| Kelly. |
 Kelly. L Plate Warrior
| Pol Anorl |
 Pol Anorl Banned
 Posted: 16:02 - 09 May 2015 Post subject: |
air and fuel mixture set right? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Kelly. |
| Mysteriass |
 Mysteriass Nova Slayer
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:54 - 10 May 2015 Post subject: |
so you need
original jets
correct needle
make sure airbox is connected with correct air filter
make sure you have no air leaks on any of the rubbers
turn the mixture screw all the way in then 2 1/2 turns out
from the description you gave its bogging down under fast full throttle. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Kelly. |
| WD Forte |
 WD Forte World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 20:03 - 10 May 2015 Post subject: |
ok so its chucking in too much fuel.. is the correct needle fitted?
air screw set correct?
rubber perished? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 14:13 - 11 May 2015 Post subject: |
Assuming you have the original carb,not the type two Brazil with the accelerator pump,then it sounds like a knacker or wrong main needle.another problem can be float height,..or...a punctured float. You said you needed loads of choke so you either have air leaks, worn main jet n slide , slidecoiver screw misthreaded or knackers engine.
What's clear about every Honda single 125\100 is they need hardly any choke, its clearly a fueling issue..........or........completely worn engine.
Bear in mind that most carbs over twenty five years need a new washer\ jet\ needle and slide and float. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 11 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
