| Motorhate |
 Motorhate Nearly there...
| Matt B |
 Matt B World Chat Champion
| Casper |
 Casper World Chat Champion
 Posted: 17:30 - 24 Sep 2015 Post subject: |
Make a couple of foot loom and move it to somewhere that will get a bit air flow. All you want is the male and female side of your connector and whatever length of wire you need. You can get a sheath for the wire but i prefer loom tape. You should get it all here
https://stores.ebay.co.uk/towzatronics/ |
| stinkwheel |
 Posted: 17:57 - 24 Sep 2015 Post subject: |
The mouldings for the multi-pin connectors tend to be unique to each reg/rec.
BUT
The connectors inside them are not. You can buy those over the counter.
You can, with either the proper terminal removal tool or patience and a small screwdriver wiggle the connectors out of the moulding.
So. Neatest way I can think of doing the job.
1) Mark the wire positions in the moulding.
2) Wiggle the wires out of the moulding with terminals attached.
3) Snap the terminals into a new, 6-wire connector block.
4) Attach the other end of the connector block to a new, multi-core cable. The stuff they sell for towbars is ideal, works out very neat and saves wrapping.
5) Attach new terminals for connectors to the far end or your multi-core cable and snap them back into your original moulding.
This place also has most things you'd need. Watch the postage and VAT!
https://www.vehicle-wiring-products.eu ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Motorhate |
| Fizzer Thou |
 Posted: 18:21 - 24 Sep 2015 Post subject: |
Pictures of the rectifier and its present location would be useful.Then work out where you would like to relocate it to  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Vincent |
 Vincent Banned
| andys675 |
 andys675 World Chat Champion
| stinkwheel |
 Posted: 11:30 - 25 Sep 2015 Post subject: |
A lot of factory customs/cruisers have the reg/rec mounted on the bottom of the frame near the front engine mounts as standard, presumably because that's where Harley put them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Oldie |
 Oldie Brolly Dolly
 Posted: 17:19 - 25 Sep 2015 Post subject: |
The early Deauvilles went through reg/recs like crazy. Used to try using thermal paste and also run an extra neg lead direct to the battery (but I can't remember exactly why ) |
The last post was made 10 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
