Hydraulic DIY clutch
john24ssj
PostPosted: 13:47 - 25 May 2015    Post subject: Hydraulic DIY clutch Reply with quote
Hi guys,
Had a go on my friends bike which had a hydraulic clutch and I loved it! But my ER5 clearly can't have on like that Sad
What I found though is hydraulic pull clutch kits, here's some images i found online:
https://i.imgur.com/4VLZPmN.jpg
https://i.imgur.com/lpOqBi5.jpg
https://i.imgur.com/ZxWsZCG.jpg
https://i.imgur.com/buAhJko.jpg
I wanted to ask has anyone had any experience with these?
Found few links for them, seem to be fairly cheap:
CNC Pull Hydraulic Clutch Cylinder Pump
7/8 Motorcycle CNC Hydraulic Brake Master Cylinder Or Clutch Lever
Thanks Smile
Bikes: Honda CBR600Fi, Kawasaki ER5
kramdra
PostPosted: 14:06 - 25 May 2015    Post subject: Reply with quote
What bike does he have? if its standard it ill be set up right and suit the clutch.
It would be some guesswork/trial and error to get the right stroke and feel at the lever. Brake mc's are designed for much larger pistons. Also chinese parts are shit.
RhynoCZ
PostPosted: 14:42 - 25 May 2015    Post subject: Reply with quote
Well, I wouldn't bother. Thumbs Up
There's really no point in having hydraulic clutch on your motorcycle. They only put those on bikes in the 90's because it was, for some reason, popular back then. Also, I do not see a point in the conversion. The vast majority of hydraulic clutches I've seen, the ZXR included, had a push rod system, rather than pull the classic lever mechanism in the clutch lid. I might be wrong, but I can't see a single benefit in what you are trying to achieve.
I think the cable operated clutch is the best. You can set the lever wherever you want it and the clutch control is just more precise. I do realize you can buy aftermarket levers for the hydraulic operated clutch with 20 different settings and so on, but yeah, no. Thumbs Down
john24ssj
PostPosted: 15:00 - 25 May 2015    Post subject: Reply with quote
She's got a bandit 1200 Smile
Thanks guys, I was just curious. My clutch seems to be quite hard most likely just need a new cable.
Are Slinky Glide cables any good?
kramdra
Get decent levers, keep standard clutch cable.
Some like these
https://www.ebay.co.uk/itm/281241553390
john24ssj
PostPosted: 15:03 - 25 May 2015    Post subject: Reply with quote
Some like these
Great minds think alike Very Happy I got them already and love them!
But my clutch cable is at-least 7 years old.
RhynoCZ
PostPosted: 15:20 - 25 May 2015    Post subject: Reply with quote
You could buy a set of pulleys, to reduce the force required to disengage the clutch with the lever. Some older riders here had such a system on their bikes. I've no idea what the English term is, but I bet, someone will soon come, to explain it to you. It's basically primary school physics. Smile
PostPosted: 19:11 - 25 May 2015    Post subject: Reply with quote
They can be very useful on bikes with uprated or very heavy clutches. Or for people with hand and wrist injuries.
A mate of mine fitted one to his Triumph X75, he was unable to use the standard clutch.
That said, an ER5 shouldn't really have an issue. It's a reasonably smooth, light clutch on them with a well-designed, span adjustable lever as standard. I think you'd be better off spending your money on a new cable and ensuring it's routed correctly. Also check the pivots on the lever are free to move and well lubed.
Magura make levers and parts for Royal Enfields so I personally wouldn't think about fitting magura parts to anything I actually wanted to work properly for any length of time. (to be clear, Enfields work, they don't work properly)
PostPosted: 20:56 - 25 May 2015    Post subject: Reply with quote
Here's me now pondering fitting a hydraulic clutch to mine because it is working properly. It's getting a bit predictable.
PostPosted: 21:26 - 25 May 2015    Post subject: Re: Hydraulic DIY clutch Reply with quote
You can also get systems for cable which change the ratio of lever pull to cable movement (so that there's a lighter action). However of course this means you need to have it setup more precisely - with heavier clutch springs where there may be a smaller biting point, this should be less of an issue.
