Riding without a speedometer - how do I not get in trouble?
Wonko The Sane
PostPosted: 13:26 - 23 Jul 2015    Post subject: Riding without a speedometer - how do I not get in trouble? Reply with quote
So, riding home last night, noticed that the speedo wasn't reeding, checked that the speedo cable was not about to drag or get caught anywhere (it's happily still attached at both ends) had to continue home
New cable on order, assuming it's just the cable that's failed.
Found it strangely liberating riding along not looking at the speedo (no point) even though I was having to guess my speed based on gear + engine speed or other traffic and again this morning.
Anyone else found this?
any advice for keeping my license clean while I wait for my new cable?
PostPosted: 13:28 - 23 Jul 2015    Post subject: Re: Riding without a speedometer - how do I not get in troub Reply with quote
Got a smart phone you can use with a GPS app?
Otherwise, in the past I've got used to what sort of rpm is what speed and gone from that.
I'd get stuff apart and check the problem. Could be plenty of bits at fault.
DrSnoosnoo
PostPosted: 13:28 - 23 Jul 2015    Post subject: Reply with quote
I think, 4k revs in third and you'll be safe in the 30s
4k in fourth and you'll be ok in the 40s
I'll double check when riding home and give you some revs for gears for speed.
Also as for the cable, they snap inside. When mine broke it was still attached but the internals went. 95% it'll be the cable, the other 4.9% the drive on the front wheel. 0.1% ghosts and or aliens
Irn-Bru
PostPosted: 13:32 - 23 Jul 2015    Post subject: Reply with quote
It's fine, you could pass an MOT with no speedo, they have no way of knowing if it works.
Recently I have started taping mine up due to wearing a chest mounted camera which shows my speedo perfectly. So to avoid a hefty amount of editing if something interesting happens I just taped it up. I really much prefer riding this way, it's one less distraction Thumbs Up
weasley
PostPosted: 13:35 - 23 Jul 2015    Post subject: Reply with quote
I had a speedo cable fall out of my Thundercat and another bike with a smashed up speedo. I just used the speed of whatever traffic was around to calibrate my rev counter, being especially prudent around speed cameras.
PostPosted: 13:48 - 23 Jul 2015    Post subject: Reply with quote
A non-working speedo, yes. Need one fitted however.
Monkeywrenche...
PostPosted: 16:26 - 23 Jul 2015    Post subject: Reply with quote
No Speedo required for a bike MOT, not mentioned in the manual at all.
andym
PostPosted: 16:32 - 23 Jul 2015    Post subject: Reply with quote
Take Paddy's word for it, I've seen the proof
PostPosted: 16:33 - 23 Jul 2015    Post subject: Reply with quote
MOT no, construction and use regulations yes.
https://www.legislation.gov.uk/uksi/1986/1078/regulation/35/made
Should you get pulled for speeding just don't give them any reason to want to look at your speedo.
You can get a push bike computer / speedo thing for less than a fiver if you want to take (some of) the guess work out of knowing how fast you're going. Thumbs Up
Monkeywrenche...
PostPosted: 17:30 - 23 Jul 2015    Post subject: Reply with quote
https://www.motinfo.gov.uk/htdocs/m1i00000001.htm
if its not in there its not tested/can't fail
Az
PostPosted: 18:05 - 23 Jul 2015    Post subject: Reply with quote
https://www.gearingcommander.com
Use the above site to figure out what revs you need to be sat at, in which gear, to go 'x' speed.
thx1138
PostPosted: 18:10 - 23 Jul 2015    Post subject: Reply with quote
stopped working on my CRF after I dropped it in a puddle
eventually came back, but, rarely ride over 40mph with the current tyres anyway
andyscooter
PostPosted: 18:17 - 23 Jul 2015    Post subject: Reply with quote
Passed (I know ) my second cbt without one as it snapped on the carpark bit
delsol
PostPosted: 18:44 - 23 Jul 2015    Post subject: Reply with quote
Makes a lot of sense till main speedo is sorted properly, I'd do that for a fiver and enjoy some peace of mind.
Better than a tug\hastle from popo, take it you could possibly argue compliance with construction and use regs ???
PostPosted: 19:20 - 23 Jul 2015    Post subject: Reply with quote
I've got a very flexible tester. The requirements for my road legal track bike are horn, speedo and plate. If I go without one of them he will fail it.
I'd not risk going anywhere for an MOT without a speedo, however I may be wrong and willing to admit it. C&U though, got a tug for non working speedo in IoW... Laughing
PostPosted: 19:24 - 23 Jul 2015    Post subject: Re: Riding without a speedometer - how do I not get in troub Reply with quote
Follow someone at a set speed and observe your engine revs in top. Hope that they are not a bastard.
Shaft
PostPosted: 23:16 - 23 Jul 2015    Post subject: Reply with quote
He's not that flexible then, at no point do you test a speedo, or fail a bike that hasn't got one.
The only reason I look at one is to note the mileage, because the odometer is normally incorporated in the speedo; if it hasn't got a speedo or an odometer, I just put '0' in the box and it still passes.
You're right when it comes to C&U though.
edit: there's also an option for testing a vehicle without a number plate....
PostPosted: 23:40 - 23 Jul 2015    Post subject: Reply with quote
Speedo failed on one bike, and as a pain to change the cable I rode it using the rev counter and worked out the speed from that in top gear. Did this for quite a while
K
moonzoomer
PostPosted: 23:49 - 23 Jul 2015    Post subject: Reply with quote
That depends on where the MOT test is conducted, here in NI the speedo is tested (at tester discretion) and must be calibrated in MPH and KPH, add-on MPH/KPH stickers on the glass speedo cover are no longer accepted. Taking the MOT aside the cops could take you to the cleaners as regardless of an MOT cert it is illegal to ride without a speedo on a motorcycle exceeding 49cc in capacity.
Ariel Badger
PostPosted: 23:53 - 23 Jul 2015    Post subject: Reply with quote
Halfords cycle speedo about £20 should keep your licence clean, takes about half hour to fit.
PostPosted: 08:06 - 24 Jul 2015    Post subject: Reply with quote
Fancy.
I got one for something like £3 from Tescos for my CCM.
As the speed rose, it'd often show exactly half or a third the speed, but that wasn't a big issue as you could easily tell the difference between 50mph and 25mph.
My more expensive cateye one was fine to 150mph (at Snetterton, actually) on the zx9.
fatjames
PostPosted: 08:23 - 24 Jul 2015    Post subject: Reply with quote
I fitted heated grips last winter and the controller is right in front of my speedo. I don't know what speed I'm doing until around 60, so I just make sure I'm going at least that fast Laughing
Wonko The Sane
PostPosted: 12:15 - 24 Jul 2015    Post subject: Reply with quote
New cable is here, looks quite short but might just be how it looks
Hopefully get it fitted before Monday
those "your're doing this speed" signs at the side of the road are fairly useful :p
PostPosted: 15:33 - 24 Jul 2015    Post subject: Reply with quote
Interesting, no doubt riding to MOT centre would raise eyebrows of the po po though Sad
The last post was made 11 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 134.74 Kb
