and do the job, as I wouldn't know what to look for as such, even with stinkwheels very helpful description. ____________________ There ain't no devil, there's just god when he's drunk.
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 14:15 - 15 Jan 2015 Post subject: |
If it is clutch slip, but doesn't happen all the time, can you get it to happen by gently squeezing the clutch lever gradually as you are riding normally?
Does it feel the same?
The only other thing I can think of in the drive train, is the Cush Drive Rubbers, but not sure what you might feel if they are shot. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Dave70 |
| Aff |
 Aff World Chat Champion
| Dave70 |
| Vincent |
 Vincent Banned
| el_oso |
 el_oso World Chat Champion
The last post was made 11 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
