| iginge |
 iginge Nova Slayer
 Posted: 15:08 - 30 Jan 2015 Post subject: 1st Chain Clean + Lube (Look Ok)? |
Hi all,
I'll cut straight to the chase.. after a service yesterday I looked at my chain and couldn't see any difference (didn't look like it had been cleaned and lubed), could of been because the roads where in such poor condition that between the long distance home it had basically picked up muck again.
Decided to use chain cleaner and lube that I purchased a little while ago for the first time (usually leave it to the garage or a service).. simple job, there are spots of rust I appreciate just because it was neglected for a short while.
Just wondered if it looked ok to anyone and everyone?
https://s15.postimg.org/ouibo05u3/IMG_2331.jpg
https://s2.postimg.org/77nu1saxl/IMG_2332.jpg |
| doggone |
 doggone World Chat Champion
| iginge |
 iginge Nova Slayer
| doggone |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 16:32 - 30 Jan 2015 Post subject: |
Get ready for your jacket to get sprayed with the chain lube. This is not enduro nor motocross, you do not need so much lube on the chain. On dry road, it'll only bind dust and spray everything.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| iginge |
 iginge Nova Slayer
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| iginge |
 iginge Nova Slayer
| Commuter_Tim |
| DottyDuck |
 DottyDuck Nearly there...
 Posted: 22:50 - 30 Jan 2015 Post subject: |
if you have any cereal boxes or newspaper in the recycling bin just slide it between the wheel and swing arm... protects the tyres and an easy clean up of chucking it in the bin.
 ____________________ CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14
Old Bike: Zontes Panther 125cc - wrote off Current Bike: Kawasaki ZR7  |
| DottyDuck |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
 Posted: 09:36 - 31 Jan 2015 Post subject: Re: 1st Chain Clean + Lube (Look Ok)? |
I personally don't like the look of that chain, in that it appears too worn. But it's impossible to know just by looking at it. To be certain would involve checking for tight spots, and feeling how well the links flex. I could well imagine, from the photos, there being numerous places along that chain where the rollers are ailing and the inner plates are grinding against outers because grit, crud and rust has built up too much. A decent service would've noticed that though, so eh. Who knows. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| iginge |
 iginge Nova Slayer
| wr6133 |
 wr6133 World Chat Champion
| iginge |
 iginge Nova Slayer
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| iginge |
 iginge Nova Slayer
 Posted: 16:06 - 31 Jan 2015 Post subject: |
Yeah well WD is okay, but paraffin or diesel is a bit better. Also, this is far more use than a toothbrush:
https://static.rapidonline.com/catalogueimages/Module/M306010P01WL.jpg
Fiver or less. Cleans two or three sides at once. Then grab the chain w/ some kitchen roll and turn the wheel so that the chain passes through. Repeat until only a small amount of black is showing on the kitchen roll. Then lubricate w/ e.g. EP90 (thick gear oil). If you're afraid of fling, wipe chain w/ clean rag. Ideally, you should do this after every ride, but failing that - and assuming 10-15 miles a day on dry roads - once or twice a week. But chains can suffer quickly from the shite accumulated from wet winter roads. And bear in mind too, if you think the regimen I mention is too strict, a well-maintained chain will make for *much* smoother gear changes, will last A LOT longer than a poorly cared for one, and - in some cases - could be worth as much as a couple of extra bhp (probably not on a 4t 125, mind you - but still, extra friction caused by a shitty chain will definitely have a detrimental effect on power output).
One last thing - ideally the CBT should cover basic maintenance beyond POWDER checks (although of course that's where "D" comes in - the idea is that you go home and e.g. search youtube for motorbike chain maintenance), but this would just mean bombarding the n00b with YET MORE info. The list of stuff you have to absorb in minutes on the cbt is already fairly colossal. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
| iginge |
 iginge Nova Slayer
| Wull |
 Wull Crazy Courier
| kramdra |
 kramdra World Chat Champion
| Mark65 |
 Mark65 World Chat Champion
| devojunior |
 devojunior Brolly Dolly
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
