Laptop instantly clicks off at low battery - no warning
Lord Percy
PostPosted: 12:20 - 07 Mar 2015    Post subject: Laptop instantly clicks off at low battery - no warning Reply with quote
About two weeks ago, my laptop warned me of low battery, then half a second later it just flicked off like a light switch. No chance to get it plugged in at all.
Since then, every time it gets to low battery (about 20% - not even the critical level of 7% or whatever) it just clicks off dead. No warning or anything, the whole thing just goes out like a light.
I did a bit of research and found I could run a battery diagnostic through the command prompt, which told me the battery was in perfect condition.
I then tried a system restore to a time before this issue started.
However it's still happening.
I'm guessing it's a software issue as it always dies at the point when the 'low battery' warning is supposed to pop up, which is still quite a way from battery being actually dead.
Thoughts??
Thanks
Andy_Pagin
PostPosted: 14:23 - 07 Mar 2015    Post subject: Reply with quote
Off the top of my head..
BIOS settings been changed?
I'm guessing you're running Windows. An easy way to take that out of the equation is to run it down to say 25%. Boot from a Linux Live CD, set the power management setting to whatever. Then wait and see if it shuts down at the same percentage with Linux.
kramdra
PostPosted: 15:20 - 07 Mar 2015    Post subject: Reply with quote
My guess is inaccurate voltage measurement in the computer and the batterys internal low voltage protection kicking in. Check with a multimeter after it occurs.
Ben90
PostPosted: 18:04 - 07 Mar 2015    Post subject: Reply with quote
https://imgs.xkcd.com/comics/hard_reboot.png
Change low battery warning to 30%. Solved.
Yamaha FZ6 S2
Seb
PostPosted: 19:10 - 07 Mar 2015    Post subject: Reply with quote
It's just likely the battery wearing out. Set the shutdown percentage higher or replace the battery.
2010 Triumph 1050 Sprint ST
Lord Percy
PostPosted: 03:23 - 08 Mar 2015    Post subject: Reply with quote
I had no idea I could do that. Thanks Thumbs Up
If that doesn't work, I'll think about BIOS things etc. Strange though as I've certainly never played around with those settings before so why would it change suddenly?
Ben90
PostPosted: 09:31 - 08 Mar 2015    Post subject: Reply with quote
Yep, it's somewhere in Control panel > Power Options > Change plan settings > advanced settings and it's the expansion box thingy called Battery at the bottom. Thumbs Up
Yamaha FZ6 S2
prawny1
PostPosted: 09:52 - 08 Mar 2015    Post subject: Reply with quote
go into device manager and uninstall anything to do with the battery and powerpack then restart the laptop but go into bios, if you have a memory check built in run that until the laptop shuts off if not just leave it in bios to drain the battery.
When it has remove the battery and power up the laptop let it do a few shutdown cycles then replace the battery and let it fully charge, now go into power management and adjust the setting to do nothing on low battery warning and run the laptop flat and recharge a few times, this should recalibrate the battery meter.
once you are done reset the power options back to normal.
hellkat wrote:
Andy_Pagin
PostPosted: 13:14 - 08 Mar 2015    Post subject: Reply with quote
I mentioned BIOS just in case you'd been playing with the settings, or done a recent BIOS update.
As I said you can easily eliminate the O/S and software from the equation using a Linux Live CD, which won't install or change anything at all on your machine.
The last post was made 11 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 16 - Page Size: 62.64 Kb
