Compressor For Blowing Down
nickyboy4
PostPosted: 23:08 - 06 Feb 2015    Post subject: Compressor For Blowing Down Reply with quote
I've been down the route of trying to do my own spraying and using air tools but never had a compressor that's done the job properly, now i just want a simple, small compressor, enough to blow up bike tyres and blowing out stuff like carbs and calipers. Money is tight so what sort of size am i needing to do these simple tasks, would a 25 litre be ok or could i go even smaller?
Thanks for any replies
mentalboy
PostPosted: 00:41 - 07 Feb 2015    Post subject: Re: Compressor For Blowing Down Reply with quote
nickyboy4 wrote:
...enough to blow up bike tyres and blowing out stuff like carbs and calipers. Money is tight so... could i go even smaller?
You're welcome Wink
https://images.esellerpro.com/2462/I/314/129/PUMP2.jpg
Make mine a Corona.
kramdra
PostPosted: 01:46 - 07 Feb 2015    Post subject: Re: Compressor For Blowing Down Reply with quote
Footpump is ideal. Ive fitted about 20 (tubeless) tyres without one. If I had a compressor it would not get used, too much space...
mentalboy
PostPosted: 02:48 - 07 Feb 2015    Post subject: Reply with quote
I know my earlier post seemed a little flippant but it's surprising what you can get for very little money.
A marginally larger, double action upright pump that is anchored with your feet will give you more than enough air for the occasional tyre inflation.
Carbs respond better to a decent solvent and just a light blow to remove loose material
Calipers are a little trickier but with some tweaking of the pump connector it shouldn't be too tricky to screw the end straight into the banjo fitting.
The only drawback is that using a foot pump for operations other than tyre inflation may require more hands than the average human possesses, or some ingenious thinking.
Make mine a Corona.
Taught2BCauti...
PostPosted: 11:53 - 07 Feb 2015    Post subject: Reply with quote
I have a 25 litre compressor, bought from Lidl years ago, and get quite a lot of use out of it.
Apart from basic tyre inflation and air-dusting, I use it with attachments: Impact Wrench, Nail Gun, Sand Blaster and Drain Cleaner.
I also use if for inflating the kids' paddling pool, and air-mattresses for the occasional sleep-over.
I have a cheap Paint Sprayer attachment too, but only use it for creosoting the shed, garage and fences.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
mudcow007
PostPosted: 14:56 - 07 Feb 2015    Post subject: Reply with quote
yep i got a compressor, had big ideas for it it. i think ive used it twice in 12 months....
now its in the way in my shed Sad
kramdra
PostPosted: 15:11 - 07 Feb 2015    Post subject: Reply with quote
[quote="mentalboy"
Calipers are a little trickier but with some tweaking of the pump connector it shouldn't be too tricky to screw the end straight into the banjo fitting.[/quote]
Fail. Use an M10 bolt to block banjo hole and 6mm PVC hose over bleed nipple.
A couple of strokes will get 100psi in the pots and force them out at some speed so hold cloth over them. If one pops out early, G clamp some thick rubber sheet over the hole to get the others out.
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 57.16 Kb
