how long can you leave a bike sitting for
bigdom86
PostPosted: 23:28 - 30 Oct 2015    Post subject: how long can you leave a bike sitting for Reply with quote
how long can you leave a bike to sit without starting it up? i have surgery soon and it won't be fired up for atleast 3 weeks, would this be ok? its a cbr125
thanks
Ichy
PostPosted: 23:31 - 30 Oct 2015    Post subject: Reply with quote
I have one that has sat for 7 years. I reckon it could do another 7 easily without starting it up.
Ichy
PostPosted: 23:33 - 30 Oct 2015    Post subject: Reply with quote
3 weeks is nothing. It might just need a bit of a charge when you get back to it but otherwise it'll be fine.
bigdom86
PostPosted: 23:35 - 30 Oct 2015    Post subject: re Reply with quote
so you reckon it will start up fine and i can ride it as normal? Thumbs Up i use it for work so cant be messing around in the morning Laughing
Triton Thrasher
PostPosted: 23:38 - 30 Oct 2015    Post subject: Re: re Reply with quote
Try it the night before.
Rrrrrrrrrrrrrrrrrr
Ichy
PostPosted: 23:38 - 30 Oct 2015    Post subject: Reply with quote
I left my bike for far longer than that without any problems. Seriously, three weeks is nothing. The battery might need a bit of a boost at most.
bigdom86
PostPosted: 23:39 - 30 Oct 2015    Post subject: re Reply with quote
sorry for the noobish questions but if it doesnt fire up how would i charge it?
Ichy
PostPosted: 23:48 - 30 Oct 2015    Post subject: Reply with quote
bump start or a battery charger. Chances are it'll be fine. Don't worry.
PostPosted: 00:04 - 31 Oct 2015    Post subject: Reply with quote
Don't be tempted to start it up and run it for a few minutes every day, you'll just flatten the battery. Give it a good long run, fill the tank, forget about it.
Nexus Icon
PostPosted: 01:22 - 31 Oct 2015    Post subject: Reply with quote
Mine sat for 3 months after back surgery and fired right up. 3 weeks should be fine.
You could hook it up to an optimiser while it's sat there if the battery is getting a bit old now, to make sure it has juice, but everything else will be fine and if the battery is strong that'll be alright too.
Greetings from Shitsville!
trevor saxe-coburg-gotha
PostPosted: 17:24 - 31 Oct 2015    Post subject: Reply with quote
I hadn't started one of my cb500s for a year until a couple of weeks ago (although the battery had been on a cheap ass Aldi trickler). Unbelievably - to me - it started on the button and sat there idling like it had been a couple of days.
Wednesday Biker
PostPosted: 19:33 - 31 Oct 2015    Post subject: Reply with quote
My bike lasted 11 days before it wouldn't start,battery was 6 months old.
I've left it 3 weeks before and since and started first time.So dunno what was up with it.
My old 125 I left 3 months before with no problem.
You should be fine really.
Lord Percy
PostPosted: 20:28 - 31 Oct 2015    Post subject: Reply with quote
To muddy the waters a bit...
I left my bike for about 3 months then it wouldn't start. Ended up being some weird electrical thing which nobody ever got to the bottom of, aside from knowing that the solution was to pull a wire out of the relay box then simply reconnect it again.
Then at a later point I left it for a similar amount of time and the same problem happened again. Pretty weird.
Wonko The Sane
PostPosted: 22:03 - 31 Oct 2015    Post subject: Reply with quote
My brakes bind a little bit after the bike has been sat for a week or so but other than a quick wipe of the disks with brake cleaner and a spot of lube on the chain before parking up it's fine
the brakes stop binding by the time I've got to work when I next get on it.
Aceslock
PostPosted: 17:31 - 04 Nov 2015    Post subject: Reply with quote
Please dont mix these up........ Mr. Green
Previous Bike: Skyjet SJ27
Sold: Yamaha YZF 600 R Thundercat. Sold: ZX636R
Current bike: R1 14B (Beast)
Val
PostPosted: 01:08 - 05 Nov 2015    Post subject: Re: how long can you leave a bike sitting for Reply with quote
thanks
3 weeks is nothing.
You charge it before so that it fires up. What is the point to wait for battery to get discharged and than to not fire up Laughing
Buy a charger it cost £20. Connect the charger permanently to the battery or remove the battery, charge it and keep it indoors for 3 weeks. This way you will know it will fire up for sure.
https://www.fc-moto.de/epages/fcm.sf/?ObjectPath=/Shops/10207048/Products/Oxford-Oximiser-900-Battery-Care&Currency=GBP&Locale=en_GB&ViewAction=ViewProductViaPortal&&utm_source=Portalexport_MBO&utm_campaign=GoogleShopping_GB&gclid=CjwKEAiA9uaxBRDYr4_hrtC3tW8SJAD6UU8GE5VtPBr9umn_R_A86eaPV8xWoKtHFB5Kn3CQ2TAtCxoCU1bw_wcB
or the Halfords one is £27 if you can't wait for delivery:
https://www.halfords.com/motoring/motorcycling/motorcycle-accessories/halfords-motorcycle-maintenance--charger-1-25-amp?cm_mmc=Google+PLA-_-Motorcycling-_-Motorcycle+Accessories-_-965533&_$ja=tsid:60494|cgn:GoogleShopping|kw:965533&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=liwtiq&istBid=tzxt&_$ja=tsid:35522|cid:356616244|agid:24765782284|tid:kwd-63100764844|crid:86548719724|nw:g|rnd:14556145002821755477|dvc:c|adp:1o2&gclid=CjwKEAiA9uaxBRDYr4_hrtC3tW8SJAD6UU8GkitrkQhthhEpEg3pTeQfAbq4Nz5I0-T1fceh318mhhoC7gfw_wcB
PostPosted: 02:42 - 05 Nov 2015    Post subject: Reply with quote
When I was at sea the longest I ever left a bike was 7 months. All I had done was remove and fully charge the battery before I left. When I came back I recharged the battery, replaced it back on the bike and started it. Thumbs Up No issues.
I have to say the bike was in a garage that was part of the house and did keep quite warm.
talkToTheHat
PostPosted: 03:28 - 05 Nov 2015    Post subject: Reply with quote
Consider that petrol lawnmowers might be used every other sunny summer Sunday and then forgotten about over winter.
If you have a fuel petcock (tap) turn it to off, and if you are a forgetful type put some kind of "turn back on before riding" flag. A strip of old high-vis vest does for me. Particularly useful on the exhaust bung that goes in before washing.
As mentioned above you might need to charge your battery, or start bike using jump leads or a booster pack. Be very careful not to touch the red +ve lead against the frame or engine. My bike is old and has the starter accesible at the front, so i just connect the -ve lead to frame bolt i know is a good earth, and touch the +ve to the terminal on the starter motor. Battery is so well hidden car jump leads wont go in there.
Bandit. does. everything.
andyscooter
PostPosted: 09:21 - 05 Nov 2015    Post subject: Reply with quote
my old 50cc was sat in the garage for 12 months
recharged the battery and it started and ran fine
Doovy
PostPosted: 11:01 - 05 Nov 2015    Post subject: Reply with quote
My aunt's RXS was sat in her shed for 14 years. It didn't start.
The last post was made 10 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 111.77 Kb
