| supZ |
 supZ World Chat Champion
 Posted: 11:18 - 10 Mar 2016 Post subject: Indicators taking a good few seconds to engage |
Haven't had a chance to have a good look at this yet but I was wondering if anyone else has experienced this type of issue.
Got through my MOT on monday fine, I did mention to him the indicators are reacting slowly to the switch which he did agree with but they did work (eventually) so it's still a pass.
Basically, I'll flick the switch and it could take 5+ seconds for the indicators to start working, after which they flash fine but as you can imagine, 5 seconds later I'm most likely already round the corner and up the road so it's not that helpful.
My 1st thought is that the relay is on its way out which presents its own problems as honda, for some stupid reason, integrated it into the instrument cluster so I'm going to have to rewire the loom to bypass it (I've seen various guides on this, shouldn't be a problem but why honda?? why?)
I've ordered a load independant relay and may look to doing some rewiring this weekend.
So yeh, just wondering if anyone else has had the prob and would you think a relay swap fix the issue?
# Bikes a 2003 CBR954 FireBlade
# Indicators are standard bulbs, not LED
# Battery is fine, it's pretty new and kept on my smart charger most of the time. Bike starts and runs on the button every time
Cheers ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| Minty |
 Minty World Chat Champion
| Matt B |
 Matt B World Chat Champion
| supZ |
| Minty |
| supZ |
 Posted: 12:26 - 10 Mar 2016 Post subject: |
Can't hurt, just don't understand how it would help with my issue but more than happy to be proved wrong. As said, I don't think it's a switch contact issue
High beam switch sticks a bit so I need to 'lube' up the switchgear on that side anyway.
We'll see  ____________________ CBR954RR - Daily toy
| Minty |
 Posted: 12:38 - 10 Mar 2016 Post subject: |
* results may vary.
My experience of automotive relays has been that they work or they don't. Have never had me a 'slow' relay. Stand to be corrected though.  ____________________ My fingers smell of your mum. |
| Matt B |
| Islander |
 Islander World Chat Champion
 Posted: 15:25 - 10 Mar 2016 Post subject: |
As above, push the switch to one side and squirt some contact cleaner into the slot then work the switch. Push the switch to the other side and work it again. Repeat as necessary.  |
| supZ |
| Matt B |
 Posted: 17:37 - 10 Mar 2016 Post subject: |
That's all we are saying, try the easy/free job first. No guarantee it's your problem but it has been known to work.  ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| Vincent |
 Vincent Banned
| Islander |
 Posted: 17:48 - 10 Mar 2016 Post subject: |
First you have to understand how flasher relays work. They rely on a heating coil wrapped around a bimetallic strip, when you flick the switch over it passes current through the heating coil to the lamp. That causes the bimetallic strip to heat up and bend, breaking the contact and turning the lamp off. It then cools and the cycle starts over.
If your indicator switch has oxidisation or crud on the contacts, then it won't pass the current needed to make the relay operate properly and that will introduce a delay. Clean the contact and the problem should go away. Use electrical contact cleaner for this as it'll not only shift any contaminants, but also leave a film of lubricant on everything.  |
| supZ |
 Posted: 17:57 - 10 Mar 2016 Post subject: |
| Vincent |
 Vincent Banned
| supZ |
 Posted: 18:01 - 10 Mar 2016 Post subject: |
Vincent, yeh that's the one.
Cool cheers, that'll be good to see  ____________________ CBR954RR - Daily toy
| Vincent |
 Vincent Banned
 Posted: 18:30 - 10 Mar 2016 Post subject: |
You can do this with the switch still attatched to the bike, you'd have to unplug it first...but I wouldn't recommend it, you're dealing with small parts and you're better of on a workbench or table. I find it best to work on a piece of cloth or rag, it stops things sliding about and makes it harder for stuff to roll away. Use a normal sized phillips/pozidriv screwdriver for the small screws and don't round them off, they can be stuck quite fast. Cup the half of the switch firmly in one hand while undoing the screws with the other...just don't slip and go thorugh your hand with the driver.
