| Oldie |
 Oldie Brolly Dolly
| Oldie |
 Oldie Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:09 - 21 Dec 2015 Post subject: |
Have you had a look at where the brake line runs? If it's like my GS, it'll run back to the ABS unit, not straight down to the brakes. Do you actually need to extend it? ____________________ Biking is 1/20th as dangerous as horse riding.
| Oldie |
 Oldie Brolly Dolly
| G |
 G The Voice of Reason
| Oldie |
 Oldie Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:58 - 21 Dec 2015 Post subject: |
If it's the same system as on the 800 GSes, bleeding shouldn't be an issue.
Unlike on older BMW systems which appear to be a right sod to do, the ABS circuit is sealed off from the normal lines. You can drain/bleed/flush the lines right through and the fluid in the ABS part won't be disturbed.
The Motorrad Monkeys have a gadget that will hold the ABS valve open so that you can flush / bleed that circuit at the same time, but you don't need to.
Ostensibly you can renew the ABS fluid by renewing the fluid in the normal line then triggering the ABS a few times to open the valve, then renewing again. I'm not 100% convinced that will be completely effective, but unless you actually want to renew that fluid it's not an issue - I drained and renewed the front circuit on my GS without any problems or trickery. ____________________ Biking is 1/20th as dangerous as horse riding.
| Oldie |
 Oldie Brolly Dolly
| bugeye_bob |
 bugeye_bob World Chat Champion
| Pete. |
 Pete. Super Spammer
| Hahadumball |
 Hahadumball World Chat Champion
| iooi |
 iooi Super Spammer
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 18:05 - 21 Dec 2015 Post subject: |
there is a shop in newcastle upon tyne which makes bespoke braided lines ..
quite sure i`ve seen ends as pictured loose in his shop window display
he makes the lines up himself .. ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:08 - 21 Dec 2015 Post subject: |
Add an extension carefully to the top of the line would result in minimal fluid loss and all the air would start near the reservoir. Pretty much trivial to reverse bleed out, and an interesting suggestion given the reasonable concerns about bleeding past the ABS unit. ____________________ Biking is 1/20th as dangerous as horse riding.
| Vincent |
 Vincent Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:18 - 22 Dec 2015 Post subject: |
That's very ghetto - I love it.
I've never been sure of the point of those stops on M/Cs. Anyone? ____________________ Biking is 1/20th as dangerous as horse riding.
| Pete. |
 Pete. Super Spammer
| Vincent |
 Vincent Banned
| Oldie |
 Oldie Brolly Dolly
| Vincent |
 Vincent Banned
 Posted: 22:49 - 22 Dec 2015 Post subject: |
| Oldie |
 Oldie Brolly Dolly
 Posted: 05:51 - 23 Dec 2015 Post subject: |
Thanks Vincent - that just might do the trick  |
The last post was made 10 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
