Emergency Breaking
DukeRed
PostPosted: 22:54 - 07 Feb 2005    Post subject: Emergency Breaking Reply with quote
The stoppie thread got me thinking, what is the quickest way to stop your bike?
If the back come off then you loose rear breaking but to not bring the rear up you wouldn't use all you'r front break so stops slower.
I remember thinking in my CBT that 50% on front and back didn't seem very emergency. Is it even possible to use all the breaking force?
What about pumping the break like in cars?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
PostPosted: 23:00 - 07 Feb 2005    Post subject: Re: Emergency Breaking Reply with quote
In my opinion:
Stopping with the rear just about to leave the ground.
At this point the rear brake will probably just make the rear slide, so won't be any use at all, it may make things worse as you may ose the gyroscopic stabilty the spinning rear gives.
Being able to stoppy is actually excellent practice for this.
Pumping the brakes seems like a very bad idea.
PostPosted: 23:02 - 07 Feb 2005    Post subject: Reply with quote
If you want to pump the brake like in a car - you can try it if you like.
Actually because of the way the forces are transmitted along the length of the bike, the most efficient way to brake is actually to keep the rear just off of the floor. Any higher and the energy that should be going into slowing the bike goes into keeping the rear in the air.
Ideally you want to keep the rear on the floor to stay in perfect control of the machine however.
Mick Doohan - the oft tested master of late braking - used to be heading towards the corner apex with the rear tyre around an inch off of the floor if he was particularly dicing with an adversary.
However, you or I are not Mick Doohan (unfortunately).
Stoppies don't allow you to steer (unless you are the guy from "Roue 2 Oeuf" on the Judgement Day 2 DVD) and so I reckon its closer to 90% on the front and 10% on the rear (which will lock easily due to the forces shifting from the rear to the front wheel).
Well, thats my stance on the subject anyway! Wink
craigT19
Jolly Green Giant
I tend to slide back in the seat slightly and push hard on the pegs to keep the rear stable so i can use the rear brake and the front.
i would say 60/40 front/rear to start with untill i get a feel for the brakes (maybe a few seconds) but i end up around 80/20 with the back just starting to skip alittle
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
mchaggis
PostPosted: 23:05 - 07 Feb 2005    Post subject: Reply with quote
The maximum rate of braking occurs when both wheels are simultaneously on the point of locking. The problem is that you can exert a lot more force to the rear with your foot than you can to the front with your hand. Add the weight transfer to compound this, and the back locks remarkably easily.
If you can get them there without locking the back way before the front or flipping, I'd be impressed.
I must not be a troll...
Mmmm, Guinness
PostPosted: 23:07 - 07 Feb 2005    Post subject: Reply with quote
As mentioned in the stoppy thread; a decent bike with decent tyres can lift the rear without losing traction from well over a ton.
This means that the limit is moved to the amount of energy spent lifting the rear.
At the point that the rear is about to lift the rear brake will not be able to do anything usefull as the rear tyre should not have decent traction, therefore the rear brake is useless.
DukeRed
PostPosted: 23:08 - 07 Feb 2005    Post subject: Reply with quote
Cool, good to know that. Will try it on the way to college tomorrow Smile.
So is the rear break good for anything other than slow speed manouvers and trimming speed in corners?
craigT19
Jolly Green Giant
PostPosted: 23:10 - 07 Feb 2005    Post subject: Reply with quote
When i was in france one of the guys (riding a gsxr1100wp) would test his brakes by riding and slamming the anchors on...untill he locked the brakes so he new just how far he could push them, bearing in mind he did it to the front as well as the rear...i was fecking impressed.
To be honest tho the guy was insane Laughing awsome rider tho
craigT19
Jolly Green Giant
PostPosted: 23:12 - 07 Feb 2005    Post subject: Reply with quote
when u use the rear u make the arse end sit down, moving the center of gravity back, and so easing the pressure of of the front...which in the wet or in poor grip conditions...is a bloady good idea in my humble oppinioun Laughing
mchaggis
Maybe 100% weight transfer to the front is the way to do it then. Very Happy It's entirely probable that most brakes aren't set up to allow simultaneous locking without the rear coming up from the road anyway.
Mmmm, Guinness
PostPosted: 23:14 - 07 Feb 2005    Post subject: Reply with quote
Do remember that bad conditions, be it road surface, damp, big rake, low performance or low tempreture tyres etc, can cause the front to slide before you start a stoppy.
Therefore brake with increasing hardness progressively. Don't suddenly whack the front on full force. Make sure you're on a clear road and be ready to let go the front if it does go slidey Thumbs Up.
mchaggis
PostPosted: 23:16 - 07 Feb 2005    Post subject: Reply with quote
Well, if the road or the tyres are crap enough that you will slide the front before the rear comes off the ground, then you need to make use of the rear brake to get optimum braking. Of course, with crap conditions, you're even more likely to lock the rear, just this doesn't matter half as much as locking the front if you're doing anything other than a dead straight line.
Mmmm, Guinness
DukeRed
PostPosted: 23:18 - 07 Feb 2005    Post subject: Reply with quote
Maybe this should be workshop but is it really unhealthy that my forks bottom out very easily? Can I still stoppie (In the name of good breaking)
Might put some heavier oil in when I've got some money.
PostPosted: 23:22 - 07 Feb 2005    Post subject: Reply with quote
With decent tyres I would probably try and still just the front pretty much.
But putting your weight back will take grip from the front and make it more likely to slide.
However if there is an excess of grip it will mean the rear will rise later, so will mean better decceleration.
Frost
PostPosted: 23:27 - 07 Feb 2005    Post subject: Reply with quote
It will effect handleing. your bike will feel stable on long bends and when upright, but might feel unstable at turn in. It is only dangerous if somethough grounds out on the bike, or the bottoming out of the forks effects handling mid corner in a way you werent expecting.
Heavier oil, and more oil will help to stiffen them up Thumbs Up
The stoppie question is just like wheelying. Will you accelorate quicker by popping a wheelie, or by keeping the front wheel down?
For the answer, look at tractor pulling. Ideally the front end will be light or ever so slightly off the ground with all energy being focused into moving forwards, rather than rasing the front, or pushing it into the ground. with braking the opposite is true. Having the rear on the ground gives you an element of control and will allow ou to stop more effectively in Most situations. getting the rear off the ground can stop you quicker, but you need the grip and skill to pull it off.
jaffa
PostPosted: 23:53 - 07 Feb 2005    Post subject: Reply with quote
emergency breaking
And there I was, thinking this would be a thread about how to dismantle ones bike for spares in an emergency.
jaffa - all juice and no pips
mchaggis
PostPosted: 00:10 - 08 Feb 2005    Post subject: Reply with quote
https://www.motorcyclerev.com/ten/crash/endoops.mpg
You just need to be careful. Confused
Mmmm, Guinness
The last post was made 21 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.08 - MySQL Queries: 16 - Page Size: 102.64 Kb
