suggestions needed
Larry90
PostPosted: 11:37 - 05 Dec 2015    Post subject: suggestions needed Reply with quote
Hi Guys
Im looking into getting a new bike in the new year,
i currently own a GSX650F which has a gear indicator and would like another bike with this feature,
I would like more of a naked bike rather than full fairing, but cant find many with gear indicator as standard.
Engine size from 600cc and upwards.
Any suggestions??
Fisty
PostPosted: 11:41 - 05 Dec 2015    Post subject: Reply with quote
If you can't work out what gear you are in then you have problems. Buying a bike for the feature of a gear indicator is one of the dumbest things I've ever heard. There are so many great bikes you are missing out on!
Fatter and faster than Fret
dydey90
PostPosted: 11:43 - 05 Dec 2015    Post subject: Reply with quote
Just get one retrofitted, they're not expensive. If you get an ER6n, I know they're super easy to fit, just plug in to a port under the seat. My ER6f had a GI pro indicator fitted when I bought it.
Edit: turns out they're expensive
PostPosted: 11:52 - 05 Dec 2015    Post subject: Reply with quote
As above, if it's something you really want, I'd expect most modern motorcycles can be retro-fitted with a gear indicator.
MCN
PostPosted: 12:13 - 05 Dec 2015    Post subject: Reply with quote
Healtech stuff is well good quality.
I fitted a GI gear indicator to the ER650F. As Stinkers mentioned, there should be a receptacle/socket in the harness under the seat to simply 'plug n play'.
Only 'hassle' would be routing the cable to somewhere you can see it.
And check before you screw or glue that you can see the indicator in daylight.
It has a speshal prastic 'lens' material that cuts out glare but that don't mean it is visible in all lighting.
And don't run the cable near hot shit or where it can be schnecked/pinched between moving parts. £99 big ones to chop in half is not funny.
The ER6 goes much faster now with the GI.
Easier to install and better than the purple power band I fitted (which failed miserably the week after and I stupidly bought the new PB off ebay so no warranty on it. Smile)
NJD
PostPosted: 12:25 - 05 Dec 2015    Post subject: Reply with quote
Out of interest (because you're basing the whole choice around this feature), why?
PostPosted: 13:11 - 05 Dec 2015    Post subject: Reply with quote
Street Triple, because why wouldn't you?
Caino7
PostPosted: 14:35 - 08 Dec 2015    Post subject: Sinnis Apache 125 oil problem Reply with quote
Hey guys,
thought I'd try this website out to get some help and suggestions.. I own a sinnis Apache 125, was riding it for a while yesterday and started to slip so pulled liver and oil was everywhere I need some help fixing the issue, any ideas? 🤔 Question[/b]
cain
PostPosted: 14:55 - 08 Dec 2015    Post subject: Reply with quote
You'll want to start a new thread in the Workshop section.
I'd suggest that you tell us what you've done to find the source of the oil leak. Not here, in your new thread.
Matt B
PostPosted: 17:49 - 08 Dec 2015    Post subject: Reply with quote
Because they are dog slow down the 1/4 mile at Santa Pod where they are easily outpaced by a 1200 Bandit. It's a proven BCF fact dat.
Buy a Bandit 1200 and fit a gear indicator Thumbs Up or learn to count up to 5
The last post was made 10 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 67.64 Kb
