High speed brake vibration when they're hot
stonesie
PostPosted: 19:41 - 06 Aug 2015    Post subject: High speed brake vibration when they're hot Reply with quote
As above, I was getting quite a strong vibration from the front brakes on my track day at Cadwell (slowing from Park straight into Park corner) after a couple of laps, nothing at lower speeds or on the road.
Pads are factory fit with nearly 9K on them and I would estimate 60% worn.
Discs look fine, bit of rainbow heat colouring but no visible warp.
Any ideas?
andys675
PostPosted: 20:11 - 06 Aug 2015    Post subject: Reply with quote
I do remember triumph wanting a dial gauge using when reporting warpage under warranty, anything over 0.5mm iirc they would replace, so you're not likely to see that level of warpage with the naked eye
stonesie
PostPosted: 20:17 - 06 Aug 2015    Post subject: Reply with quote
To either the dealer or eBay then for a DTI...
MCN
PostPosted: 20:37 - 06 Aug 2015    Post subject: Reply with quote
My 2p.
Used pads might/may have caused vaporised pad material/other shit to condense in the perforations.
It may be causing them to skip under braking heat and pressure.
Clean out the holes in the disc.
I had a bike that would squeal like a biatch when ever the pads were about 1/2 worn.
Just a quickie before you spend a small fortune on new pads.
You'd be cleaning up before new pads anyway.
The last post was made 11 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 16 - Page Size: 40.94 Kb
