| Simba76 |
 Simba76 Renault 5 Driver
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 19:11 - 27 Jan 2016 Post subject: |
Get a screwdriver and bridge the 2 pins on the starter relay, if the motor turns, then it's not the motor.
Could also check if there is voltage getting to the starter.
Also the starter motor body is the earth to the engine, so could check this too. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| talkToTheHat |
| Ariel Badger |
 Ariel Badger Super Spammer
| Simba76 |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Simba76 |
| Nemo |
 Posted: 18:53 - 28 Jan 2016 Post subject: |
Most likely cause will be the bushes inside the starter motor, open it up and have a look, sometimes you can get a repair kit.
If you do strip the motor, be careful of the o ring when you put it back together. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
| Simba76 |
| RhynoCZ |
 RhynoCZ Super Spammer
| talkToTheHat |
| Nemo |
 Posted: 12:57 - 02 Feb 2016 Post subject: |
Do you still have the starter motor off? If you have a set of jump leads you can connect them to a battery, then put the negative on the body of the starter motor, when you touch the positive to the terminal it should start spinning (if it works).
Other than that I can't remember what's under the seat electronic wise so can't help you there, just check the loom and any connections for damage (if there is a connector and it only came slightly apart, it could have been arcing and cause it to get hot) ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
| Simba76 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:00 - 10 Feb 2016 Post subject: |
Moral of the story is to buy a £5 multimeter and actually use it.  ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 10 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
