Worn ignition barrel.
Copycat73
PostPosted: 20:11 - 07 Apr 2016    Post subject: Reply with quote
weld the fcuker shut then super glue your face to the hot metal...
cos bodgin is all your good at .... Middle Finger
caveat emptor
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
Snod Blatter
PostPosted: 20:27 - 07 Apr 2016    Post subject: Reply with quote
Since it is a Yamaha try pushing the top of the key towards the outside of the lock when you turn it. This often vastly improves the situation.
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Pigeon
PostPosted: 22:03 - 07 Apr 2016    Post subject: Reply with quote
Could try spraying a load of 3in1 in there. Bit of oil + ptfe seems to work well in locks.
redeem ouzzer
PostPosted: 22:09 - 07 Apr 2016    Post subject: Reply with quote
I hope op gets raped and murdered in prison.
Be a REAL MAN!
Suntan Sid
PostPosted: 22:45 - 07 Apr 2016    Post subject: Re: Worn ignition barrel. Reply with quote
God.i wrote:
Turning the key in my 2001 FZS 600 is becoming slightly increasingly a PITA I have to wiggle it before it turns.
Probably not what you want to hear, but its a Yamaha, every Yammy I've owned, including my current FZ1 has been the same, they all required the key to be wiggled to get it to turn.
Jmh600
PostPosted: 22:49 - 07 Apr 2016    Post subject: Reply with quote
My old r6 was a bastard for this, I used to have to properly roll the key in the lock before it would turn..... A good dose of acf50 really helped!
Jmhmotorcycles
Pigeon
PostPosted: 23:41 - 07 Apr 2016    Post subject: Reply with quote
I've got a Suzuki and they are proper loose, you can stick it in at any angle and not touch the sides. I only found this out at the last MOT because I got an advisory on being able to pull out without the engine dying.
Now, I think its a great feature. Each time I forget to remove the disk lock, I leave the old girl warming up while I take the key out to open the rear top box and drop in my disc lock, then ride off with the key in my pocket.
Copycat73
PostPosted: 09:59 - 08 Apr 2016    Post subject: Re: Worn ignition barrel. Reply with quote
God.i wrote:
Why aye get fucked off yer fat old geordie cunt. Middle Finger
i may be many things but at 13st 2 lbs and 5-10" fat in not one of them..
but you are trully a horrible little troll.
caveat emptor
The last post was made 10 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2 - MySQL Queries: 16 - Page Size: 72.41 Kb
