Author |
Aff |
![](images/spacer.gif) Aff World Chat Champion
![](images/avatars/159973162751d3186ad97e3.png)
Joined: 05 May 2011 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_5.gif)
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
Aff |
Back to top |
Shaft |
![](images/spacer.gif) Shaft World Chat Champion
![](images/avatars/746466802501f033748f15.jpg)
Joined: 27 Dec 2010 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:12 - 06 Aug 2013 Post subject: |
Shaft wrote: | https://www.rsbikepaint.com/en-gb/shop-paints.php?colourscheme=4462&6728=on |
Cheers Shaft, I found that company a while ago, but the tank isn't in as good condition as I remember, so I may just repaint the whole thing. Colour suggestions are welcome.
Anyway I attempted to start it today, starter motor turns it over very well, very good spark, getting fuel... but no start.
I'm assuming it has no compression, but my tester doesn't have an adapter small enough so will have to see if the shop has one or wait for one to be delivered before I can do anything.
I can't think of any other reason for the no start, it doesn't even try to catch, just spins on the starter. Plugs come out wet and bogs down if you open the throttle. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 20:13 - 09 Aug 2013 Post subject: |
Awww.
https://i1135.photobucket.com/albums/m637/Biles/b0aaeee1-3ccf-421a-84c9-f198f3acdf02_zpsff3a746b.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152550_zpsa9cccd97.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152229_zpsc8f2de9e.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152723_zps8444a04a.jpg
So probably explains the no start, I think what I may have done was accidentally put the donor engines pistons and rings in the old engine (valve clearances and timing spot on BTW).
Anyway onwards and upwards, lets do it all again (sorry for the blurriness, think I got oil on the lens):
Rockers out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_162551_zps9f4c5db8.jpg
Camshaft out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_163732_zps346a8a3f.jpg
Thought I would be able to get the studs out and not have to drop the engine, but they weren't budging, so engine out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_165250_zps05fd2618.jpg
Head off:
https://i1135.photobucket.com/albums/m637/Biles/20130809_175627_zps21c1f829.jpg
Pistons out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_180456_zps98b80185.jpg
Now seeing as the pistons look fine and the original engine was running fine I was just going to get new rings, but I cant find anything anywhere also all the piston kits have just got 2 compression rings where as the OEM pistons have 2 compression rings and an oil scraper, see below:
https://i1135.photobucket.com/albums/m637/Biles/20130809_180449_zps3d1ebf92.jpg
If anyone can link me to where I can buy replacements I will be grateful, Wemoto only have the copy 2 ring pistons and DS has nothing.
Cheers. ![Karma](images/smiles/yingyang.gif) ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Back to top |
Aff |
Back to top |
Aff |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 19:56 - 16 Aug 2013 Post subject: |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 23:23 - 17 Aug 2013 Post subject: |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:55 - 18 Aug 2013 Post subject: |
More progress.
Valve springs back in:
https://i1135.photobucket.com/albums/m637/Biles/20130818_111309_zps1d3c4177.jpg
Cylinders honed, the camera doesn't really show it very well, but it came out nice, a good 45° cross hatch.
https://i1135.photobucket.com/albums/m637/Biles/20130818_114303_zps189e8ed9.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130818_114307_zpsc90da247.jpg
Pistons etc back in, huge pain in the ass without a second set of hands.
https://i1135.photobucket.com/albums/m637/Biles/20130818_130226_zps8d373c9a.jpg
Head on and cams in. Having the chain run down the middle makes it very awkward setting the timing.
https://i1135.photobucket.com/albums/m637/Biles/20130818_141333_zps1ff3dbf5.jpg
Rockers on and valve clearances set:
https://i1135.photobucket.com/albums/m637/Biles/20130818_142444_zps8e883c98.jpg
Engine back in the frame, also a huge pain in the ass without a second set of hands:
https://i1135.photobucket.com/albums/m637/Biles/20130818_152556_zpsa007a0c5.jpg
And then it came to start it....and nothing.
Spent a few batteries worth of electricity trying to diagnose, it would start for a few seconds on carb cleaner, so I stripped the carbs down.
Turned out to be a stuck float, so sorted that and stuck the carb back on the bike.
Bodged on the Fireblades battery using cable ties and had another go.
https://s1135.photobucket.com/user/Biles/media/20130818_171523_zps337d303f.mp4.html
Still need to play about with the carb a bit, but at least it runs now. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:53 - 01 Dec 2013 Post subject: |
Back to top |
beardface |
![](images/spacer.gif) beardface Spanner Monkey
![](images/avatars/210793692652139bba5a188.jpg)
Joined: 19 Aug 2013 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_0.gif)
Back to top |
![](/images/spider_left.gif) |
There is a gap of 193 days between these two posts... |
![](/images/spider_right.gif) |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 19:01 - 14 Jun 2014 Post subject: |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 18:49 - 15 Jun 2014 Post subject: |
Back to top |
pepperami |
![](images/spacer.gif) pepperami Super Spammer
![](images/avatars/9388201394edfd3f159e48.jpg)
Joined: 17 Jan 2010 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 11:43 - 16 Jun 2014 Post subject: |
MOAR NOW! ![Thumbs Up](images/smiles/thumb_up.gif) ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
_Troy_ |
![](images/spacer.gif) _Troy_ World Chat Champion
![](images/avatars/7095337235332edd40541a.jpg)
Joined: 11 Feb 2011 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_2.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:10 - 16 Jun 2014 Post subject: |
Haven't looked through this thread before, and saw the date of the first post and was hoping to read a project from start to finish.
But then I realised I have been in your garage recently, and there are many bits in many boxes ![Laughing](images/smiles/icon_lol.gif) ____________________ Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650 |
Back to top |
Aff |
Back to top |
Aff |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 18:22 - 22 Jun 2014 Post subject: |
Back to top |
There is a gap of 192 days between these two posts... |
Aff |
Back to top |
pepperami |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 22:42 - 02 Jan 2015 Post subject: |
MOAR NOW!
Don`t make me wait ![Twisted Evil](images/smiles/icon_twisted.gif) ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
-Monty- |
![](images/spacer.gif) -Monty- World Chat Champion
![](images/avatars/1969580541532cc3347da01.jpg)
Joined: 20 Apr 2012 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_4.gif)
Back to top |
Shreeve |
![](images/spacer.gif) Shreeve Scooby Slapper
![](images/avatars/24447921253ab31fe18bbb.jpg)
Joined: 01 Jul 2013 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_1.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 18:10 - 04 Jan 2015 Post subject: |
Give in to the peer pressure and update more regularly! ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4 |
Back to top |
Moo. |
![](images/spacer.gif) Moo. World Chat Champion
Joined: 11 Jan 2009 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_1.gif)
Back to top |
Bubbs |
![](images/spacer.gif) Bubbs World Chat Champion
![](images/avatars/149900782255df6a2053ea0.jpg)
Joined: 28 May 2009 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 14:26 - 16 Feb 2015 Post subject: |
Glad I didn't see this thread when it first started - I'd be disappoint.
Looking good though.. only 3-4 more years and she'll be ready ![Laughing](images/smiles/icon_lol.gif) ____________________ Life begins at the end of your comfort zone. |
Back to top |
There is a gap of 322 days between these two posts... |
Robzki |
![](images/spacer.gif) Robzki L Plate Warrior
Joined: 04 Jan 2016 Karma : ![Neutral Karma](/images/karma/white.gif)
Back to top |
The last post was made 8 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
