Broken bleed nipple on caliper - cost to remove?
owl10
PostPosted: 22:11 - 03 Aug 2015    Post subject: Broken bleed nipple on caliper - cost to remove? Reply with quote
Hi All,
One of my caliper bleed nipples has not only seized and broke, but there is also a snapped off point from one of those easy out things stuck in the centre now as well... (Doh).
Calipers are 4 pot nissins, non radial, from a bandit 1200 (fitted to a zx6r).
Clearly Im too potato to remove it myself, so is it worth paying some machine shop to do it, or simply chuck it and buy another pair of calipers?
How much would a machine shop likely charge for this kind of thing?
Owl
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
PostPosted: 22:18 - 03 Aug 2015    Post subject: Reply with quote
Try a banjo bolt with integral bleed nipple. Bleed the system down to the banjo then pump out the pistons a bit. Hold the calipe rso that the banjo is highest, crack the bleed nipple then have someone press the pistons back in one at a time lowest first. This should push any remaining air back out the nipple.
andys675
you can buy a banjo bolt with a bleed nipple in it, less than a tenner
davebike
PostPosted: 09:27 - 04 Aug 2015    Post subject: Reply with quote
Broke bleed nipple is almost impossible to repair well
As said get banjo bolt with bleed nipple or 2nd hand calliper
Dave
NC750Xdct + others at work !
[email protected]
Taught2BCauti...
PostPosted: 10:23 - 04 Aug 2015    Post subject: Reply with quote
Personally, I wouldn't trust it but if there's no fluid leaking from the damaged bleed nipple, you could probably bleed it from the banjo bolt if you can position the caliper so that the banjo is the highest point.
I have seen calipers that have had a seized bleed nipple forcibly removed, drilled out or otherwise bodged, leaving the seat, or the threads in the caliper body damaged, so I would recommend getting a replacement.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MaybeGuy
PostPosted: 10:52 - 04 Aug 2015    Post subject: Reply with quote
Why would you say that? It's probably easier than getting a snapped regular bolt out. It's even got a pilot hole there for you. I've drilled out a few without any problems. Much better than bolting some transformer shit with a bleed nipple to it.
bugeye_bob
PostPosted: 11:17 - 04 Aug 2015    Post subject: Reply with quote
https://www.fraserbrowneng.co.uk/store/index.php?route=product/category&path=60
MCN
PostPosted: 11:35 - 04 Aug 2015    Post subject: Reply with quote
It's a simply enough jobbie to drill out as there's a 'pilot hole' already drilled through a bleed nipple.
You only need to know the thread size (so you can determine the tapping size drill bit.)
You can determine that by measuring the diameter of the threaded section of a 'good' nipple you can remove from a similar calliper or by purchasing a new one (which you will have to do anyway.)
£65 for a kit is a bit expensive unless you don't have a clue.
You probably won't even need a tap if you carefully drill out the old fitting by incremental drill sizes. When the material is removed from inside a bolt it tends to weaken it's grip on the hole thread and can allow it to be dug out with a screwdriver.
If it all goes pear-shape then you can call an engineers to take over or possibly/probably cheaper to buy a 2nd hand calliper depending on how favourable an engineer's labour cost are.
The banjo and nipple would be my first option though and worry about a remedy later.
bugeye_bob
PostPosted: 11:48 - 04 Aug 2015    Post subject: Reply with quote
Buy kit, repair nipple, sell the kit on flea bay, works out cheaper then paying to get it repaired and you learn something along the way.
Major Doss
PostPosted: 12:14 - 04 Aug 2015    Post subject: Reply with quote
Whilst a decent engineer 'may' be able to successfully remove a snapped bleed nipple, with the remains of a super-hard eazi-out added into the mix, you can pretty much forget about it.
Like others have suggested, banjo bleeder. Thumbs Up
MCN
PostPosted: 12:24 - 04 Aug 2015    Post subject: Reply with quote
With respect, one doesn't have to be an 'engineer' to hoi a broken bolt (which is basically what a bleed nipple is) out using the correct drill bit.
But if no confidence in one's prowess then a bike shop or an engineer's shop will do it easily. It is not a massive biggy/biggie rly.
