| Ziggy81scott |
 Ziggy81scott Borekit Bruiser
 Posted: 18:54 - 03 Jul 2015 Post subject: Rejetting advice needed |
Hi, I've recently replaced the standard airfilter with a K&N style filter, the bike runs ok however I've read online that it's recommended that you change the jet so that the mixture is slightly rich as this helps with engine cooling.
The question is, how much bigger do I go with the jet? And where can I buy jets from?
I've tried adjusting the mixture with little affect and fiddling with the mixture screw is really difficult as is right underneath the carb.
I bought a special tool for adjusting the mixture but on its first use it broke but managed to use a 1/4 ratchet with a screwdriver bit in a small socket. Even so it is incredibly hard to more the screw and pretty much impossible to count the turns, so any advice is welcome.
Cheers  |
| MCN. |
 MCN. Banned
| MarJay |
 MarJay But it's British!
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:30 - 03 Jul 2015 Post subject: |
I insist that you don't tell us what bike it is. That would make it far too easy to offer any sort of useful advice. ____________________ Biking is 1/20th as dangerous as horse riding.
| Ziggy81scott |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:35 - 03 Jul 2015 Post subject: |
K&N stuff is a waste of money.
Keep the motorcycle stock to have the best performance possible. Honda is a multi billion pound company, that invested quite a lot of money into developing your motorcycle. They are not stupid and they know what they are doing. All the GP racer stuff is not just about putting an expensive filter there.
I know I might get karma raped here, but the K&N filters are actually worse at filtering dirt/dust/etc. than the OEM filters. YES, people use K&N stuff in their race motorcycles, but then, those motorcycles could easily run fully opened intake as well, since they are not gonna do 50,000 miles on it, before they take it apart.
Paper filters are far the best at filtering particles, but there are motorcycles, with ram air intake mostly, that can't run a paper filter because when you run it in rain, the filter gets damp. Paper just disintegrates when it gets wet.
By the way, a ZX7R hiflo air filter is about £7.50, a K&N filter is abou £48.00, the difference in performance? Well, with the K&N stuff you need to re-jet the carbs (Dynojet kit - expensive or put it on DYNO and pay someone to fiddle with the carbs - not cheap) and the result is quite possibly the same, well worse MPG is expected. It's all funny because both filters are made out of quite the same material.
ALSO - running engine rich makes it run colder, but why would you want that + you do realize that rich mixture washes off the protective film of lubricant on the walls of the cylinder/s which ruins the rings and soon enough your engine's gonna start to run on oil rather than petrol?
Some engines are designed to run rich, but yours was not! ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Rogerborg |
 Rogerborg nimbA
| Kickstart |
 Kickstart The Oracle
 Posted: 21:58 - 03 Jul 2015 Post subject: |
The mixture screw only affects the fueling at tiny throttle openings; up to around 1/8th open, maybe 1/4 at most. While important to get a good idle and avoid it bogging down when you open the throttle it is probably the thing you touch last.
Main jet is the important bit. This controls the fueling around full throttle, and is the ultimate limit on how much fuel flows. With the main jet the idea is to do a plug chop. Basically put in a new plug and accelerate the bike hard up hill (fully throttle, revving it out). The hill just means you get more time on full throttle to make it easier. Then you pull the clutch and hit the kill switch (from full throttle), coast to a halt and remove the plug to check its colour. The try a larger or smaller jet and do it again.
Once that is done you can fiddle with the needle jet. The is a tapered needle, so you adjust the clip that locates it in the carb slide to alter its position, hence richening / leaning the mixture.
The above is a VERY brief description of it. It is possible to do it yourself, but it takes time.
For an overview of a slide carb (although aimed at the Dellorto ones, the basics are the same):-
https://www.bikechatforums.com/viewtopic.php?t=17124
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Rogerborg |
 Rogerborg nimbA
| Ziggy81scott |
 Posted: 22:33 - 03 Jul 2015 Post subject: |
Thanks Kickstart. Sound advice  |
| Ziggy81scott |
 Posted: 22:55 - 03 Jul 2015 Post subject: |
Ok. If you were me, considering I've put this airfilter on and already messed with the mixture, what would you do now?
Do I continue messing about with jets etc or put it back to stock setup?
The whole reason for tuning the carb was to try to squeeze an extra 5 mph out of the top speed or to create enough power so that I could put a 16 tooth front sprocket on with the aim of adding a bit more top speed.
The trouble with the bike is on big A roads the bike is running flat out for long periods, which doesn't do it much good. I like to tour on the bike and have been on 150 mile rides already. Having been a lorry driver I'm aware of getting in the way on these A roads so want to avoid thrashing the crap out of it but stay out of everyone's way.
I plan to do my test asap but due to lack of funds I can't yet so I'm stuck with a 125 for now. I avoid where possible bigger roads for these reasons but on long tours it's impossible to avoid them completely. It annoys me that I can't enjoy myself while going at my own pace without being in a vulnerable position due to cars and lorries being up my arse pushing me to get out their way. It's a bit of a pisser really what with having no money, hence my desperation to get more speed out of the darn thing. I appreciate your advice  |
| RhynoCZ |
 Posted: 23:07 - 03 Jul 2015 Post subject: |
You wanted what now?  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ziggy81scott |
| RhynoCZ |
 Posted: 23:13 - 03 Jul 2015 Post subject: |
You sir, need a bigger motorcycle or a lot more than just a posh air filter.
Is this what we are talking about?:
https://icaruswept.com/wp-content/uploads/2015/01/Honda-CD125-T.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ziggy81scott |
 Posted: 23:17 - 03 Jul 2015 Post subject: |
That's a newer version, but yes that's the bike and yes I agree I do need a bigger bike. Money is always the problem for me  |
| Rogerborg |
 Rogerborg nimbA
| RhynoCZ |
 Posted: 23:25 - 03 Jul 2015 Post subject: |
This might be a stupid question, but do you actually lay down on the bike, when you want to go fast, or you just sit there, being a huge air brake?
You'd be surprised how fast a motorcycle can go, when you put your chin on the tank.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ziggy81scott |
| Old Git Racing |
 Old Git Racing World Chat Champion
| Ziggy81scott |
| RhynoCZ |
| Kickstart |
| Ziggy81scott |
| RhynoCZ |
 Posted: 23:44 - 03 Jul 2015 Post subject: |
Au contraire, larger rear sprocket will make it easier for the engine to spin the wheel. The premise is, that the 5th gear (or what the top gear is) has very long gear ratio to keep the revs down at high speed = to make the MPG better. With stock final drive gear ratio, the engine will never get to the rev limiter at the top gear, not on a commuter.
Imagine a mountain bike. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ziggy81scott |
The last post was made 11 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