First part, unscrew the small philips on the lever, the one the lever pivots on:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103558_zpsirfg2g7o.jpg
Remove the small brass bush sitting underneath:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103559_zpsjjcgoazq.jpg
Remove the small phillips holding the wire retainer on. The retainer is a shaped bit of steel designed to stop the lead getting puled or chafing on the handlebars, this'll make it possible for the switch unit to be removed:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103560_zps4p8num7h.jpg
Remove said wire retainer:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103561_zpsq4cxp8e4.jpg
Remove small phillips that holds on the switch lever plate:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103562_zpsrrcfaymt.jpg
brb..
OK..Next, carefully tease the wiring out of the switch, thus:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103564_zpstdohpknu.jpg
Here, I'm pointing out where the spring will appear from, there's a good chance it wil be gunked up so shouldn't "ping" out, just don't lose it. Also note that I've removed the pivot screw from the horn switch, you don't really need to do this unless you want to clean out the horn switch too. They tend not to get as messed up as the indicator switch but worth looking over and remove to clean if you wish.
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103566_zpsnaf32bmc.jpg
Switch unit is now out of the switch housing and here you can see the ball bearing still in place:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103567_zpssys2yneq.jpg
Push the ball out from the other side with...well, anything you like.
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103568_zpsvpblcpid.jpg
Spring and ball:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103571_zpsonaoha60.jpg
This is the switch proper. Note it is made of of three parts, two of which, the black part and the centre white part, are housing the slider contacts. You have to get these apart...
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103569_zpsffg9gp4q.jpg
Here's where they're held together, the black part has two clips that clip into the holes in the other part. Gently open one side up to release that sides clip. DONT BREAK IT
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103572_zps0cfnvc88.jpg
When one side is out, you can pull the switch assembly apart to show the contacts. This is what you should have. Note the ball in the white part that holds the contacts, this is for locating the slider in it's three positions - Left, right and centre. This ball should stay in place while the switch is apart.
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103574_zpsqela3tzh.jpg
Just clean these lot up now, degreaser is good, I'm using a spot of degreaser to start then some contact cleaner. Be carefull with the smaller of the two white parts of the switch, don't lose or bend the contacts while cleaning as they're loose.
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103563_zps2kaeauqg.jpg
After a good dousing with degreaser and leaving for a few minutes, I use cocktail sticks to get into the smaller spaces, again be careful around the contacts:-
https://i77.photobucket.com/albums/j71/Drewskovitch/Jap%2070s%20bike%20toys/Bike%20toys/P3103575_zpsc1puli1w.jpg
Be back after I've cleaned them up but assembly is just the reverse, just add grease to the moving components - the spring and ball, and the sliding part of the switch. I'm using silicone grease but that's probably not the best. I'm sure I'll soon find out
Will add bits if I think of any ____________________ Space Is Deep
| Islander |
 Posted: 18:34 - 10 Mar 2016 Post subject: |
Where's the picture of the tiny ball bearings and springs pinging out in opposite directions?  |
| Vincent |
 Vincent Banned
 Posted: 19:10 - 10 Mar 2016 Post subject: |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| supZ |
 Posted: 22:19 - 10 Mar 2016 Post subject: |
That's some awesome information there! Very nice indeed
I had a look at it when I got home from work and well.. mine looks a fair sight better than that one
https://c2.staticflickr.com/2/1594/25054950943_66204e51ce_b.jpg
Ironically, the moment I tried it when it was apart it kicked in immediately.
I still gave it a bit of a squirt with WD40 on the sides and did the same to my high beam switch which is now moving freely, so that's something.
Put it all back together and it appears to be working fine again.. both annoying and not annoying that there doesn't appear to be anything wrong and it's coming on when expected but I'm not going to look a gift horse in the mouth so I'll see how it goes and if it starts playing up again I'll come back and follow your guide to dismantle it.
Thanks again for that by the way, that could help a lot of people  ____________________ CBR954RR - Daily toy
| Vincent |
 Vincent Banned
 Posted: 22:30 - 10 Mar 2016 Post subject: |
You see that blob of yellow grease? That's grease that's gone off and become sticky....there's your problem. Stick a match end in it and you'll see what I mean. It's not as much the muck that makes the switch misbehave but the sticky old grease It's different to the grease you use on bearings etc, it's called dielectric grease or something like that, it seems to go off in less time and ends up like treacle. ____________________ Space Is Deep |
| mauzo |
 mauzo Nova Slayer
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
