| sutty86 |
 sutty86 Trackday Trickster
 Posted: 21:20 - 28 Mar 2015 Post subject: dash lights dodgy |
OK picked up new bike today - Derbi Terra 125
Really nice bike, got it at a good price 900 just one fault what I know about ATM
Apart from melted light housing and slack chain.
The dash lights are illuminating when they shouldn't be.
All indicators,lights work fine,neutral.
For example knock my indicator on and I have got to physically check it's on and off,bodywork on the bike makes it pretty difficult.
Fuel light is on majority of time when tanks full.
Seller was honest and open about this,and said it passed last mot.
Also if it helps the seller told me it started doing this after installing new battery,also at then time the mileage reset.
I've took a few photos to help explain
https://i.imgur.com/1aWM5HY.jpg
https://i.imgur.com/c1pTFaG.jpg
After further investigating earth lead (yellow) came off,just unwrapped. Voltage 12.3v engine cold. 13.6v when fired up
Stuck optimate on overnight.
Hold start button and fires up after 2 seconds(is this right,Ive come from fuel injection ,where I normally just press once)
Bike as only done around 800 miles in two years!!!
https://i.imgur.com/v6piXHE.jpg
Really would appricaite yoir knowledge this site has!!!
Beers and kudos to people who help!!!!
Got a multimeter also but its a cheap crappy one.
And I've squirted a few connections with wd40 to see if it would help... |
| Raffles |
 Raffles World Chat Champion
| sutty86 |
| Raffles |
| sutty86 |
| WD Forte |
 WD Forte World Chat Champion
| Taught2BCauti... |
 Posted: 10:35 - 29 Mar 2015 Post subject: |
It's pretty obvious that someone has been messing with the wiring, but a couple of good clues here, are the mileage re-setting itself and the melted wiring!
I think that suggests that the system voltage has gone excessively high at some point, so you need to do a full check of the alternator windings and the reg/rec - as well as all of the repairs that might have been done.
Check all of the fuse values aswell - it's not unusual for tinkerers to replace them with higher rated ones if they can't find the cause of them blowing.
I would even consider trying to find a replacement wiring harness, as I had to do this once for a car that had been bodged beyond help - saved a lot of time and brain-ache. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Raffles |
The last post was made 11 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
