2nd hand cams?
0l0dom0l0
PostPosted: 12:20 - 05 Feb 2015    Post subject: 2nd hand cams? Reply with quote
For shits and giggles I'm looking at dropping some R6 cams into my FZ6.
Got some bloke on another forum saying that I need new buckets as the cams and buckets work harden as a pair.
Never heard of this before.
What's the cack with using second hand cams and mixing and matching this stuff?? Anyone ever had any issues?
davebike
PostPosted: 12:24 - 05 Feb 2015    Post subject: Reply with quote
I would not worry about the buckets
You will need to re shim
You may need a power commander and dyno runs different cams will mess up the fueling but it may still be in range of the closed loop
map
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Matt B
PostPosted: 12:35 - 05 Feb 2015    Post subject: Reply with quote
Just wondering what you want to achieve by doing this?
PostPosted: 12:43 - 05 Feb 2015    Post subject: Reply with quote
Once upon a time it might have caused some problems but Japanese build tolerances are now so good you can even buy a single cam cap*. I doubt there would be any need to replace buckets.
I'd suggest if your cam lobes/buckets are wearing appreciably, you have bigger problems.
I swapped out the cams on my VFR for a set of second hand ones of a different spec model four years apart and had to buy TWO new shims (out of 16).
I wonder if what he was meaning/heard was you should ordinarily try to keep the same bucket and shim in the same place on the head if you want to avoid having to re-jiggle the shims every time you have the head off due to small variations in thickness? You'll have to re-shim it anyway if you're swapping out the cams (or maybe not if you're lucky?)
*It used to be that they were through-drilled in place on the head and if you cracked a cam cap, your whole head was scrap. Now they are well enough made you can just replace one.
Nexus Icon
PostPosted: 14:35 - 05 Feb 2015    Post subject: Re: 2nd hand cams? Reply with quote
I bet a pound coin to a pinch of shit that he's in his 50's or older. That used to be the case but not any more.
Edit: I see Stinkwheel has already said as much. Carry on.
Greetings from Shitsville!
0l0dom0l0
PostPosted: 15:38 - 05 Feb 2015    Post subject: Reply with quote
That's fine he sounds like he's a bit old fashioned. I think he was referring to the days when he used to race American V8's lol.
Got a power commander and only doing it as a hopefully cheap and effective mod to get a few more Hp.
Thanks for the replies!
PostPosted: 16:00 - 05 Feb 2015    Post subject: Reply with quote
Is your Fazer the Ally framed one, or the steel framed one?
Matt B
PostPosted: 18:16 - 05 Feb 2015    Post subject: Reply with quote
2002 would be the tubular steel frame jobbie, so (unless I'm mistaken) that's the old Thundercat engine, not the R6 derivative?
PostPosted: 18:38 - 05 Feb 2015    Post subject: Reply with quote
That's what I'm getting at. R6 cams will not fit the Thundercat engined derivative. Thundercat cams are the same as Fazer cams IIRC.
Carvel
PostPosted: 21:26 - 05 Feb 2015    Post subject: Reply with quote
It says 'FZ6' in the first post.
Big giveaway.
0l0dom0l0
PostPosted: 21:40 - 05 Feb 2015    Post subject: Reply with quote
Sorry guys not updated my sig for ages.
It's for a 2006 S1 FZ6.
The last post was made 11 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 73.25 Kb
