| danwilde |
 danwilde L Plate Warrior
| mudcow007 |
 mudcow007 World Chat Champion
| danwilde |
| smallfrowne |
 smallfrowne Scooby Slapper
 Posted: 13:58 - 22 Feb 2016 Post subject: |
I have an 'E' - it was 6V. It probably can be done. The battery provided juice for the indicators and brake light, the horn too I think.
Wiring diagram (click for bigger)..
https://i.imgur.com/igNs4Pal.jpg
The yellow wire from the stator goes to the handlebar switch, which switches it either to the blue (high beam) or white (low beam). ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| danwilde |
| smallfrowne |
| smallfrowne |
 Posted: 14:44 - 22 Feb 2016 Post subject: |
The spark comes from the black/white wire, it goes to the ignition coil and condenser. It continues to the ignition switch, where in the off position it grounds the black/white wire (goes to green) - which causes the 'spark' to never reach the ignition coil or spark plug, thus immobilising the bike. Which is pretty shit as it makes it very easy to bypass if you don't have a key.
Are you wanting a horn as well?
Also, pictures of the custom cg please  ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| smallfrowne |
| mudcow007 |
| smallfrowne |
 Posted: 16:52 - 22 Feb 2016 Post subject: |
You're right, the resistor is only used when the pilot light is selected though iirc. It might be an idea to use the resistor in-line with the lamp if the new set-up keeps blowing bulbs due to excessively high voltage though.  ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| danwilde |
Thanks for all the advice and ill try and put some pics up in the next couple of days smallfrowne of my bike so far when i have access to a phone with a better camera than my calculator
Cheers! |
| redeem ouzzer |
| danwilde |
 Posted: 17:15 - 22 Feb 2016 Post subject: |
Just putting it through a day M.O.T and then hooking up the headlight afterwards.........hopefully  |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| danwilde |
The last post was made 10 years, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
