| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:24 - 08 May 2015 Post subject: Rxs 100 project... It may be fucked -.- |
Was looking for a bike to fix up whilst im bored, fazer is done on all small parts all except the polishing of the swingarm and forks but waiting on polishing pads...
found an rxs close to me went to look and it wasn't looking too pretty..
apparently "bored out to 110cc"
parts missing and bits of rust, guy said it was running but he painted the tank and it didnt work after so he ordered a new battery but still a no go.
offered £100 less ended up getting it for under £250, can't go wrong.
came with the side panels but werent on the bike at the time.
https://i.imgur.com/XzgpsZv.jpg
https://i.imgur.com/hnnewVA.jpg
Pushed it 2 miles home with the gf taking it in turns (flat front tyre was a bitch)
had a look over it and the positive was connected to the frame
charged battery stuck it back on we had power!!
Indicators don't work properly, left works doesnt flash very dim, right is a no go but right indicator light on dash stays dimly lit. horn is quieter than a moths fart..
next is the engine, grabbed some fuel from my fazer, keys in ignition on and 1 swift kick it fired into life!!
no hesitation no problems ran fine smoked fine!
https://www.youtube.com/watch?v=sYD_eqV79qw&feature=youtu.be
to do list:
Repaint the god awful tank! its like someone primered it with the thickest possible primer and didn't sand it then painted over the top.
Fix electrics
fix front tyre (puncture or flat)
put side casings back on.
much polish.
fit bolts where they belong. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges
| CaNsA |
 CaNsA Super Spammer
 Posted: 01:03 - 08 May 2015 Post subject: Re: Rxs 100 project |
| PaulFzs wrote: | Was looking for a bike to fix up whilst im bored, fazer is done on all small parts all except the polishing of the swingarm and forks but waiting on polishing pads...
to do list:
Fix electrics
much polish.
fit bolts where they belong. |
Iain. |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 01:07 - 08 May 2015 Post subject: |
no coz teh swingarm doeznt have a 500mm of movement ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 13:02 - 08 May 2015 Post subject: |
today i did take a better look over it...
12v bulb taped into headlight..
wiring loom had been cut then rejoined.
flash relay needs replacing
1 stud on seat has snapped off but other than that seat is good.
needs speedo cable and tacho cable. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| wodge |
 wodge Nitrous Nuisance
 Posted: 20:24 - 08 May 2015 Post subject: |
That's a good price for a RXS these days
There is a 12Volt mod for RXS's Has yours been converted? It might explain the 12Volt bulb, weak horn and dodgy indicators... ____________________ nolidge iz pouwur.
Yamaha RXS100 RS100 |
| Pol Anorl |
 Pol Anorl Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:41 - 08 May 2015 Post subject: |
today i did take the carb off, gave it a clean, much gunk and dirt inside then i tackled the outside because why not.
before (slightly cleaned off bowl before pic)
https://i.imgur.com/Yb4teTg.jpg
after
https://i.imgur.com/YKeSrNr.jpg ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| -Monty- |
 -Monty- World Chat Champion
 Posted: 21:49 - 08 May 2015 Post subject: |
Good price for an RXS. Will be watching this with interest. Good fun blasting these through the country back roads on a summers afternoon  ____________________ Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition] |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 22:44 - 08 May 2015 Post subject: |
will be doing this with moderate interest, my other half is showing more interest than me but muggins is doing all the work.
need to find out if i can get the seat bolt out at its snapped and not enough thread to get a nut on the end, the bolts go through the rack and frame holding the seat on, have 1 thats fine but id rather have 2.
May get a sidestand if i find one cheap enough but has centre stand for now.
need to fathom out this electrical problem, im sure its just the flash relay thats borked, indicators are weak and barely visible unless youre giving it some revs and even then its hardly bright. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Pol Anorl |
 Pol Anorl Banned
 Posted: 18:06 - 10 May 2015 Post subject: |
carbs all cleaned, seat hamerited underneath.
Sanded most of the tank to a smooth finish, i may just paint over the top of whats on it now providing it doesn't react on a test surface.
took front wheel off to find the adjuster for the rear brake had snapped -.-
may have enough thread and adjustment on the lever.
clutch seems a bit dry and seems to have tons of slack even at full adjustment but whel i pull the clutch cable out from the side casing and pull the lever its stiff as hell it engages but only just i can feel it trying to turn the wheel still and finding neutral whilst its running is impossible ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Pol Anorl |
 Pol Anorl Banned
 Posted: 20:08 - 11 May 2015 Post subject: |
so i attacked the clutch, it sounded insanely dry i couldnt get neutral and i had no idea when the oil had been done so oil change might help...
Took sump bolt out and i thought id accidentally cut the fuel pipe...
out came gushing 2% oil 98% petrol and even then there was under 100ml !!
filled it up with oil according to the manual and run it for 15 mins, will do it again a few more times then drop the oil and see how it goes...
im guessing itll probs be full of fuel again if so then a new job to tackle!!
on the plus side i can find neutral 8/10 times.
oil + fuel mix
https://www.youtube.com/watch?v=paLLrXjWkn4 ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Pete. |
 Pete. Super Spammer
| Pol Anorl |
 Pol Anorl Banned
 Posted: 20:16 - 11 May 2015 Post subject: |
i dont know why i didnt check out before started and running it for the past 3-4 day. pretty tough motor it hasn't siezed! ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| CaNsA |
 CaNsA Super Spammer
| moggie |
 moggie Borekit Bruiser
| Pol Anorl |
 Pol Anorl Banned
 Posted: 01:31 - 12 May 2015 Post subject: |
super capacitor is smaller, don't really need power when the engines not running. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Doovy |
 Doovy World Chat Champion
 Posted: 09:38 - 12 May 2015 Post subject: |
My 20 year old RXS was in a bit better condition when I got it but still requires a little bit of work.
My back brake pedal is a little too close to the footpeg (similar to yours), replacement rear left shock needed and my front brake adjuster needs adjusting
Good bike though, I'm hoping to fix up those last bits, get an MOT and sell during the summer for a bit of cash for profit. Bought for £300 in May 2014. ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
| Iain. |
 Iain. Could Be A Chat Bot
 Posted: 09:53 - 12 May 2015 Post subject: |
Doovy, gimmie a shout when your RXS is availible.
Might be interested depending on situation at the time  |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:56 - 12 May 2015 Post subject: |
nice one doovy, im struggling to find the correct colour of the tank and one of the rxs induction emblems. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| urbandz1255 |
 urbandz1255 Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 14:31 - 28 May 2015 Post subject: |
today i will be taking the top end off...
await fucked rings bearings cylinder tyres. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Pol Anorl |
 Pol Anorl Banned
 Posted: 18:48 - 28 May 2015 Post subject: |
head off.. turns out its +2mm oversize
downside is i could only get 2 of the 4 cylinder nuts off...
new spanner ordered to try again.
https://i.imgur.com/vh4ERl4.jpg
it has at some point had some damage to the head.. pretty deep so just polished and left as is.. no point trying to get it out.
https://i.imgur.com/S1fGg9A.jpg ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| wodge |
| Pol Anorl |
 Pol Anorl Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:14 - 30 May 2015 Post subject: |
still waiting on man sized spanner so i can get the cylinder off...
im placing bets on stud snapping. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
The last post was made 11 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
