Alfa 147
Irezumi aka Reuben
Carrot Top
PostPosted: 19:56 - 19 Jan 2015    Post subject: Alfa 147 Reply with quote
Considering getting a car again and wondering why these are so cheap?
Are they particularly bad or just unwanted?
What in particular goes wrong with them/whats to look for? Any other suggestions for interesting hatchbacks?
Thanks for any help.
Pictorgraphicalfantastical
RhynoCZ
PostPosted: 20:11 - 19 Jan 2015    Post subject: Reply with quote
Because they are crap. Smile
BenR
PostPosted: 20:15 - 19 Jan 2015    Post subject: Re: Alfa 147 Reply with quote
Because they're shit! Seriously when I used to do bodywork for an Alfa agent I took the door card off of a 3door & all the wiring just fell out, it hadn't been clipped up at the factory. Iirc it was only a year & a half old & had rust coming through on the tailgate where they had fitted the rear spoiler badly at the factory. Shocked Engines a generally reliable so long as the maintenance is kept up some of the petrols have a tendency to burn oil. The V6 variants are awesome but cost loads to run & maintain especially coil packs. The diesels are excellent but then they are fiat engines so should be good. If you test drive one & the biting point on the clutch is high it usually means it needs a new clutch which won't be cheap. Generally more expensive but not as well put together as a fiat stilo & with less kit to boot. Personally I'd go for the stilo 3door JTD multi-jet. 150bhp & 230ft/lbs torque & with a lot of kit. You'll probably get a good/low mileage one for around £1000-1500 now. Either that or save up a bit more & get a VAG diesel. Thumbs Up
andys675
PostPosted: 20:46 - 19 Jan 2015    Post subject: Reply with quote
work mate had one back in 2005 I think
don't remember exact problems but she had them all listed and new what to expect, one was definitely suspension creaking, she got the stuff it did suffer from fixed under warranty and then goodwill fixed enough of it for her to get shot of it after the finance was paid
PostPosted: 20:53 - 19 Jan 2015    Post subject: Reply with quote
I would happily go for one.
Main mechanical issue is front suspension arms. These wear out but are cheap and easy to change (good day, half an hour each upper arm).
With the petrol engines the main issue is the cam belts. Meant to be changed at 36k, and not a simple / cheap job.
Don't really know about those with engines powered by the fuel of satan.
Nash GT
PostPosted: 01:17 - 20 Jan 2015    Post subject: Reply with quote
They also used to suffer from horrific gearbox problems, specially the ones fitted with the dreadful selespeed box.
I had the pleasure of the aforementioned gearbox in a 156
It kept forever breaking and producing exorbitant bills
Suzuki GSF600N
Irezumi aka Reuben
Carrot Top
PostPosted: 12:38 - 20 Jan 2015    Post subject: Reply with quote
Thanks for the information. Was more interested in the 5dr than 3dr version but good option there BenR.
I'm not looking for an amazingly good car handling or performance wise. Just something a bit more interesting than the standard. Will look more in to the Alfa's as they seem even cheaper than the FIAT's!
All work will be done by myself so the cambelt issue is a bit worrying.
Nash GT
PostPosted: 18:02 - 20 Jan 2015    Post subject: Reply with quote
156 manual is better option IMO
Suzuki GSF600N
Iain.
PostPosted: 18:36 - 20 Jan 2015    Post subject: Reply with quote
Modern diesels are great! You gotta try driving some Wink Thumbs Up
Robby
Dirty Old Man
PostPosted: 19:39 - 20 Jan 2015    Post subject: Reply with quote
My father in law had a 147 for about 5 years, 1.6 petrol. For the most part it was a normal hatchback experience. A little less reliable, a little more fun. He bought another Alfa afterwards.
Mr Nice Guy
PostPosted: 20:51 - 20 Jan 2015    Post subject: Reply with quote
My brother had a 156 1.8, lots of problems but the biggie was when the plastic impellor on the water pump shat its guts, meltdown, cost about £1800 to fix.
Suzuki GSX-R750K4 ~ Mivv GP
Rockhopper
PostPosted: 23:52 - 20 Jan 2015    Post subject: Reply with quote
It's well known that you should change the water pump when you do the cam belt- £350 all in, not a difficult job. Cam belt on a V6 is a different story! A good used engine can be had for £300 so your bro had his pants pulled down on that one I'm afraid.
147 had a galvanised body so no rust issues, the 156 didn't and they suffer rotting floor pans
No common gearbox problems apart from Selespeed issues which are usually caused by mechanics who don't understand them.
Suspension creaks are common but easy and fairly cheap to fix.
Five door 147's are more desirable hence more expensive.
I've had a 1.8 156, a 1.6 147 and I've currently got a 155hp 1.4 MiTo (awesome car!).
PostPosted: 00:39 - 21 Jan 2015    Post subject: Reply with quote
The Selespeed actual gearbox is virtually identical to the normal manual box and is pretty reliable. The problems tend to be the actuator units.
Last diesel I had the displeasure of driving was a fairly recent Golf. Bloody awful thing to drive. One before that was an Alfa Mito which was nothing special at all, and one before that was a BMW 330D, which while OK, for driving pleasure wasn't a patch on a vaguely competent petrol engine.
Anything with torque at low revs which then just tails off just feels like you are being punished for using the gears.
Mr Nice Guy
PostPosted: 01:45 - 21 Jan 2015    Post subject: Reply with quote
Assumptions galore Laughing
The car was new, by new I don't mean new, but, not an old bag of shit (that you would chuck a 2nd hand engine in), say 4 years old, twas 99/00 reg in 2003/4 so maybe 5 max. Out of warranty luckily, and low miles was sub-40k if I mind right. Replacement engines weren't £300 at that point, like they may be now.