Northern Monkey
PostPosted: 21:49 - 25 May 2015    Post subject: Reply with quote
Try riding it somewhere, that'll soon put a stop to it working properly
PostPosted: 23:31 - 25 May 2015    Post subject: Reply with quote
Or they use hydraulics on systems which require a 'push'? Smile
b422063
PostPosted: 08:28 - 26 May 2015    Post subject: Reply with quote
kramdra wrote:
Get decent levers....Some like these link to Chinese parts
Rolling Eyes
MaybeGuy
PostPosted: 09:25 - 26 May 2015    Post subject: Reply with quote
I had one of these on my crf250x and it was actually great. I got a magura master cylinder and line from a Ktm sx250. Ditch the dowty seals it comes with and file the surface of the slave flat, then use proper copper washers. Basically do everything the Chinese didn't, and it's a good product
Oh, it was also too long, so for it to work properly I had to cut down the actuator rod. Replaced the nipple with one from those universal cable repair kits.
talkToTheHat
PostPosted: 13:52 - 26 May 2015    Post subject: Reply with quote
I'm not sure it's just about force multiplication. Hydraulic systems that are properly adjusted are less elastic so give more immediate feel with less mechanical slop. With a hydraulic conversion as pictured you still have the linkages at the clutch side.
I have ridden some bikes with superbly light feeling cable clutches that I can operate with one finger, so it has to be down to the clutch mechanism. The 99 R1 has an effortless clutch and it appears to transmit a more than adequate amount of torque. My 535 requires four finger operation yet is known to be prone to slippage despite being connected to a more feeble engine.
Bandit. does. everything.
PostPosted: 14:52 - 26 May 2015    Post subject: Reply with quote
mpd72 wrote:
I'd be worried about hydraulics working properly in a pull environment with braided hoses. Surely they offer greater strength to push forces rather than pull forces?
I'm guessing this is why manufacturers use push forces on all normal hydraulic clutches. If pull was the better option, they would use it.
Look at what you've typed.
Now look a this picture and tell me where in that system hydraulic fluid is doing anything but being compressed?:
The only part there "pulling" anything is a solid metal rod attached to the slave cylinder. The master cylinder compresses the hydraulic oil which is transmitted down the hose to expand the slave cylinder away from the clutch linkage. This puts the link rod into tension. When the pressure is released on the lever, a spring in the slave cylinder compresses the fluid which returns up the hose to the master cylinder.
stevo as b4
PostPosted: 18:46 - 26 May 2015    Post subject: Reply with quote
I'd like to have the smug feeling of technically superior machinery in having a bike equipt with a hydraulic clutch, if it was OEM and built in the 90's when Jap build quality was possibly pretty good.
I cannot see any point in fitting the kit the OP was thinking of, and I don't dislike cable clutches, but if I had a hydraulic bike, I would have bit of mine is bigger than yours feeling possibly? Laughing
PostPosted: 22:08 - 26 May 2015    Post subject: Reply with quote
Oh yeah. You bet your arse. (VFR750 owner reporting in). You still need to de-yak the pushrod every so often but it does indeed come with that smug "No cable for me" feeling.
The setup the OP has posted does look like it would be quite interesting for a possible hydraulic drum conversion though Thinking
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 22:20 - 26 May 2015    Post subject: Reply with quote
The enfield gets round having a shitty clutch by using 2 different different strength springs. I think this makes the plates stack up slightly off-kilter every time. If it starts slipping, I switch them about randomly.
If I'm drag racing, I drain the oil out of the primary and leave the cover off. Can't do that with your fancy-schmancy unit construction motorcycles!
ScottT
PostPosted: 22:48 - 26 May 2015    Post subject: Reply with quote
Like this, I tried one on my TY175 a few years ago, it made the clutch a bit easier/lighter.
https://www.trialsbits.co.uk/images/EAsyClutch.jpg
PostPosted: 13:08 - 27 May 2015    Post subject: Reply with quote
mpd72 wrote:
Remind me how a "push hydraulic clutch" would pull the normally cable pulled actuator on an ER5 again?
Look at the picture. Look where the hydraulics are fitted.
The clutch lever PUSHES against the piston in the master cylinder. This pressurises the hydraulic fluid which PUSHES against the piston in the slave cylinder and moves it.
When you release the lever, a spring PUSHES the slave piston back in which pressurises the hydraulic oil which PUSHES the master cylinder back to its original position.
It exerts a pulling action on the cable attachment because of where the rod is attached to the piston, the hydraulics themselves aren't pulling. If you attach the rod to one side of the piston it'll pull on the rod, if you attach it to the other, it'll push but the piston is being forced out by an increase in hydraulic pressure in either case.
PostPosted: 15:06 - 27 May 2015    Post subject: Reply with quote
Hitchcocks will sell you one for £295 plus VAT - bottom of the page :-
https://www.hitchcocksmotorcycles.com/accessory-gearbox-clutch-primarydrive
Love their "Enfield owners are slightly touched, we'll just move the decimal place a bit" pricing Smile
The last post was made 11 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.93 - MySQL Queries: 16 - Page Size: 143.58 Kb
