File with data item keys convert to fixed format.
PostPosted: 14:46 - 19 Oct 2015    Post subject: File with data item keys convert to fixed format. Reply with quote
Hi Guys,
I have a file in the format...
aaaa=xxxxx, bbbb=xxxxxxxxx, cccc=,xxxxxxxxx, dddd=xxxxxx
aaaa=xxxxx, bbbb=xxxxxxxxx, dddd=xxxxxx
i.e. each data item is prefixed by a code identifying what item type it is. With a etc. being item tag and x being data.
I want it in something excel friendly,
e.g.
Code:
aaaa                   bbbb                  cccc           dddd
xxxx                   xxxxxxxxxxxx          xxxxxxxxxxx    xxxxxxxx
Any ideas?
Stowelly
PostPosted: 14:49 - 19 Oct 2015    Post subject: Reply with quote
CSV ?
aaaa, bbbb, cccc, dddd,
xxxxx, xxxxxxxxx, xxxxxxxxx, xxxxxx,
PostPosted: 14:51 - 19 Oct 2015    Post subject: Reply with quote
Stowelly wrote:
CSV ?
Not all records have all data items. it screws it up.
Stowelly
PostPosted: 14:53 - 19 Oct 2015    Post subject: Reply with quote
its fine to have blank fields in csv just have xxxx,,xxx,,
or just use 0 / null
PostPosted: 14:58 - 19 Oct 2015    Post subject: Reply with quote
The field tags are not present if the value is null, how do I assign which tag goes where?
PostPosted: 15:47 - 19 Oct 2015    Post subject: Reply with quote
Sample data with the erroneous "cccc=," commas stripped but the whitespace around commas left in.
Code:
aaaa=xxxxx, bbbb=xxxxxxxxx, cccc=xxxxxxxxx, dddd=xxxxxx
Code:
use strict;
my $columnHeaders = 'aaaa,bbbb,cccc,dddd';
my @lookForTags = split(',', $columnHeaders);
my $numberOfTagsToLookFor = @lookForTags;
print $columnHeaders . "\n";
while(<STDIN>) {
    chomp;
    s/\s*,\s*/,/g;
    my @foundTags = split(",");
    my $foundTag = 0;
    my @foundTagAndData = split("=", $foundTags[$foundTag++]);
    for(my $i = 0; $i < $numberOfTagsToLookFor; ++$i)  {
        if(@foundTagAndData[0] eq $lookForTags[$i]) {
            print @foundTagAndData[1];
            @foundTagAndData = split('=', $foundTags[$foundTag++]);
        if($i < $numberOfTagsToLookFor - 1) {
            print ",";
    print "\n";
Code:
$ perl create-csv.pl  < sampleData.txt
aaaa,bbbb,cccc,dddd
xxxxx,xxxxxxxxx,xxxxxxxxx,xxxxxx
xxxxx,xxxxxxxxx,,xxxxxx
,,xxxxxxxxx,xxxxxx
https://i.imgur.com/y6r5o7I.png
PostPosted: 16:15 - 19 Oct 2015    Post subject: Reply with quote
Code:
Code:
use strict;
while(<STDIN>) {
    chomp;
    s/\s*,\s*/,/g;
    my $foundTag = 0;
            print ",";
    print "\n";
Code:
aaaa,bbbb,cccc,dddd
,,xxxxxxxxx,xxxxxx
This looks promising, I can't see the picture, work block more or less everything.
Is it as simple as putting the specific headers in replacing a,b,c,d etc.? I have 117 are there any width restrictions in the input script?
This looks too easy I'm used to mainframes where you have to specify all manor of file/item lengths.
Cheers Thumbs Up
PostPosted: 16:23 - 19 Oct 2015    Post subject: Reply with quote
It's running, the input file is 50Mb so this might take a while!
PostPosted: 16:37 - 19 Oct 2015    Post subject: Reply with quote
One small issue,
It only picked up the first 2 data items, I'm guessing the script reads through each record and if the input data is in the different order to the headers in the script it will miss some out, anyway round this? I don't have a specific order of these fields nor do I know if they are in such an order (I think they are though.)
PostPosted: 16:42 - 19 Oct 2015    Post subject: Reply with quote
I also tried using just a space selection of about 8 or so fields I was interested in this returned nothing, do I need to have a heading for each field?
PostPosted: 17:01 - 19 Oct 2015    Post subject: Reply with quote
Out-of-order sample data.
Code:
aaaa=xxxxx, cccc=xxxxxxxxx, bbbb=xxxxxxxxx, dddd=xxxxxx
bbbb=xxxxxxxxx, aaaa=xxxxx, dddd=xxxxxx
dddd=xxxxxx, cccc=xxxxxxxxx, bbbb=xxxxxxxxx
Less efficient script.
Code:
use strict;
while(<STDIN>) {
    chomp;
    s/\s*,\s*/,/g;
    my $foundTag = 0;
    for(my $i = 0; $i < scalar @lookForTags; ++$i)  {
        foreach my $foundTag (@foundTags) {
            my @foundTagAndData = split("=", $foundTag);
                last;
        if($i < scalar @lookForTags - 1) {
            print ",";
    print "\n";
PostPosted: 17:25 - 19 Oct 2015    Post subject: Reply with quote
Great thanks that looks good, last another thing, can I write this to a file?
Currently I'm running this from a Command Line and it is putting the output in the command line, which isn't big enough.
Stowelly
PostPosted: 17:30 - 19 Oct 2015    Post subject: Reply with quote
Rogerborg wrote:
[code]
the < will output to file
Stowelly wrote:
Rogerborg wrote:
[code]
That's the input file.
PostPosted: 17:32 - 19 Oct 2015    Post subject: Reply with quote
Never mind worked it out Thumbs Up
> text.csv
PostPosted: 17:40 - 19 Oct 2015    Post subject: Reply with quote
Big thanks Rog, Thumbs Up Got some decent output now.
Stowelly
PostPosted: 17:51 - 19 Oct 2015    Post subject: Reply with quote
my bad Very Happy
PostPosted: 09:11 - 20 Oct 2015    Post subject: Reply with quote
No problem, now I need to shower to get the stench of Perl off of me.
nowhere.elysium
The Pork Lord
PostPosted: 10:52 - 20 Oct 2015    Post subject: Reply with quote
It never goes away. Not entirely.
The last post was made 11 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.24 - MySQL Queries: 16 - Page Size: 116.02 Kb
