Honda CD/Cb?????
keithm
PostPosted: 19:57 - 17 Jan 2015    Post subject: Honda CD/Cb????? Reply with quote
Hello
just purchased a 1984 Honda CD125 twin. Can anyone tell me the difference between a CD/CB?
many thanks
keith
nighthawk250
PostPosted: 20:28 - 17 Jan 2015    Post subject: Reply with quote
The CD models are commuter single carb models, the CB's are the more sporty models, twin carbs and better exhausts, better brakes, better instruments.
keithm
PostPosted: 20:31 - 17 Jan 2015    Post subject: Reply with quote
thanks for your reply
so parts are swapable?
thanks keith
moonzoomer
PostPosted: 11:26 - 18 Jan 2015    Post subject: Reply with quote
Most of the cycle parts will change though the engines on the CD tend to have 360 cranks with the CB models having 180 cranks, the wiring looms in respect to the ignition circuit will also be different between CB and CD.
Teflon-Mike
tl;dr
PostPosted: 18:37 - 18 Jan 2015    Post subject: Reply with quote
CD125 Benley Has Twin-Shock rear suspension; the CB125 has Mono-Shock rear suspension; CD has 17" wheels; CB 18" wheels; CD has drum brakes; CB has disc front, ad the list goes on....
Easier for me to list the bits that they share.... that will be; crank-cases; cylinder barel; cylinder head bare casting and valves, the cam-chain and cam-chain tensioner....
The crank in the Benly has 360 'Timing'; both pistons' up and down together; CB has 180 crank; one piston up, one down; which means that the cam-timing also has to be different; so dfferet cams; also different ignitions to give different spark timing; so a lot of electrical differences; The CB125 has a rev counter, so the oil-pump is different having an open casing to allow the rev counter drive to be taken off the end; CB motor can rev to 14K, and drives 18" wheel, so the gear ratios are all different in the gearbox, as Benly revs to nadge over 10K and turns a 17" wheel.. Rocker covers are different, carbs are different, air-boxes are different, exhausts are different, err... NOT much is the same.... tappet adjuster screws have the same part umber if that helps?
SO... they have very different chassis, with little interchangeability, except perhaps the odd light bulb or perhaps handle-bar grips; the engines are of the same basic design, based on the same crank casings, but internally, totally different designs; with again, little 'direct' interchangeability. To all extents and purposes they are completely different motorcycles.
B-U-T..its all pretty much in the Haynes Manual for the model.. And why are you interested?
CaNsA
PostPosted: 18:41 - 18 Jan 2015    Post subject: Reply with quote
Ignore Teflon-Mike because...
Teflon-Mike wrote:
360 Deg... Five 1/4 turns.
keithm
PostPosted: 18:43 - 18 Jan 2015    Post subject: Reply with quote
Thanks for the information. Was wondering about parts as the CD125 parts is hard to come by, having said that i've pretty much sourced all the parts I need to build a cafe racer.
thanks
pdg
PostPosted: 18:44 - 18 Jan 2015    Post subject: Reply with quote
There is no substitute for accuracy...
https://databikes.com/imgs/a/b/h/h/z/honda__cb_125_t2_1984_1_lgw.jpg
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Fisty
PostPosted: 18:47 - 18 Jan 2015    Post subject: Reply with quote
Holy fuck and I thought his last post was potato.
Fatter and faster than Fret
moonzoomer
PostPosted: 20:21 - 18 Jan 2015    Post subject: Reply with quote
The 1984 CB125 uses a mono shock.
pdg
PostPosted: 21:07 - 18 Jan 2015    Post subject: Reply with quote
moonzoomer wrote:
Yes, because I drew that picture of a 1984 CB125 with crayons.
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
pdg
PostPosted: 21:15 - 18 Jan 2015    Post subject: Reply with quote
Now of course, someone is going to have to specify which CB125 they are talking about.............
1984 was a strange year for honda, what with having monoshock and twinshock subversions of the same model designation in circulation, they even continued the twinshock version into at least 1986 and later in some markets.
But hey, what would I know about honda? It's not even as if I like these far eastern tinpot excuses for a machine.
The last post was made 11 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.23 - MySQL Queries: 16 - Page Size: 82.06 Kb
