XR 400 Adjusting Rear Brake Pedal Height
killerbanjo
PostPosted: 03:33 - 19 Nov 2015    Post subject: XR 400 Adjusting Rear Brake Pedal Height Reply with quote
Hey all, need to lower my pedal height but the clevis is pretty tight on the pushrod, i can't get anything to hold onto the pushrod as there is not enough room, but was wondering if I can remove the pushrod without leakage? I can't quite tell from the diagrams and wondered if anyone has had any experience with it. Once removed I can get some grips or something on it and free off the clevis.
https://snag.gy/PYCA5.jpg
Fladdem
PostPosted: 00:15 - 20 Nov 2015    Post subject: Reply with quote
Bear with me, I'm down the pub.
The push rod can not be removed, there is a washer slides over the top between the piston, I believe. You should be able to pull the rubber boot down that stops dirt ingress to the washer, you should find find a ten mill thing on the rid to hold Vit and adjust the twelve (?) nut on the clevis.
You should find that will help. Forgive me if I've misunderstood the question. Hope that's of son assistance..
Fladdem
PostPosted: 00:17 - 20 Nov 2015    Post subject: Reply with quote
You should find that will help. Forgive me if I've misunderstood the question. Hope that's of son assistance..-
Fizzer Thou
PostPosted: 18:33 - 25 Nov 2015    Post subject: Reply with quote
By loosening the locknut that is against the clevis,you should be able to adjust the height of the peddle using the 12mm nut.You should only need to adjust it a small amount at the clevis Thumbs Up
Always have a 'Plan B'
The last post was made 10 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 16 - Page Size: 43.47 Kb
