Show your touring/adventure equipped handle bar
charliefirpo
PostPosted: 02:46 - 16 Mar 2015    Post subject: Show your touring/adventure equipped handle bar Reply with quote
I'm curious what you guys have on your handle bar when you make longer trips.
I am guessing you got a GPS and maybe a SPOT?
So far I only have my GPS on there so it's pretty empty.
I'm thinking about getting a SPOT device. But maybe it would be better to wear it on my body since one might land somewhere different than the bike coming off.
My empty bar with just my getto GPS solution:
https://i.imgur.com/jBxgcGO.jpg
Matt B
PostPosted: 10:05 - 16 Mar 2015    Post subject: Re: Show your touring/adventure equipped handle bar Reply with quote
charliefirpo wrote:
...maybe a SPOT?
A what?
bamt
PostPosted: 11:13 - 16 Mar 2015    Post subject: Reply with quote
A spot is a satellite tracking device - it uploads your location to their servers via satellite (i.e. no mobile coverage needed) on a regular basis, allowing you to be tracked pretty much anywhere in the world (with the exception of some polar regions, IIRC). It also has an SOS feature so you can call for help without mobile coverage.
I know people who use them for solo long distance trips, and also where they are doing some kind of challenge (charity or otherwise) where people want to be able to see where they are on the web.
MacZurbi
PostPosted: 11:20 - 16 Mar 2015    Post subject: Reply with quote
we are navigating with the GPS from BMW - Navigator 4.
Until now, we found most of the places we searched to reach mrgreen:
Greetings from Switzerland,
Fredy
Greetings from Zurich/Switzerland
Enjoy your life - it is always to short Smile
Actual bike: BMW R1200 GS Liquid cooled
charliefirpo
PostPosted: 11:58 - 16 Mar 2015    Post subject: Reply with quote
That is also why I want to be using the SPOT device. I will be riding solo long distances so I want to be sure somebody will pick up my corpses.
They will actually launch a search & rescue mission pretty much all over the world if you send an SOS. Helicopter and all that. Or simply an ambulance when you are on the road. Ore you can send an assistance request which just goes out to pre set contacts which you can use when you just need non emergency situations. Plus you can track your routes and send update messages home with an interval with your location. Though some of these features cost extra. The only down side is that you have to but a subscription which isn't cheap (at least 100quid) but it's worth it for me because to a certain degree it simply gives me piece of mind, knowing that I can get help.
PostPosted: 21:52 - 16 Mar 2015    Post subject: Reply with quote
I fitted a motherfucking casio digital to mine. This means I always know what the time and date is. Waterproof to 50 metres!
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG2158_zpssgt8c7uo.jpg
charliefirpo
PostPosted: 22:35 - 16 Mar 2015    Post subject: Reply with quote
I first thought you are kidding. Then I saw you are not.
I like how it's not just flapping around. It's got it's own proper mount. You really put some work into this and made it work.
Very Happy
Just make sure you check frequently when you are nearing 45m!
https://pbs.twimg.com/profile_images/2161482394/image.jpg
PostPosted: 22:57 - 16 Mar 2015    Post subject: Reply with quote
It's amazing what you can do with some foam pipe insulation and a bit of gaffa tape. Smile
EDIT: Bitches don't know about my compass either (clipped onto front brake cable).
PostPosted: 23:06 - 16 Mar 2015    Post subject: Reply with quote
Casio FTW! Smile
https://www.bikechatforums.com/download.php?id=80586
PostPosted: 23:10 - 16 Mar 2015    Post subject: Reply with quote
The Shaggy D.A. wrote:
I couldn't help but notice you also appear to have fitted a handlebar-mounted, dynamic carb balance monitor. Expect a call from touratech any day to talk about licencing the rights to your invention.
-Monty-
PostPosted: 23:49 - 16 Mar 2015    Post subject: Reply with quote
I too noticed this fantastic piece of innovation.
Do tell us what gave you the inspiration for such a unique and compact design?
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
Monkeypony
PostPosted: 09:15 - 17 Mar 2015    Post subject: Reply with quote
Heated Grips, a sat nav and a double bubble screen.
https://i293.photobucket.com/albums/mm52/monkeypony/20150317_065001_zpsweyfrozm.jpg
All any self respecting tourer needs.
Apart from fuel, which it seems I'm out of. Again.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
Knightsy
PostPosted: 08:31 - 18 Mar 2015    Post subject: Reply with quote
https://i.imgur.com/kLW4CEi.jpg
£6 GPS holder + bunch of foam + 12v with a cap = All I'd ever need Thumbs Up
A "proper" alternative: https://shop.touratech.com/over-cockpit-nav-bracket-universal-yamaha-xt660z-tenere-gps-bracket-adapter-bracket-for-navigation-systems.html#!prettyPhoto = €41.90 Shocked
09' Versys 650 | 07' FJR1300A
Northern Monkey
PostPosted: 09:17 - 18 Mar 2015    Post subject: Reply with quote
My enfield is fitted with a Casio. Not only is it waterproof to 50m, it can also tell me the time in New York and Cairo
PostPosted: 21:16 - 18 Mar 2015    Post subject: Reply with quote
Well, once I got the layout right, it was a simple case of miniaturisation to end up with the discrete module you see in this example. I'm now working on a version for the Savage - being a single it should only need half the components.
delsol
PostPosted: 18:57 - 02 Apr 2015    Post subject: Reply with quote
Carb balancing on the hoof, fastidious attention to maintenance, way to go bro.
pepperami
PostPosted: 20:05 - 02 Apr 2015    Post subject: Reply with quote
https://i158.photobucket.com/albums/t87/pepperami_photos/SANY0335_zpsc55e4b5f.jpg
If look closely you can see my 99p watch of lovelyness stuck to the top yoke with sticky backed velcro Thumbs Up
Meaning I can remove both the sat-nav AND my time piece when I park up Smile
The last post was made 11 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.64 - MySQL Queries: 16 - Page Size: 102.38 Kb
