| Liljohn999 |
 Liljohn999 L Plate Warrior
| iginge |
This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
 iginge Nova Slayer
| Northern Monkey |
 Northern Monkey World Chat Champion
| Pete. |
 Pete. Super Spammer
| iginge |
 iginge Nova Slayer
| Pete. |
 Pete. Super Spammer
 Posted: 22:47 - 06 Feb 2015 Post subject: |
It wasn't a joke, you really should stop giving technical advice. ____________________ a.k.a 'Geri'
| Carvel |
 Carvel World Chat Champion
| temeluchus |
| Fisty |
 Fisty Super Spammer
| temeluchus |
| Carvel |
| RhynoCZ |
 RhynoCZ Super Spammer
| Commuter_Tim |
 Commuter_Tim World Chat Champion
 Posted: 23:20 - 06 Feb 2015 Post subject: |
I agree too, get that leaky tap fixed pronto, taps shouldn't be able to roll in all gears.
Praise Rhyno for trying to steer BCF away from stupidity, fools errand bro.  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly.
| Pete. |
 Pete. Super Spammer
| RhynoCZ |
 Posted: 23:27 - 06 Feb 2015 Post subject: |
Good call Pete, I forgot the cable. The quick test, undo the cable and then try to roll the bike in gear. No cable means the springs (if you put some in there) will push the plates together and won't let you roll the motorcycle.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Nobby the Bastard |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 23:54 - 06 Feb 2015 Post subject: |
As for the starting issue I'm going to assume that it's electrical and that you've got nothing happening when pushing the start button...
(...unless you mean it's turning the engine over but not firing up....)
...Have you forgotten to reaffix an earth cable fixed to the clutch cover by one of the cover bolts?
Oh, and for the record, I agree with Rhyno that it's boring that Carvel agrees with Fisty who agrees with Teme, but I agree with Carvel who agrees with Pete that technical advice on this subject is distinctly lacking, however I disagree with Pete advising the changing of a bath plug chain when the tap drips, everyone knows that you should clean the drain so that the bath won't flood  ____________________ Make mine a Corona. |
| mudcow007 |
 mudcow007 World Chat Champion
| bypass2 |
 bypass2 Spanner Monkey
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 06:27 - 07 Feb 2015 Post subject: |
bath and sink plugs can be bodged by wrapping a peice of plastic bag round the plug......just keep your toes off the plug....failing that block the plughole up with body filler and attach a hosepipe to the bath ,using syphon principles ,go into the garden after a bath and just suck and let gravity do the rest...(assuming you dont live in a basement of course)
p.s. I agree that others may disagree but i strongly disagree that people should be encouraged to not post workshop advice cos some cheesballs who wank over haynes manuals think they know better.....man up ....try some soft porn , or if really hung up ...poke the mrs and forget about bikes for 3 minutes.
CG s , you ve probably put the clutch plates in the wrong way round or not assembled the thrust bearing and rod . When putting the casing on be carefull that the clutch operating mechanisim is in the right position. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 11 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
