| simon1221 |
 simon1221 World Chat Champion
 Posted: 23:11 - 01 Feb 2005 Post subject: Iridium Tipped Spark Plugs |
Anyone had any experiences with these?
I brought one from SparkPlugs, just to see if it made any difference.
If you are unfamiliar with it, they are standard plugs with the tip made from Iridium (stronger, better conductor) instead of copper. More info here
On my 2T tzr i can feel a noticeable difference in acceleration and throttle response, plus the fact that it warms up faster and does not need the choke as long.
I did bugger up the YPVS and the powervalve got stuck open, causing the bike to be derestricted, this however made the bike incredibly fast acceleration (at higher revs, absolutely nothing lower down) and is quite sensitive at the higher rev ranges.
I put the powervalve back to standard setting (see other post - workshop) and then it was fine.
Mine cost £6 plus p+p and tax for a BR9EIX (equivalent of BR9ES) so it was £10 from SparkPlugs.co.uk.
Anybody else notice any difference? ____________________ DNA50 (sorry) ->> TZR125l >> GPZ500S |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 23:27 - 01 Feb 2005 Post subject: |
Placebo? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| pipnet11 |
 pipnet11 Brolly Dolly
| GSXR |
 GSXR Two Stroke Sniffer
 Posted: 02:41 - 02 Feb 2005 Post subject: |
Hi,
I got hold of one for my XR600R in a last ditch effort to make it easier to start when hot - kick-start only and brute to start when it's hot
Shocked to say it worked
I can't comment on their ability to improve performance but one other advantage is that you can run a cooler grade of plug as the "fine wire" type plugs are much less prone to fouling. This is handy if you're running non standard ignition timing etc and your engine has a tendency to run a little hot. ____________________ GSXR | Ian
| 1991 GSX-R 1100M | 1994 XR600R | 1965 BSA C15T | 1970 Woman | 2001 Daughter | 1989 Leathers | |
| BLOFLY 636 |
 BLOFLY 636 Brolly Dolly
 Posted: 08:29 - 02 Feb 2005 Post subject: |
I will be fitting 4 of them to my ZX-6R as soon as my bike goes in for it's 12,000km service I have heard they are worth the extra money because they increase spark size due to a smaller electrode tip producing a cleaning action each time the spark fires which maintains a healthier plug in terms of premature fowling I can see how this would increase performance closer to the end of a standard plug life expectancy because the iridium tip should stay cleaner longer  ____________________ Those bloody footpegs......they ought to do away with em! |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 12:15 - 02 Feb 2005 Post subject: |
If they provide a stronger spark and foul less, that should give a better combustion. A stronger (bigger) spark should ignite the mixture better (faster flame speed and hopefully more complete combustion), and less carbon fouling to glow red hot and cause pre-heating/ pre-ignition will give you better burning. It's all about the burn rate, though that's also largely controlled by the mixing and vapourisation of the fuel. Less carbon fouling will keep the plug running better for longer, which obviously is something you'd notice too.
I suppose it's like brake pad ingredients, a little bit of black magic.  ____________________ I must not be a troll...
Mmmm, Guinness
| Zoffo |
 Zoffo Brolly Dolly
 Posted: 12:21 - 02 Feb 2005 Post subject: |
Remember that you can't use a feeler gauge in iridium plugs either.
Hello BTW First post. Blackbird rider from Cumbria
I read you rules etc but I have to warn you that I'm dyslexic and can't always spot mistakes that the spell checker dont pick up. |
| John |
 John World Chat Champion
| Zoffo |
 Zoffo Brolly Dolly
| simon1221 |
| loply |
 loply World Chat Champion
 Posted: 15:51 - 02 Feb 2005 Post subject: |
AFAIK, and I have this from "Four Stroke Performance Tuning, A. Graham Bell" that a spark plug can not possibly make an engine producer more power or better throttle response.
He insists quite forcefully that the only difference from one spark plug to the next is lifespan and temperature rating. And im inclined to agree - A spark is a spark.
Ofcourse, if your existing spark plugs were the wrong temperature rating and caused preignition or the wrong gap size, that would be a different matter. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| simon1221 |
| map |
 map Mr Calendar
| mchaggis |
| simon1221 |
| mchaggis |
 Posted: 18:55 - 02 Feb 2005 Post subject: |
A smaller air gap would certainly make them spark sooner, advancing the ignition. Decreasing the resistance would lower the voltage needed to get a spark I think too. The resistance might not go up as much when they get hot either.
I wonder if they're really just cheating and advancing the timing.
They do go on about the shape of their electrodes altering the shape of the combustion kernel however, though why they don't just have 3 earth plugs instead I don't know.
If they could manage to get a more complete combustion by altering the shape of the kernel by the spark characteristics, they'd certainly have a case for what they say about fuel consumption too.
I think the main point of them really is that they won't decay and erode as quickly as cheaper plugs, and won't attract carbon fouling as easily. Two-stroke fouling is normally from too much oil I thought however.  ____________________ I must not be a troll...
Mmmm, Guinness
| loply |
 Posted: 20:18 - 02 Feb 2005 Post subject: |
Yeah to clarify spark plugs with 2 or 3 prongs do not produce 2 or 3 sparks!
They only ever produce one spark, but because there are three prongs effectively you get 3 times less wear, and therefore the prongs remain clean and good for the current flow. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| mchaggis |
The last post was made 21 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
