Winter riding & fogging up visor/specs
Kamikaze Bob
PostPosted: 07:42 - 21 Oct 2015    Post subject: Winter riding & fogging up visor/specs Reply with quote
Getting a frozen face the past couple of weeks, so decided to try and sort myself out for the winter. Got a fleece neck tube for a few quid, which is much better than the one I was using over the summer, and some winter gloves and a Foggy mask.
Winter gloves are getting sent back, used their size chart and they're too tight, plus can't get a decent feel for the controls. Put my regular gloves on today and it was night and day. Gonna try some silk inner gloves that are supposedly for skiing, read somewhere they should help without losing loads of feel.
Main issue is the Foggy tho. Came in the post at work yesterday, fitted and went home. But still getting a bit misted up unless moving at high speed and air rushing in. Adjusted and came into work today, but still getting the same result. When I looked in the mirror I think I may have found part of the problem - my nose is squint. Must have done it when I was a kid and thought it wasn't serious cos I've never been to hospital or nowt, but it's definitely off. I can get the mask up above that to create a proper seal (I think) but then can't get my specs to sit properly.
Cold mornings is starting to get annoying, especially wet ones like today. Don't want to open the visor to keep face from getting frozen, but closed visor and dirty roads mean I end up with mucky water all over my visor if I keep it closed, and I can't see cos the visor and my specs are getting fogged up!
Anyone got any ideas on this? Barring laser eye surgery which I can't afford, I think I'm fucked.
2001 Honda VFR800fi
wr6133
PostPosted: 08:01 - 21 Oct 2015    Post subject: Reply with quote
Contacts lenses and pinlock?
Matt B
PostPosted: 08:24 - 21 Oct 2015    Post subject: Reply with quote
This Thumbs Up Pinlock works well in the Winter and seriously reduces the issue.
Winter gloves always feel awkward and bulky when you first start using them (especially after thin summer ones) but you do get used to it after a while. I've found glove sizing to be a joke and end up ordering/buying two sizes bigger to get a good fit.
If winter gloves are a problem what about muffs?
winz
PostPosted: 08:39 - 21 Oct 2015    Post subject: Reply with quote
+2 for pinlock too. I don't think I could ever ride with my lid closed without one.
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
PostPosted: 08:48 - 21 Oct 2015    Post subject: Re: Winter riding & fogging up visor/specs Reply with quote
The point of adding layers is to create air gaps. If your gloves are already well fitting all you'll do is to fill in any the existing gap. I find liners harm rather than help. Hopefully you'll have better luck (and worse fitting gloves).
Muffs.
Visor = pinlock.
Specs = dunno, nothing I've tried has really worked. I've tried proprietary ('cat crap'), soap and polish off, rain-x, isopropanol. But get a good breath on them and they still fog. This is cheap plastic lensed sunglasses or clear safety glasses, mind, I can't speak to actual glass.
Doovy
PostPosted: 09:02 - 21 Oct 2015    Post subject: Reply with quote
Both work for me. I never ride in glasses and wouldn't have a helmet for regular use without pinlock.
Kamikaze Bob
PostPosted: 09:24 - 21 Oct 2015    Post subject: Reply with quote
Can't do contacts, tried years ago and they kept popping out. Just ordered a new visor as this one's scratched, doesn't have the pinlock bits on it tho, didn't think there would be much point with the specs. Might see about that tho, the replacement only cost £20.
2001 Honda VFR800fi
wr6133
PostPosted: 09:46 - 21 Oct 2015    Post subject: Reply with quote
You can get a universal DIY pinlock for around £20. Comes with the pins, insert, a template and a little drill thing. You then add the pins to a current visor.
UncleFester
PostPosted: 09:53 - 21 Oct 2015    Post subject: Reply with quote
Also this.
Same problem and i've come to the conclusion that if i want to ride at either end of the year, I need to go down the contacts route as glasses just steam up .... at which point a non fogging pinlock insert is pointless.
2017 Z1000SX
NJD
PostPosted: 10:06 - 21 Oct 2015    Post subject: Reply with quote
Don't be tempted by third party spray or wipes they're all useless IMO, just try contacts and see if they work for you, boots do a three week trial period and teach you all about them beforehand.
Once you've solved above consider pinlock, max vision + contacts is a dream come true in comparison to glasses.
Kamikaze Bob
PostPosted: 11:31 - 21 Oct 2015    Post subject: Reply with quote
I've got my checkup at the opticians next Saturday actually, maybe I will ask about it, it was years ago I did it before.
As for the gloves, my summer gloves I've had for years, so they're a little stretched anyways, a liner shouldn't be too bad I wouldn't think.
2001 Honda VFR800fi
Doovy
PostPosted: 12:26 - 21 Oct 2015    Post subject: Reply with quote
I use the Air Optix Night and Day lenses, can keep them in for about 5 days at a time without even removing them for sleep.
Acuvue Moist were also good.
Val
PostPosted: 13:22 - 21 Oct 2015    Post subject: Reply with quote
You need pinlock for the visor. For the glasses it helps if you have glasses with plastic lightweight lens not glass. Glass lens fogs easier.
Next step is buy glasses with the latest Essilor Optifog special anti-fog lenses:
https://www.ceyecare.net/Content/eyeglasses/lenses/essilor/optifog/default.aspx
https://www.specsavers.co.uk/ask-the-optician/optifog-lenses/
I am not convinced by these lenses,because you buy expensive lenses and also need to apply special spray product on top.
Here are details about different anti-fog products that may help us glass wearers:
https://vision.about.com/od/eyeglasses/qt/Anti-Fog-Lenses.htm
From my experience Foggy mask helps for glasses, but you need helmet with open down so that when you breath the air gets in and out down freely. Some helmets have too better wind stopper below the chin that returns back the air, just remove it.
JonWal
PostPosted: 13:56 - 21 Oct 2015    Post subject: Reply with quote
+1 for the Pinlock. £20 for a bit of flimsy plastic seemed a bit steep, but I dont know how I'd cope without it now. They really do work well.
- Yamaha YBR 125 - Swansea, UK
- Triumph Street Triple
A Licence Passed 25.09.2015
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 88.61 Kb