The easy-out part I agree with as they are the Devil in the wrong hands.
I would prefer to drill out rather than risk breaking an easy-out in.
Still not sure why they are called 'Easy-Out'. Very Happy
Major Doss
PostPosted: 14:17 - 04 Aug 2015    Post subject: Reply with quote
The 'hoi'-ing of a bolt is not the issue. Not damaging the finely machined seat underneath however, is. Hence trusting it to someone who will have a rake of kit to hand, to deal with it sympathetically. If that person is you, hoi away! Thumbs Up
MCN
PostPosted: 14:41 - 04 Aug 2015    Post subject: Reply with quote
I agree baaaat....
The bleed nipple has a relatively long un-threaded 'shank' before the seat/chamfer end of the nipple. So that should actually prevent the drill hitting the calliper seat as the un-threaded part will spin when the last threads are cut.
If using the 'correct' tapping size drill of course.
But not a great job for the in-experienced/mongtarded.
SO 'ONLY A FOOL AND HIS TOOL BREAKS THE THREE MIL RULE.'
Embarassed
Major Doss
PostPosted: 15:04 - 04 Aug 2015    Post subject: Reply with quote
Fair enough! Thumbs Up
bikenut
PostPosted: 15:57 - 04 Aug 2015    Post subject: bleed nipple Reply with quote
I have successfully removed several sheared off bleed nipples ( as well as other "bolts" etc. even m/c chewed screws!! ) using the mig welder method, even ones that are below the surface alloy somewhat.
Remove caliper and strip all easy heat damaged rubbers etc.
Clean remains of steel nipple as best as possible, bright steel.
Mount in holding devise and set welder up ( on mine, 100amp blue machine mart machine now 26 years old, and paid for its self many times over ) , max power, wire speed 6 ish, good gas flow ) .
Prepare a 8 or 10 mm bolt, by tapering the end to be welded to the nipple remains.
Assistant holds the bolt in place, and welder positioned for a 4 to 5 second "burst".
Allow to cool, then repeat the parts not welded to the nipple.
I usually weld one side, allow to cool, then weld the other, allow to cool and fill in the gaps one at a time.
ALLOW TIME TO COOl between each step.
When confident, try undoing the "bolt".
If it shears off again, repeat.
Some but not much melting of the alloy may take place so adjust your technique accordingly.
This method has worked for me many times, not that I am in the habit of shearing nipples, usually the previous owner does that for me.
Old calipers can be problematic, so I strip of all easy damaged rubbers etc, and use heat to expand the alloy, then gently but firmly try and undo the nipple.
Water is a great lub for this!!!!!!!
Cheap, biodegradable, washes away corrosion ( caused by water in the first place ) etc.
Karma Karma Karma
Get the easy out remains as best as possible.
Why use a brittle easy out on a well corroded in nipple???????
left hand drill??
nuts about bikes
PostPosted: 18:48 - 04 Aug 2015    Post subject: Reply with quote
Bleed nipples tend to break up when drilling which can snag the drill and snap it off. No matter, if you feel confident then take a drill to it, I've done several but i figured that the OP wouldn't be asking if he had the confidence to tackle that.
kramdra
PostPosted: 21:23 - 04 Aug 2015    Post subject: Reply with quote
Used callipers are cheap
Its not a massively difficult job to do and would not cost much to have it done either.
I would not bodge brake calliper with a dodgy bleed nipple.
owl10
PostPosted: 00:01 - 05 Aug 2015    Post subject: Reply with quote
Thanks for all the replies.
I've got 2 pairs of tokico s awaiting refurbishment hiding somewhere in the garage, as well as the damaged nissins though realistically no time for doing a proper job, far too many other projects going on (car, house, baby, work).
Mechanically I'm not usually so inept, and would normally take on this kind of thing. perhaps I'm just getting lazy now (hence using easy out in first place...)
Bleed banjo sounds good for a temporary measure, longer term I'll likely sell all three sets to pay for a decent refurbished set.
Anyone on here refurb calipers?...
The last post was made 11 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.71 - MySQL Queries: 16 - Page Size: 115.34 Kb
