Car MOT seat belt question
Groove
PostPosted: 22:39 - 12 Feb 2015    Post subject: Car MOT seat belt question Reply with quote
The womans car failed its MOT on 2 things;
Arrow Rear seat belt not working (you have to press it down to plug a seat belt in)
Arrow Emissions (its a turbo diesel which does 4 half mile journeys a day Laughing )
She was meant to plug a car seat in to the dodgy one so it wasnt tested and give it a good run before taking it, but she forgot about the car seat and didnt get time to give it a run...
Question is now that its failed on the seat belt, if a car seat was to be plugged in to that seat would they be allowed to test it still?
Obviously it will be getting a thrashing before going back, and the seat belt will be replaced at some point.
Bikeless
PostPosted: 23:01 - 12 Feb 2015    Post subject: Reply with quote
I would imagine if it's failed on that belt/rear belt then it will be tested again whatever, just get a latch/fixing from a scrappy.
janner_10
PostPosted: 23:25 - 12 Feb 2015    Post subject: Reply with quote
similar to above - I had an old car fail on a frayed seat belt. Got one from a scrappy for a tenner and fitted it myself. There was no drama.
Cant advise on the emissions without more detail.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:28 - 12 Feb 2015    Post subject: Re: Car MOT seat belt question Reply with quote
How is this supposed to stop someone from testing it?
Triumph Sprint ST 1050
andyscooter
PostPosted: 23:49 - 12 Feb 2015    Post subject: Reply with quote
Always got an advisory for car seats as couldn't be tested
Guessing in case they sdidnt reconnect it properly or somthing
Groove
PostPosted: 23:50 - 12 Feb 2015    Post subject: Re: Car MOT seat belt question Reply with quote
They normally give an advisory saying it cant be tested due to car seat in the way. The opposite side had the advisory which works fine. Rolling Eyes
dabigginger
PostPosted: 23:57 - 12 Feb 2015    Post subject: Reply with quote
They're not allowed to move stuff for inspection. E.g. if your exhaust was completely covered by some kind of under tray, they can't inspect it for leaks as they can't remove the tray.
binge
Emo Kiddy
PostPosted: 00:01 - 13 Feb 2015    Post subject: Reply with quote
Should have just folded the rear seats down (If they can be folded down).
Ref the smoke test. Best thing to do is throw a Wynns Diesel Magic in the tank, and go take it for a hoon.
Accuhaler
PostPosted: 02:31 - 13 Feb 2015    Post subject: Reply with quote
If you have access to a baby seat, just drop it in the seat the belt doesn't work, as others have said you'll just get an advisory
covent.gardens
World Clap Champion
PostPosted: 03:09 - 13 Feb 2015    Post subject: Reply with quote
Err - can't you still see and operate the buckle (which is the part that failed?) with the baby seat attached? If you can, and because he knows it's fucked, I would be pretty surprised if he didn't re-test it and fail you. I think the time for hiding the problem has passed.
If I was an MoT tester and someone tried that shit I'd do all I possibly could to fail it again out of sheer principle.
Groove
PostPosted: 08:36 - 13 Feb 2015    Post subject: Reply with quote
Mixed answers.
Phoning Ford for a price of the buckle in a bit, I might test the theory by changing it and then putting a car seat in it anyway Laughing
Moral of the story is; make sure the woman listens!
Minty
PostPosted: 09:16 - 13 Feb 2015    Post subject: Reply with quote
To aid assistance in making your lady pay attention, I have attached the worldwide accepted sign language for the word 'listen':
https://api.ning.com/files/vhkkuu3WVfPRpOdIUfM6BCDEObO-0pVNnkmOMxFN7Uj2Cl2yqhfxEDTrEB65lgWNT5BDasbHBKKtNriHCAVfTf6sM7HQkEPW/4842864931134fistonhand.jpg
My fingers smell of your mum.
1198
PostPosted: 10:31 - 13 Feb 2015    Post subject: Reply with quote
I would have thought a breaker would have available for little money....
Bikeless
PostPosted: 11:01 - 13 Feb 2015    Post subject: Reply with quote
Try spraying WD down the buckle to see if it frees up before buying one.
Groove
PostPosted: 11:55 - 13 Feb 2015    Post subject: Reply with quote
I've looked at it and the red bit you push down usually had a plate that blocks the pin that locks the buckle in position.
This means the pin is always in the lock position So the buckle won't go in unless you press the button down to release the pin.
35 delivered from the net. Ebay seems to charge about 30-50 although couldn't find the right one.
25 quid including vat direct from Ford. Go figure.
WD Forte
PostPosted: 13:16 - 13 Feb 2015    Post subject: Reply with quote
Re the emissions
I'd suggest putting some Millers in prior to the Italian tune up
Halfrauds type places flog it
https://www.halfords.com/motoring/engine-oils-fluids/fuel-oil-additives/millers-diesel-power-ecomax-500ml?cm_mmc=Google+PLA-_-Engine+Oils+and+Fluids-_-Fuel+and+Oil+Additives-_-811125&_$ja=tsid:60494|cgn:GoogleShopping|kw:811125&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=liipmq&istBid=tztl&_$$ja=cgid:16790764204|tsid:35522|cid:214996084|lid:50531628122|nw:g|crid:62631937204|rnd:2490734299249780924|dvc:c|adp:1o2|bku:1&gclid=CLnqq-vy3sMCFYsEwwod5R8A2w
bikers smell of wee
PostPosted: 13:39 - 13 Feb 2015    Post subject: Reply with quote
<ponders duct taping over (under) his leaking exhaust>
Dafuq aren't exhausts covered over to keep the worst of the crud off of them? Just about everything else under a modern car is.
angryjonny
PostPosted: 13:48 - 13 Feb 2015    Post subject: Reply with quote
There's a replacement exhaust industry that needs to stay afloat.
The last post was made 11 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.42 - MySQL Queries: 16 - Page Size: 109.73 Kb
