Revitalising foothangers on the zr7 (99)
DottyDuck
PostPosted: 00:47 - 22 Feb 2015    Post subject: Revitalising foothangers on the zr7 (99) Reply with quote
Bonjour everyone!
Well, the foothangers on the ZR7 are looking rather sorry for themselves so I have taken them off (a task in itself, the right foot hanger was a complete pain!), gave them a clean- first with soapy water and then white spirit, used a wire wheel drill attachment and decided I would use gunmetal plastidip and then use clear lacquer on top.
Here is progress so far:
Started out like this
https://i1341.photobucket.com/albums/o743/DottyDuck/FH%20R_zpsc4ntgcqn.jpg
https://i1341.photobucket.com/albums/o743/DottyDuck/FH%204_zpsvdrevmkz.jpg
https://i1341.photobucket.com/albums/o743/DottyDuck/FH%205_zpsymeuc9gf.jpg
Got down to cleaning:
https://i1341.photobucket.com/albums/o743/DottyDuck/FH%20L_zpstadyrvob.jpg
after I attacked it with the wire wheel (may have over done it):
https://i1341.photobucket.com/albums/o743/DottyDuck/foot%20hanger%20sanded_zpsbnealh3e.jpg
After the first coat, I was worried it wouldn't "stick":
https://i1341.photobucket.com/albums/o743/DottyDuck/1ST%20COAT_zpse5wckdpx.jpg
Luckily it seemed to do the trick after a few coats (either second or third):
https://i1341.photobucket.com/albums/o743/DottyDuck/2ND20COAT_zps8iewrwtn.jpg
Both have had 4 coats on the front and 2 coats on the back of plasti dip. The one on the left has had a few coats of clear lacquer and the right one hasn't:
https://i1341.photobucket.com/albums/o743/DottyDuck/foot%20hangers%201%20with%20clear%20coat%201%20without_zps3kg1vwq4.jpg
I have now began polishing footpegs!:
https://i1341.photobucket.com/albums/o743/DottyDuck/foot%20peg_zpsz2gs1dpa.jpg
I am pleased with how they are turning out but hope they last a good while... time will tell. Smile
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
SQL
PostPosted: 03:07 - 22 Feb 2015    Post subject: Reply with quote
Plastidip is designed to come off? that is a high friction area I expect the paint wont last refitting.
grr666
PostPosted: 13:36 - 22 Feb 2015    Post subject: Reply with quote
I would have used Hammerite then baked it off on in an 100 degree oven for a couple of hours. .
Did that to some car brake calipers some years back and they looked
great. The paint never so much as flaked even after a few Castle Combe trackdays.
The baking is the key IMO. As was the 10 or so thin coats.
Before.
https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/SAM_0387.jpg
During.
https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/SAM_0398.jpg
After.
https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/SAM_0424.jpg
nowhere.elysium
The Pork Lord
PostPosted: 13:47 - 22 Feb 2015    Post subject: Reply with quote
Did you at least prime it before painting it?
grr666
PostPosted: 13:53 - 22 Feb 2015    Post subject: Reply with quote
Me? No need they were in primer already. They are fitted to cars
(namely Audi TTs and the like) without paint in silver natural finish as pictured.
They were a upgrade for the OEM brakes on my car so were painted to match the original brakes which were green when they left the factory.
nowhere.elysium
The Pork Lord
PostPosted: 13:56 - 22 Feb 2015    Post subject: Reply with quote
Sorry no - that question was aimed at OP.
RhynoCZ
PostPosted: 14:11 - 22 Feb 2015    Post subject: Reply with quote
I'm actually surprised Dotty took those off, before she painted them. Smile
PostPosted: 14:28 - 22 Feb 2015    Post subject: Reply with quote
OP mentions plasti dip...which would need nothing initially but then has used clear coat...so I'm a little confused.
nowhere.elysium
The Pork Lord
PostPosted: 14:34 - 22 Feb 2015    Post subject: Reply with quote
Plasti-dip's website says otherwise.
PostPosted: 15:16 - 22 Feb 2015    Post subject: Reply with quote
I could coat my car in it, my friends wheels are also plastidip coated and they are directly sprayed on to. I'd not prime, I'd just spray it...its worked fine previously.
SQL
PostPosted: 15:22 - 22 Feb 2015    Post subject: Reply with quote
I would clean and spray, priming it defeats the point of it not being permanent.
DottyDuck
PostPosted: 18:17 - 10 Mar 2015    Post subject: Reply with quote
Thought i'd post an update!
https://i1341.photobucket.com/albums/o743/DottyDuck/fh10_zps9gezpgdn.jpg
https://i1341.photobucket.com/albums/o743/DottyDuck/fh6_zpsplngfmph.jpg
they seemed to be fine! i did rush putting them on and caught some of the plasti dip but it hasn't started to peel.
I used plasti dip as i wasn't sure on what colour as i was stuck between this one and black. I also clear coated to help it last longer.
I am fine with the colour choice although when it comes off i will probably spray in black as I have bought some paint to respray the mirrors.
PostPosted: 18:41 - 10 Mar 2015    Post subject: Reply with quote
CLASH Sick
SQL
PostPosted: 23:05 - 10 Mar 2015    Post subject: Reply with quote
looks like its been left in primer Laughing
Carvel
PostPosted: 23:15 - 10 Mar 2015    Post subject: Reply with quote
Nice wheels.
temeluchus
PostPosted: 23:44 - 10 Mar 2015    Post subject: Reply with quote
You can often get away without primer with plastidip.
Also great for repairing torn carb diaphragms.
DottyDuck
PostPosted: 00:34 - 28 Apr 2015    Post subject: Reply with quote
So after a short time the plasti dip was peeling on the left FH. I decided to peel it off and polish them as I imagined the wear and tear would eventually destroy spray paint so I have now polished them.
Here is a photo, I painted the little circle thing black (it was chome coated) and it was obvious they were 2 different type of metals.
https://i1341.photobucket.com/albums/o743/DottyDuck/0173e594-b1a7-4881-b073-fb0b7ba3458f_zpspo9rzh3m.jpg
The last post was made 11 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.33 - MySQL Queries: 16 - Page Size: 103.4 Kb
