| Snop Doog |
 Snop Doog Brolly Dolly
| ForestRunner |
 ForestRunner Nova Slayer
| Snop Doog |
| finniee |
 finniee Spanner Monkey
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 11:37 - 20 Dec 2015 Post subject: |
You probably can't adjust the idle-air mixture, but there should be a throttle stop screw somewhere on the throttle body to adjust the idle speed.
Remove the right-hand cover and have a look at the throttle body, and you should be able to see a small hex-headed screw with a lock-nut that adjusts the position where the throttle valve (butterfly valve) comes to rest.
There are other things that can affect the idle speed on those though - so remove and check your spark plug to see if it running lean or rich, and check your air filter.
Valve clearances are also known to cause idle speed problems.
You might get better help from a specific forum or blog - try This One. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:48 - 20 Dec 2015 Post subject: |
Have a gander at this guy's blog - he's done a fair bit on his CBF125 :-
https://www.bikesandtravels.com/biker.aspx?ride=488 ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Snop Doog |
| finniee |
| Snop Doog |
 Posted: 19:48 - 20 Dec 2015 Post subject: |
Yep, except only one light works as I only replaced the Speedo's dashlight as none of them worked when I bought it  |
| finniee |
| Snop Doog |
| finniee |
| Snop Doog |
| stinkwheel |
 Posted: 00:25 - 21 Dec 2015 Post subject: |
Can I be the first to say. "If it aint broke, don't fix it.".
Doesn't sound like anything is broke to me so put the screwdriver down and step away from the vehicle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Snop Doog |
The last post was made 10 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
