hid kit, do i need the power adapter?
Taught2BCauti...
PostPosted: 10:21 - 07 Aug 2015    Post subject: Reply with quote
Normally, the HID bulb connects only to the ballast, and the ballast only needs a good 12v supply and an earth.
On metal-cased ballasts, you normally need a separate earth to the casing.
I usually find that the output from a battery charger (or a weak battery) isn't powerful enough to allow the initial arc to strike, in which case the HID bulb will just flicker.
(I believe the bulb needs 20kv to strike, then 12kv to run.)
Try connecting an earth to the ballast casing, as well as the black wire, and hooking it up to the bike's battery whilst the engine is running.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 16 - Page Size: 34.56 Kb
