Motherboard abnormally hot under load
notbike
PostPosted: 13:05 - 30 Sep 2015    Post subject: Motherboard abnormally hot under load Reply with quote
So after switching out my dead GPU for a much better one, my temps have drastically changed, especially my motherboard.
When I had the AMD Radeon 7950 my idle temps looked like this:
CPU 35-40ºc
Motherboard 30-35ºc
GPU ~30ºc
Under moderate to high load the CPU would rise to 60, the motherboard would hit maximum 40 from I guess the ambient temperature rise in the case, and the GPU could hit up to 70 but never really over 70.
Since installing the GTX 980Ti my idle temps have all increased by around 5 except the GPU temp which is currently at 28ºc (Even that doesn't add up).
I don't mind the idle temps having increased a little, but what I find alarming is that my motherboard has shot up by 30ºc when under moderate/high load since the GPU switch.
When on maximum GTA5 graphics settings at 60fps (Frame scaling off) my GPU will hit 80 after a while. CPU stays around low 60s, but the motherboard has hit 74 at one point which was alarming. My friend's motherboard during the same gaming session on maximum graphics with a GTX 980 stayed at a solid 32ºc, while other friends reported not going above 40.
When I checked temps in OpenHardwareMonitor it gave me 3 readings from 3 motherboard sensors. This was immediately after closing GTA5 so temps were falling again. Two sensors read 33 and 34, but one of them was reading low 60s.
No idea where that sensor was placed, but even if it was near the GPU, the GPU was already falling below 40s at that point, and the CPU was falling to low 50s. It can't have been another component causing it to read almost twice the temp of the other motherboard sensors. I'm thinking either the sensor is dodgy or a part of my motherboard is getting very hot.
tl;dr Why is my motherboard heating up so much when install new gfx card?
Also as a side note, the PC was spotless at the time of taking these temps so it's not dust and I have a decent push/pull airflow with plenty of fans.
Aff
PostPosted: 13:40 - 30 Sep 2015    Post subject: Reply with quote
Surely you have answered your own question?
You have said that you have bought a more powerful GFX card that is running at lower temps, meaning that it is doing a better job of getting rid of the extra heat than you last one.
You've also said that its just one sensor that's getting hot.
So it seems quite likely that your card is dumping a lot of hot exhaust onto the area where one of the thermistors is, making it look like the board is hot. I would also imagine there is a chunky ground plane or something near by retaining the heat for a lot longer than the GFX card, which is made to get back to ambient ASAP.
Electric Bike Project
notbike
PostPosted: 13:53 - 30 Sep 2015    Post subject: Reply with quote
Yeah it's just been a bit confusing trying to figure it out. Was probably looking for some confirmation to see if what I was thinking was completely wrong or not. Thinking so long as it doesn't blow up or melt I guess it'll be fine Laughing
CaNsA
PostPosted: 14:51 - 30 Sep 2015    Post subject: Reply with quote
What motherboard?
notbike
PostPosted: 23:45 - 30 Sep 2015    Post subject: Reply with quote
CaNsA wrote:
What motherboard?
Alienware 07JNH0
Also, new symptom of something else going wrong (fuck sake) - PC randomly restarts mid-game in CSGO randomly. Nothing else has triggered a random restart.
No malware found, no driver issues found, not overheating during CSGO.
Event viewer doesn't give errors prior to the critical power error.
3 times it's happened so far.
CaNsA
PostPosted: 00:02 - 01 Oct 2015    Post subject: Reply with quote
Righto,
Drop a stick of ram, test each one individually.
If that turns up nothing then take the whole rig to a mates house and test out each bit.
GFX
CPU
RAM
PSU
If they are all good then start testing your motherboard with the other bits.
Add in his RAM, CPU ( if possible), GFX and PSU.
I reckon the PSU is buggered, or possible the ram.
notbike
PostPosted: 00:06 - 01 Oct 2015    Post subject: Reply with quote
CaNsA wrote:
Righto,
GFX
CPU
RAM
PSU
Thanks man I'll get on it when I get time off work.
Accuhaler
PostPosted: 00:27 - 01 Oct 2015    Post subject: Reply with quote
Don't bother with all that shit, swapping shit around. You've already gave us the answer, you upgraded your GPU.
It dispensing heat alot better then your old one, a section of your MB is taking it. Standard reaction of a computer to restart to reduce the heat on a component.
Increase the inflow and exhaust of air from your tower.
CaNsA
PostPosted: 01:25 - 01 Oct 2015    Post subject: Reply with quote
If the old GFX popped, who knows what has happened to the other parts...
Accuhaler
PostPosted: 02:26 - 01 Oct 2015    Post subject: Reply with quote
CPUs and GPUs have dedicated fans, onboard sensors don't so...
Living among fucking morans
CaNsA
PostPosted: 02:34 - 01 Oct 2015    Post subject: Reply with quote
1. Only morons call it a "tower"
2. Oh the irony.
temeluchus
PostPosted: 02:42 - 01 Oct 2015    Post subject: Reply with quote
Fuck the fault finding, amma pull an answa outta my ass ya morans.
temeluchus
PostPosted: 02:45 - 01 Oct 2015    Post subject: Re: Motherboard abnormally hot under load Reply with quote
That's assuming it actually is and you don't have a borked sensor. The graphics card doesn't draw a great deal of current from the motherboard so I can't see it melting anything.
Any unnecessary overclocking?
notbike
PostPosted: 21:35 - 01 Oct 2015    Post subject: Re: Motherboard abnormally hot under load Reply with quote
Nope, nothing is overclocked at all. Checked my 12v voltage using HWInfo and it's fluctuating 14-16v, is this normal?
temeluchus
PostPosted: 00:19 - 02 Oct 2015    Post subject: Reply with quote
the problem could be that the new card could be venting heat right onto the sensor. Or any number of things.
12v is only nominally 12v it will fluctuate.
orac
PostPosted: 07:23 - 04 Oct 2015    Post subject: Reply with quote
I haven't heard anything great about alienware (owned by dell, and their kit isn't exactly great) stuff. CPU was running a bit hot to start with.
I would suspect that the is a regulator issues on the motherboard, most likely a heat sink not seated correctly. although the GPU will get most of its power from its ATX connector some power will come from the PCIe port and thusly the mother board has to supply it.
what CPU are you using. I personally cant see the ram making a huge difference as pretty much everything in the past 10 years or so are using IMC so nothing other than the RAM and CPU are involved there.
I would have a good look round and make sure you didn't nock a heat sink while installing the new card causing it to become unseated.
the rest of the machine specs may well be helpful and if you can with the help of a friend if needs be get some temperature readings of the heat sinks so we can work out if it actually getting that hot or just a faulty sensor. @ 60 degree even an incorrectly seated heat sink will get pretty hot.
prawny1
PostPosted: 19:01 - 25 Oct 2015    Post subject: Reply with quote
did you disturb the chipset heatsinks? they use different themal interface material than cpu's etc, generaly they are a fit once phase change material that sets when cooled so if you disturb the bond the temps will never be the same.
I sometimes remove the chipset heatsinks flat the mating surface to improve contact area and apply decent thermal adhesive to re secure them.
One I found to work ok is the halnziye heatsink plaster it actually dried flexible a bit like silicone and improved temps a fair bit, it works great on laptop gpus for bonding shims in place.
Another thing to consider is that the gpu being more powerful can allow for greater bandwidth/ through put on the other components.
Are you using the dual graphics feature on your motherboard? have you cleaned and updated your drivers to make sure no software is conflicting?
hellkat wrote:
The last post was made 10 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.34 - MySQL Queries: 16 - Page Size: 104.54 Kb