Anyhow, was a nice car to look at, but nothing special to drive.
Annabella
Like a person, only smaller
PostPosted: 08:31 - 21 Jan 2015    Post subject: Reply with quote
I'm with Keith on this one.
Be prepared to do a good full service on it once you've bought it - by that, I mean cam belt, water pump, oil and filter and check suspension over. Front arms are cheap to replace.
Find yourself a good independent Alfa specialist and the cambelt and water pump job shouldn't be much more than £300 all in. I'd usually change belts on any second hand car I've bought unless I knew they had been recently changed by someone I trusted.
My mum had a selespeed 156 which had intergalactic miles on it (>200k). Was an absolutely brilliant car. Paid £1000 for it, and absolutely nothing ever went wrong with it - genuinely nothing (despite Mum driving like the Stig everywhere) until she neglected to check the coolant levels Sad
Now on my second Alfa, Mum and Dad own two and *touch wood* they have been as reliable as the MX5. Like any car, they just need love and some understanding. If you're the kind of person who cannot deal with 'niggles' (like the rear windows dropping for no apparent reason - my 146; or the alarm going off whilst driving - the GTV) then don't go near, it'll irritate you. If you think that sort of behaviour is endearing, then you'll love every second of Alfa ownership.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Annabella
PostPosted: 08:35 - 21 Jan 2015    Post subject: Reply with quote
As a result of this happening most independent specialists will always change the water pump and impeller as part of a cambelt change, and the common 'upgrade' is to use the V6 metal impeller which has less of a tendency to disintegrate.
These cars are at an age now that if they have been looked after most issues (like the water pump impeller being made of cheese) will have been fixed. Look out for one that's been looked after by an independent specialist, that's had the cambelt changed and the water pump at the same time and you'll probably find it's a good'un. Especially if you *can* buy local and take it back to the same garage.
1198
PostPosted: 08:47 - 21 Jan 2015    Post subject: Reply with quote
It's not a better or worse way to drive, it's just different, and you need to grow used to it.
For my driving (up and down the motorways, all top gear stuff,) I'll lhappily trade a bit of supposed driving pleasure for decent mpg and mid range.
On topic, I had a 147 and it was brilliant. It handled well, went well and was a lovely place to be in. I must say that while I had no problems with it it wasn't old - 24 months or so.
Oh, and the speedo and Rev counter are not visible to the passenger....
Nash GT
PostPosted: 11:13 - 21 Jan 2015    Post subject: Reply with quote
Agreed the actuator was the culprit time and time again, seemed like it was made of cheese and patched up with chocolate
Suzuki GSF600N
Irezumi aka Reuben
Carrot Top
PostPosted: 13:04 - 21 Jan 2015    Post subject: Reply with quote
Thanks for all the advice. Still getting shocking insurance quotes on them (but that applies to any car) thanks to living in London.
As for liking niggles, I ride an old Aprilia so not an issue dealing with that!
Good to see some of the older member have come out of the woodwork for this topic! Very Happy
PostPosted: 20:20 - 21 Jan 2015    Post subject: Reply with quote
I am afraid that kind of power delivery I hate. I have no more wish to grow used to it than I have a wish to grow used to the smell of a sewage works. A normal car petrol engine is limited enough in the rpm its torque keeps increasing to.
arry
PostPosted: 20:30 - 21 Jan 2015    Post subject: Reply with quote
VW TDi engines have same design, same failure point, same sort of costs too Laughing
b422063
PostPosted: 00:04 - 22 Jan 2015    Post subject: Reply with quote
Had the 3.2 V6 as a company car in 2005. Was brand new and only had a few gremlins. Engine management light came on for apparently no reason but was always a very quick fix by the dealer. GPS unit often failed to find any satellites too.
It felt like one of the quickest cars I've ever owned. Handled quite well too, but I've a feeling that was due to it's size, I've had bigger cars since. My biggest thing against it was the gearbox, it often missed gears, as rare as it is to happen in cars, this car did it frequently. I'd expect and look out for worn gearboxes in case you get my old car Laughing
Tiff
PostPosted: 00:43 - 22 Jan 2015    Post subject: Reply with quote
Alfa's (and Fiat's for that matter) are fantastic cars, if looked after the way they should be by someone who understands them. I've owned many, and never had any real failures and never ever broken down, even taking my 400 quid 145 Cloverleaf to Berlin and back, driving it like an Italian.
Cambelts are easy to do, if you have the correct tools, which can be supplied by a specialist for not a lot of money. Good quality lubricants and proper regular servicing is key. In fact the main issues with later Alfa's were mostly electrical niggles, caused by Bosch...
Plenty information,specialists, an excellent club forum and parts suppliers are out there. Only buy an Alfa if you REALLY want an Alfa, not just because it's cheap and different, and only buy from an Alfa enthusiast who will have all the keys,kefobs,service and handbooks,locking wheelnut keys,owners club badge and t-shirt. These cars need and thrive on love.
I started with a Gulietta 2.0 RS at 18, then a 146 Boxer,then a 146 Cloverleaf,followed by 2 GTV's. Fiat Coupe 2.0 20v, Lancia HPE and I'm currently on my 16th X1/9.
P.S Diesels are OK- I dislike Diesel as well but they are fine, same lumps that Vauxhall use- just finished a 147 JTD 16v at work which snapped a belt. Some new rockers,a water pump and a belt kit and it's right as rain. Pleasure to work on to, even though it was over 150,000 miles.
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
The last post was made 11 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 132.82 Kb
