Aprilia rs125 low compression
Henry2202
PostPosted: 16:37 - 15 May 2015    Post subject: Aprilia rs125 low compression Reply with quote
I have finally got round to looking at my rs125 after it cutting out whilst i was riding it,and not starting again. The exhaust developed a hole in it about 3 days prior to cutting out, but about two weeks before that it was cutting out every so often, i'd wait about 2 mins and she'd fire back up, this time she didn't. I did a compression test today and got a reading of 45psi, Would a hole in the exhaust compromise a compression test or would it be the same? Would i be right in thinking it needs a top end rebuild? Cheers, and if you replied to my previous thread sorry i don't know how to view it now.
PostPosted: 17:45 - 15 May 2015    Post subject: Reply with quote
Hole in the exhaust might have a minor effect on a compression check, but nowhere near dropping the compression by ~2/3.
Did you do the compression check with the throttle wide open?
However fair chance it needs a top end rebuild. Easy enough job.
K
Henry2202
PostPosted: 18:21 - 15 May 2015    Post subject: Reply with quote
K
Hi, thanks for the reply. I didn't initially hold throttle open, but just been out and tested again with the throttle open but no change, still 45psi. I will remove the top end and take a look. cheers
webhead
PostPosted: 01:13 - 16 May 2015    Post subject: Reply with quote
sounds like the usual rs story , hopefully its just piston if not new barrel , what engine you got a 122 or a 123?
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.55 - MySQL Queries: 16 - Page Size: 42.21 Kb
